1 - 20 of 71 Posts
Camry LE ('00 & '09)
Discussion Starter #1 (Edited by Moderator)
I am modeling this after the thread in the 5/6th generation forums made by hardtopte72 (much will be plagiarized straight from that thread). Imitation is the sincerest form of flattery, right?!?!
Let’s keep the thread chat to a minimum, as much of the stuff here is open for debate on what is “best”. I’m not going to pass judgement on “best”, rather make a list of what is available. Discussion of “best” should be pursued in another thread.
There are 3 sections (in this order): Filters, Fluids, Parts. Sections are organized as Bold/Underline is major heading, Underline is usually Brand, and Italics is usually Product of the Brand.
Disclaimer: Myself or Toyotanation are not liable for any damage or injury that may result from use of this guide. Vehicles should be diagnosed, maintained, and repaired by qualified technicians. Use this guide at your own riski.
Note: For the US market in the Camry, the 5SFE is the 4 cylinder used from 1992-2001, the 3VZFE is the V6 used from 1992-1993, and 1MZFE is the V6 used from 1994-2001. Other markets may use different engines, like the Australian market which switched from the 3VZFE to the 1MZ in 1997. For the Solara, the 5SFE is the 4 cylinder used from 1999-2001, the 2AZFE is the 4 cylinder used from 2002-2003, and the 1MZFE is the V6 used from 1999-2003.
The Camry and Solara Generations are as follows:
1992-1996 Camry is Gen 3, which included a new V6 for 1994 model year and a facelift for the 1995 model year
1997-2001 Camry is Gen 4, which included revised engines from the Gen 3 and a facelift for the 2000 model year
1999-2003 Solara is Gen 1, which included the revised engines from the Gen 4 and an all new I4 engine and facelift for the 2002 model year
Oil Filters:
When doing an oil change, it is HIGHLY ADVISABLE to replace the oil pan drain plug gasket/crush washer. These can be purchased from Toyota, eBay, or Amazon from around 50 cents to 1 dollar each. I buy mine in packs of 10 for $5.50 shipped on eBay.
Part number: 90430-12031
Oil filters are an important part of the overall maintenance of your car. All filters are not created equal and filtering is not a job for the cheap. There are several acceptable oil filters available for the 3rd and 4th Gen Camry. I will describe most of them below and cite whatever references I can. I would recommend switching from the stock filter size to the oversize, as it is not much larger but provides more filtration surface. I’m unsure if using the V6 filter is recommended, although it fits it may drain due to the inverted placement on the I4, use at your own discretion and report back.
Oil filter terms:
OCI- oil change interval
ADBV- anti-drainback valve
Purolator: Purolator makes three different oil filters in their self named line. A standard "Premium Protection" filter, higher quality "Advanced Protection" filter, and synthetic oil "Maximum Protection" filter.
Purolator: Is the lower line filter. It is advertised with a 96.5 efficiency rating at 20 microns, 13g of "dirt holding" capacity and 5,000 mile oil change interval. It uses a rubber ADBV and paper/fiber media
5SFE Stock: L14476
5SFE Oversize/2AZFE: L14477
3VZFE/1MZFE V6: L10241
Taurus Upsize: L20195
PurolatorOne: Is the next in line filter. It is advertised with a 99% efficiency rating at 20 microns, 15g of "dirt holding" capacity and 10,000 mile oil change interval. It uses a silicone ADBV and paper/synthetic blend media.
5SFE Stock: PL14476
5SFE Oversize/2AZFE: PL14477
3VZFE/1MZFE V6: PL10241
Taurus Upsize: PL20195
Purolator Boss: Is the top of the line filter. It is advertised with a 99+ % efficiency rating at 20 microns, 27g of "dirt holding" capacity and 15,000 mile oil change interval with synthetic oils. It uses a silicone ADBV and a full synthetic media.
5SFE Stock: PBL14476
5SFE Oversize/2AZFE: PBL14477
3VZFE/1MZFE V6: PBL10241
Taurus Upsize: PBL20195
Bosch: These filters are made by Purolator ever since their merger. Two filters are offered in line with Purolator.
Bosch Premium: In line with a Purolator classic. Nearly identical in every way.
5SFE Stock: 3311
5SFE Oversize/2AZFE: 3325
3VZFE/1MZFE V6: 3330
Taurus Upsize: 3422
Bosch DistancePlus: This filter is basically a Purolator PureOne with a larger case and filter area to hold more particles. It is rated 99% at 20 microns. This filter has been shown to be good to a 15K mile OCI. It does not feature a rough texture finish.
