101 - 120 of 124 Posts
I got a recall today for incorrectly manufactured vacuum pump that exists in certain 2017 Sienna’s and 2018 Highlander’s. I saw the Dealer note and it said 5900 vehicles. Lucky me. He was surprised I got a notice already.
That's interesting. I thought the vacuum pump issue is a TSB only. Now it looks like it's a recall. I wonder what VINs are affected?
Care to post a pic of your recall letter?
Thanks
2018 HL Recall - Brake Assist Vacuum Pump may Fail - NHTSA Campaign Number: 18V211000
Thanks @rjg202
Yup... I actually came across the recall press release (see post #96) but forgot about it..
Looks like the HLs affected by this recall are the MY2018 ones produced Early October 2017 – Early November 2017.
Attached are the relevant recall docs for HL from NHTSA website.
https://www.nhtsa.gov/vehicle/2018/TOYOTA/HIGHLANDER/SUV/AWD#recalls
'18 HL Ltd, '19 GMC Acadia Denali, '02 Honda Civic EX
Bummer. I'll be watching the mail for my letter since I have an Oct '17 build date and it's not likely that it was built in the first 3 days of the month.
Just an update when to the dealer for 15k service they said there was a recall, I mentioned parts were not available when I was here in May. Long story short the parts person stated they are still waiting on parts back ordered for another vehicle since May. Is this normal not to have parts available? I thought mine were ordered before as well. But I let that go.
Credit to @lloyd123
T-SB-0279-17
Entune Audio Head Unit Software Update (Panasonic)
Applicability
2016 - 2018 4Runner, Avalon, Avalon HV, Highlander, Highlander HV, Prius, Sequoia, Tacoma, Tundra
2017 - 2018 Prius Prime, Prius V
2016 - 2017 Sienna
2018 Yaris
REVISION NOTICE
March 16, 2018 Rev1:
- Applicability has been updated to include 2018 model year vehicles.
SUPERSESSION NOTICE
The information contained in this bulletin supersedes Service Bulletin No. T-SB-0103-16 and T-SB-0337-17.
(Long list of entune versions and issues in the TSB. See attached for details)
Also see:
https://www.toyotanation.com/forum/333-highlander-3rd-generation-2014/1602546-2017-audio-system-firmware-update.html
Anyone have access to REV 2 of this TSB?
Start over at pg. 1.
What an odd response. Toyo2016's post #75 asked if it might not be useful to put all the TSB's in a "list" to make it easier to find them, rather than having to search through all the posts for a particular TSB, and you reply to "start over at pg.1". I see no list at page 1, do you?
2015 Sienna / 2018 RAV4
T-SB-0229-17 - MIL "ON" DTC p211904
Saw this on NHTSA... not sure if it's posted here before. Anyways, here it is:
T-SB-0229-17 June 22, 2017
MIL "ON" DTC P211904
2017 Highlander, Sienna
Some 2017 model year Highlander and Sienna vehicles may exhibit a MIL “ON” condition with Diagnostic Trouble Code (DTC) P211904 – Throttle Actuator “A” Control Throttle Body Range/Performance System Internal Failure present. The Engine Control Module/Powertrain Control Module (ECM/PCM) logic has been modified to reduce the possibility of this condition. Follow the Repair Procedure below to address this condition.
T-SB-0313-17 - Brake Vibration and Lug Nut
Another one ... torque your nuts properly!!
T-SB-0313-17 November 14, 2017
Brake Vibration and Lug Nut Torque
2015 - 2018
4Runner, 86, Avalon, Avalon HV, C-HR, Camry, Camry HV, Corolla, Highlander, Highlander HV, iA, iM, Land Cruiser, Mirai, Prius, Prius C, Prius PHV, Prius Prime, Prius V, RAV4, RAV4 HV, Sequoia, Sienna, Tacoma, Tundra, Venza, Yaris, Yaris R
Some 2015 – 2018 model year Toyota vehicles may exhibit brake vibration due to improper lug nut torque. Brake vibration can occur at any time if improper torque is applied to lug nuts. Even one lug nut over or under torqued can cause vibration.
T-SB-0073-18 - 2GR-FKS Engine Oil Leak from Cam Sensor Bolt Hole(s)
Yet another TSB ... anyone has this issue??
T-SB-0073-18 July 26, 2018
2GR-FKS Engine Oil Leak From Cam Sensor Bolt Hole(s)
2017 - 2018 Highlander
VDS(s): BZ3FH, BZRFH, DZ3FH, DZRFH, JZRFH, KZRFH, YZ3FH, YZRFH, ZZ3FH, ZZRFH
Some 2016 – 2018 model year Tacoma, 2017 – 2018 model year Sienna, Highlander, and 2018 model year Camry vehicles equipped with a 2GR-FKS engine may exhibit an engine oil leak from the cam sensor bolt hole(s).
T-SB-0072-18 - Front Brake Vibration
T-SB-0072-18 July 26, 2018
2014 - 2018 Highlander
Some 2014 – 2018 model year Highlander vehicles may exhibit a vibration from the front brakes during light application of the brake pedal at highway speeds.
T-SB-0127-18 - Power Back Door Squeak Noise
I think I have this issue...
T-SB-0127-18 September 28, 2018
2014 - 2018 Highlander, Highlander HV
Some 2014 – 2018 model year Highlander and Highlander HV vehicles may exhibit a condition where the power back door (PBD) makes a squeak noise while the door is opening or closing.
T-SB-0160-18 - Transaxle Whine Noise, Harsh Shift, MIL ON, or Reduced Power
T-SB-0160-18
December 17, 2018
2017 - 2018 Highlander, Sienna Transmission(s): 8AT
Some 2017 – 2018 model year Highlander and Sienna vehicles may exhibit a whine noise while driving, a harsh shift, MIL ON, or reduced power.
T-SB-0018-19 - Knocking Noise From Fuel Tank Area
T-SB-0018-19
February 15, 2019
2017 - 2019 Highlander
Some 2017 – 2019 model year Highlander vehicles may exhibit a knocking noise from the fuel tank area at idle, vehicle stationary, with a full tank of gasoline. Follow the Repair Procedure in this bulletin to address this condition.
I should post this here as well.... Looks like Toyota has decided to make good on the tranny issues! A 2017/2018 UA80e/f Transmission Warranty Enhancement Program called ZJC was announced a few weeks ago and letters are just starting to go out.
All for an improperly bent nut locking tab.... 10 year coverage!
T-SB-0160-18
December 17, 2018
Does anyone have a link to the audio files referenced in this TSB? How loud is this whine noise? Something intuitively obvious or something you have to listen for?
