Since there seems to be a common misconception about octane, I thought I would go through and explain it for you
Octane rating tells you the fuels ability to resist spontaneous ignition under compression. Lower octane fuel (such as 87 octane) will be able to withstand lower amounts of compression than high octane fuel (like 92 octane).
What octane fuel you use will depend on what your compression ratio is. Lower compression vehicles (8:1 compression) will use low octane fuel. High compression vehicles (11:1) will need to use high octane fuel. Each engine has the specified octane that should be used in it.
Using the correct octane is important to the running condition of the car. If you use too low of an octane fuel, your engine will knock. Knocking is when the fuel ignites due to being compressed, instead of the spark from the spark plug.
If you use too high of octane fuel, not all of the fuel will burn. This causes carbon build-up to form on the inside of the cylinder. This will eventually cause problems with in your engine.
So to correct many misunderstandings, using higher octane gas does not create more power. It mearly shortens the amount of time before you need to rebuild your engine.
Hope that helped
Mike
Hope that helped
Mike