5SFE Stock: D3311
5SFE Oversize/2AZFE: D3325
3VZFE/1MZFE V6: D3330
Taurus Upsize: D3422
Wix: Wix makes a very high quality line of filters. They also make the Napa brand filter.
Wix: High quality construct, silicone ADBV, and a tough case make this a good filter. 99% at 25 microns efficiency.
5SFE Stock: 51394
5SFE Oversize/2AZFE: 57145 or 51396
3VZFE/1MZFE V6: 51348
Taurus Upsize: 51516
Napa: All but recent Pro-Select are Wix made filters that expand on the line. Available in Pro-Select, Silver, and Gold (I don't see a Platinum listing). Which denote their place in the line. Pro-select is the low line, gold has top level features (more pleats, better filtering, etc.).
Pro-Select: This is a low line filter which recently appears to made on a contract basis (still likely Wix/Affinia). These use a controversial combo valve ADBV.
5SFE Stock: SFI 21394
5SFE Oversize/2AZFE: SFI 27145
3VZFE/1MZFE V6: SFI 21348
Taurus Upsize: SFI 21516
Silver: This is the mid level Wix made filter. Great filter for the money. Comparable to a Purolator Classic.
5SFE Stock: SFL 31394
5SFE Oversize/2AZFE: SFL 37145
3VZFE/1MZFE V6: FIL 31348
Taurus Upsize: SFL 31516
Nascar Select: This is their supposedly soon to be discontinued specialty line of filters. Features a unique "Spin-Flow" technology and a synthetic media. Claims to have some of the highest single pass efficiency in the industry.
From Napa "In traditional oil filters, unfiltered oil is forced under pressure through holes in the filter base plate directly to the top of the canister, creating turbulence in the filter. This constant turbulence concentrates the filtration of the dirty oil at one end of the filter media, resulting in only about 60 percent of the filter media doing the majority of the work.
The Spin-Flow technology, developed by Wix Filtration and used exclusively by NAPA for automotive applications, uses a ring of angled fins to force the dirty oil to flow in a circular motion around the filter media. This process evens out the flow of the dirty oil and virtually eliminates turbulence, thus using the entire filter media and maximizing the capacity and efficiency of the filter." "In addition to Spin-Flow technology, the NASCAR Select filter also features a newly designed filter media, combining cellulose with synthetic fibers. This new media, called T-52, was also developed by Wix Filtration for NAPA automotive use. T-52 greatly increases the filter's "Single-Pass Efficiency," which is a measure of how much of the oil's contaminates are removed in a single trip through the filter. NASCAR Select has one of the highest Single-Pass Efficiency ratings in the industry. "
5SFE Stock: NFI 91394
5SFE Oversize/2AZFE: NFI 91396
Taurus Upsize: NFI 91348
Gold: This is a top level filter. All the features you expect from a top level filter.
5SFE Stock: FIL 1394
5SFE Oversize/2AZFE: FIL 7145
3VZFE/1MZFE V6: FIL 1348
Taurus Upsize: FIL 1516
Platinum: This is their top of the line oil filter. This filter is specified specifically to be used with synthetic oil for extended drain intervals 10,000 miles or above. Tons of capacity at the expense of filtering ability.
5SFE Stock: PFL 41394
5SFE Oversize/2AZFE: PFL 47145
3VZFE/1MZFE V6: PFL 41348
Taurus Upsize: PFL 41516
Wix XP: Some say this is the same as the Napa Platinum. Some also say the data shows this filter has a terrible efficiency rating at 20 microns (50%). Regardless, Wix considers it their premium filter. It uses a wire backed synthetic media and is recommended for longer drain intervals on synthetic oil.
5SFE Stock: 51394XP
5SFE Oversize/2AZFE: 57145XP
3VZFE/1MZFE V6: 51348XP
Taurus Upsize: 51516XP
Mobil 1 and K&N: Great filters at a hefty price. These are 20 micron 99% filters made by Champion Labs. They feature all of the top of the line features you would expect from only the best. The K&N features a welded nut to aid in removal.
