1 - 20 of 153 Posts
2019 Toyota Corolla Hatchback XSE
Brand- Klutch Wheels SLC1
Size- 18x9.5"
Offset- +30
Tire Size- 205/40R18
Brand- MSR
Size- 18x8.5
Offset- +35
Tire Size- 215/35R18
Brand- MSR
Size- 18x8.5
Offset- +35
Tire Size- 225/40R18
Brand- Aodhan
Size- 17x9
Offset- +35
Tire Size- 215/35R17
Brand- XXR
Size- 17x10
Offset- +20
Tire Size- 225/45R17
I found what I'm gonna do with the sti wheels I have. They are 5x114 et53. So I have to convert them with a spacer. If I do a 25mm spacer which are common. That will give me the same specs I compared to another members car that had 17x8.25 xxr wheels. I can't remember his name but I would like to get input on what tire size.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Discussion Starter · #9 ·
Sent from my SAMSUNG-SM-G930A using Tapatalk[/QUOTE]
I'd just run a stock 215/45/17
Nice. I just found a little more information: I think the bore is 57,1 for the wheel compared to the 2015 Rollas 54,1 so would you think a decent tyre store could put some sort of spacer to make up for the bigger bore?
Yeah, if you want to purchase them yourself they're usually 10-15 bucks for all 4, get the ones with an inner diameter of 54.1mm (to sit on our hubs) and outer diameter of 57.1mm (for the Rotiforms to fit onto).
Brand- ENKEI LS-5 BLACK
Size- 18 X 7.5
Offset- +42
Tire Size- 225/40/18 BFG G FORCE SPORT COMP 2 AS
FYI, Your tires are on backwards, If you switch the left side with the right, that should correct it (from what I can see in the photos, anyway).
Yes, it won't matter if there's no rain (like here in L.A.), but the idea of these directional tires(there should be arrows on each tire, that should point forward), is to channel water away from the center of each tire to eliminate or reduce Hydroplaning.:nerd:
Flying Under The Radar
2015 Toyota Corolla
Size- 18 X 7.5
Offset- +42
They are installed correctly. If you look at the tire pic more closely you can see the forward rotation arrow is at the 6 or 7 o'clock position. Thanks for looking out for me just in case and for any other members that might not know about directional tires.
2014 Super White Rolla S
Looking at wheels and I really love the style that the HRE FF01's have, like the 2015 SEMA corolla. Reasonably priced wheels that look similar are the TSW nurburgring, avant garde m310 and the VMR 710's. Dont really like how boxy the TSW's are and haven't heard any good about the VMR so i'm really thinking the AG's are what I will do, they are 18x8 and I want to know if I will run into issues with rubbing or whatnot, I have the eibach lowering springs which are like an inch and half I think. Offset of these wheels are 30. Also what size tire? 215/34 or 225/40? Not really sure what would be best.
1 - 20 of 153 Posts