Mobil 1 Part Numbers:
5SFE Stock: M1-103
3VZFE/1MZFE V6: M1-102
Taurus Upsize: M1-209
K&N Part Numbers:
5SFE Stock: HP-1003
3VZFE/1MZFE V6: HP-1002
Taurus Upsize: HP-2009
Denso: Denso makes the OEM Oil filter for these cars. It is made in several places. In spin-on form this is one of the most peculiar designed oil filters available. It features no end caps, rubber ADBV, and generally poor construction similar to a OCOD fram, though tests have shown them very reliable and generally having a filter media with a larger surface area than the competition..
Available in three to four sizes depending on whether buying from Toyota or Denso directly.
5SFE Stock: 90915-YZZF2/150-1000
5SFE Oversize/2AZFE: 90915-YZZF1/150-1001
3VZFE/1MZFE V6: 90915-YZZG1/90915-YZZD1(older version)/150-1002
UZ V8 Upsize: 90915-YZZD3/150-1003
Fram: All but one of Fram's filters (The Ultra/Extended Guard) is complete garbage. The others use cardboard end caps and are generally poorly constructed. Cheap is their only good quality.
Ultra/Extended Guard: The Ultra/Extended Guard is a good quality and very robust filter right in the middle of the high quality pack. It uses a double pleat synthetic media and is designed for a 10K OCI. It's 97% efficiency rated at 20 microns. There appears to be a difference between the Ultra and Extended Guard though they use the same part number. The Ultra is the updated version that replaces the Extended Guard. Updates with the Ultra include a 15K OCI, 99% at 20 microns efficiency rating, and an awesome looking metal supported dual synthetic layer media. This new Fram Ultra filter appears to be the best filter ever made by Fram and right at the top level of oil filters. If it shows to be reliable, there isn't a filter available that offers more. Expect it to be a little pricy compared to other quality filters like the PureOne but considering it offers a 15K interval, it may be a bargain.
5SFE Stock: XG4967
3VZFE/1MZFE V6: XG3614
Taurus Upsize: XG3600
Those are the bulk of it. Most other oil filters are made by the above listed companies under other names (Motorcraft is Purolator, A/C Delco is a lower level Champion Labs, Carquest made by Wix).
Engine Air Filters:
Air filters are shown to be directly responsible for oil condition. There are a few available here as well. I will only discuss the OEM filter as I am a firm believer that cold air intakes are detrimental to filtering as most cone filters available filter worse than factory (and therefore flow more).
Denso: This is by far the best quality filter available. Featuring a 3 layer element to filter small, medium, and large particles and a perfect fit this filter is the best of the bunch.
Gen 3 and Gen 4 Camry and Gen 1 Solara (All Engines): 17801-03010/1432081
The rest of the filters either are of worse quality or mimic the denso without the 3 layer filtering.
Purolator:
Gen 3 and Gen 4 Camry and Gen 1 Solara (All Engines): PA24690
K&N:
Gen 3 and Gen 4 Camry and Gen 1 Solara (All Engines): 33-2145-1
Wix:
Gen 3 and Gen 4 Camry and Gen 1 Solara (All Engines): 46017
Fram:
Gen 3 and Gen 4 Camry and Gen 1 Solara (All Engines): TGA7351
Fuel Filters:
Fuel filters are an important part of overall maintenance. While Toyota specifies either no interval or 60K, the vast majority of vehicles, still use original filters. Replacement is not too hard and once you see inside of one, you will see the benefit to replacement.
OEM Toyota:
Camry
Gen 3:
1992-1994 5SFE/3VZFE/1MZFE - 23300-79305
1995-1996 5SFE/1MZFE - 23300-29045
Gen 4:
1997-2001 5SFE and 1997 1MZFE w/Banjo Fuel Fitting- 23300-79545
1998-2001 1MZFE w/Quick Disconnect Fuel Fitting - 23300-20040
Solara
Gen 1:
1997-2001 5SFE w/Banjo Fuel Fitting- 23300-79545
1999-2003 1MZFE w/Quick Disconnect Fuel Fitting - 23300-20040
Wix:
Gen 3:
1992-1994 5SFE/3VZFE/1MZFE - 33665
1995-1996 5SFE/1MZFE - 33664
Gen 4:
1997-2001 5SFE and 1997 1MZFE w/Banjo Fuel Fitting - 33502
1998-2001 1MZFE w/Quick Disconnect Fuel Fitting - 33581
Solara
Gen 1:
1997-2001 5SFE w/Banjo Fuel Fitting - 33502
1999-2003 1MZFE w/Quick Disconnect Fuel Fitting - 33581
Fram:
Gen 3:
1992-1994 5SFE/3VZFE/1MZFE - G7766
1995-1996 5SFE/1MZFE - G7767
Gen 4:
1997-2001 5SFE and 1997 1MZFE w/Banjo Fuel Fitting - G7767
1998-2001 1MZFE w/Quick Disconnect Fuel Fitting - G8207
Solara
Gen 1:
1997-2001 5SFE w/Banjo Fuel Fitting - G7767
1999-2003 1MZFE w/Quick Disconnect Fuel Fitting - G8207
Purolator:
Gen 3:
1992-1994 5SFE/3VZFE/1MZFE - F44825
1995-1996 5SFE/1MZFE - F45068
Gen 4:
1997-2001 5SFE and 1997 1MZFE w/Banjo Fuel Fitting - F45068
1998-2001 1MZFE w/Quick Disconnect Fuel Fitting - F55287
Solara
Gen 1:
1997-2001 5SFE w/Banjo Fuel Fitting - F45068
1999-2003 1MZFE w/Quick Disconnect Fuel Fitting - F55287
Beck/Arnley:
Gen 3:
1992-1994 5SFE/3VZFE/1MZFE - 0430970
1995-1996 5SFE/1MZFE - 0431007
Gen 4:
1997-2001 5SFE and 1997 1MZFE w/Banjo Fuel Fitting - 0431007
1998-2001 1MZFE w/Quick Disconnect Fuel Fitting - 0431020
Solara
Gen 1:
1997-2001 5SFE w/Banjo Fuel Fitting - 0431007
1999-2003 1MZFE w/Quick Disconnect Fuel Fitting - 0431020
Transmission Filters:
These transmission uses a screen type filter element. While they are not known to clog, they could still stand to be replaced at reasonable intervals (say 100K miles) as an additional part of good fluid maintenance.
OEM Toyota:
Filter -
Camry
Gen 3:
1992-1996 A140E 5SFE: 35330-32022
1992-1993 A540E 3VZFE: 35330-32031
1994-1996 A541E 1MZFE: 35330-33030
Gen 4:
1997-2001 A140E 5SFE: 35330-32022
1997-2001 A541E 1MZFE: 35330-33030
Solara
Gen 1:
1999-2001 A140E 5SFE: 35330-32022
1999-2003 A541E 1MZFE: 35330-33030
Gasket -
Camry
Gen 3:
1992-1996 A140E 5SFE: 35168-32010
1992-1993 A540E 3VZFE: 35168-33020
1994-1996 A541E 1MZFE: 35168-33031
Gen 4:
1997-2001 A140E 5SFE: 35168-32010
1997-2001 A541E 1MZFE: 35168-33030
Solara
Gen 1:
1999-2001 A140E 5SFE: 35168-32010
1999-2003 A541E 1MZFE: 35168-33030
Wix: Filter Kit
Camry
Gen 3:
1992-1996 A140E 5SFE: 58994
1992-1993 A540E 3VZFE: 58888
1994-1996 A541E 1MZFE: 58614
Gen 4:
1997-2001 A140E 5SFE: 58994
1997-2001 A541E 1MZFE: 58614
Solara
Gen 1:
1999-2001 A140E 5SFE: 58994
1999-2003 A541E 1MZFE: 58614
Fram: Filter Kit
Camry
Gen 3:
1992-1996 A140E 5SFE: FT1169A
1992-1993 A540E 3VZFE: FT1142
1994-1996 A541E 1MZFE: FT1996
Gen 4:
1997-2001 A140E 5SFE: FT1169A
1997-2001 A541E 1MZFE: FT1196
Solara
Gen 1:
1999-2001 A140E 5SFE: FT1169A
1999-2003 A541E 1MZFE: FT1196
Purolator: Filter Kit
Camry
Gen 3:
1992-1996 A140E 5SFE: P1231
1992-1993 A540E 3VZFE: P1228
1994-1996 A541E 1MZFE: P1245
Gen 4:
1997-2001 A140E 5SFE: P1231
1997-2001 A541E 1MZFE: P1245
Solara
Gen 1:
1999-2001 A140E 5SFE: P1231
1999-2003 A541E 1MZFE: P1245
Beck/Arnley: Filter Kit
Camry
Gen 3:
1992-1996 A140E 5SFE: 0440246
1992-1993 A540E 3VZFE: 0440219
1994-1996 A541E 1MZFE: 0440280
Gen 4:
1997-2001 A140E 5SFE: 0440246
1997-2001 A541E 1MZFE: 0440280
Solara
Gen 1:
1999-2001 A140E 5SFE: 0440246
1999-2003 A541E 1MZFE: 0440280
Engine Oil:
The life blood of the engine. Synthetic oil is recommended for better wear protection, extended intervals, fuel economy, and startability. The decision of what kind of oil you run can make the difference between an oil burner, 200K miles, or your fuel economy. Not all oils are created equal. Running synthetic oil and changing at 3K is a waste of money. These oils are proven to go up to 15K miles between oil changes!
Take a look at these links before you decide what weight of oil to use.
http://www.bobistheoilguy.com/motor-oil-101/
http://www.zddplus.com/TechBrief13 - Oil Viscosity.pdf
http://www.lubricheck.com/demo/home/resources
Mobil 1: Oils are of excellent quality. TGMO (Toyota Genuine Motor Oil) is Mobil 1 oil with a special formulation. I will describe the synthetic lines.
Mobil 1 is grouped into 6 basic types of synthetic. Mobil 1 Annual Protection, Mobil 1, Mobil 1 Extended Performance, Mobil 1 Advanced Fuel Economy, Mobil 1 High Mileage, and Mobil 1 Emission System Protection.
The Mobil 1 oil is has shown to be a high quality oil for all engines. It is available from 0W40, 5W20, 5W30, 10W30, and 15W50.
Mobil 1 Advanced Fuel Economy: Is a great oil as well shown to be superior in quality to the Mobil 1 on a few occasions. It is available only a 0W20 or 0W30. This oil has all the benefits of the 5W20 or 5W30 oil respectively but offers cold weather operation and reduces cold start wear. This is the oil I used to run in all of my cars.
Mobil 1 Annual Protection: A higher end oil from Mobil 1. It is designed to be used for extended drains of up to 20K miles or 1 year. Available in 0W20, 5W20, and 5W30.
Mobil 1 Emission System Performance: A newer oil which is specifically engineered for modern diesel and gasoline engines with emission systems components like modern diesel particulate filters and catalytic converters in mind. Available in 0W30 and 5W30.
Mobil 1 Extended Performance: A higher end oil from Mobil 1. It is designed to be used for extended drains of up to 15K miles. Available in 0W20, 5W20, 5W30, and 10W30.
Mobil 1 High Mileage: For use in vehicles with over 75K miles. Has more seal conditioners, anti-wear additives, and detergents than other Mobil 1 oils. Available as a 5W30, 10W30, and 10W40.
Product data sheets:
M1 AFE 0W20: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-20_Advanced_Fuel_Economy.aspx
M1 AFE 0W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-30_Advanced_Fuel_Economy.aspx
M1 AP 0W20, 5W20, 5W30: https://www.mobil.com/English-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-Annual-Protection
M1 0W40: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx
M1 5W20: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_5W-20.aspx
M1 5W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_5W-30.aspx
M1 10W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_10W-30.aspx
M1 15W50: http://www.mobil.com/USA-English/Lubes/PDS/NAUSENPVLMOMobil1_15W-50.aspx
M1 ESP 0W30: http://www.mobil.com/english-US/Passenger-Vehicle-Lube/pds/NAXXMobil-1-ESP-X1-0W30
M1 ESP 5W30: http://www.mobil.com/english-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-ESP-Formula-5W30
M1 EP 0W20, 5W20, 5W30, 10W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Extended_Performance.aspx
M1 HM 5w30: http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
M1 HM 10W30: http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
M1 HM 10W40: http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
Pennzoil Platinum: Pennzoil's line of synthetic motor oil. The newest formulations are made from compressed natural gas, and are some of the cleanest oils available today. These oils, like many others, are made by SOPUS.
Pennzoil Platinum is now grouped into 3 basic types of synthetic oils: Pennzoil Platinum, Pennzoil Platinum High Mileage, and Pennzoil Ultra Platinum.
Pennzoil Ultra Platinum: Even better than Pennzoil Platinum. Claims to be 25% cleaner than Mobil 1, 35% cleaner than Valvoline SynPower, and 40% Cleaner than Castrol Edge with Syntec. Available in 0W-20, 0W40, 5W-20, 5W-30, and 10W-30.
Pennzoil Platinum: It is dubbed as one of the cleanest oils claiming to be 8% cleaner than Mobil 1, 17% Cleaner than Valvoline, and 20% Cleaner than Castrol. This is supposed to be a great oil for cleaning out your engine of varnish.
This oil comes in 4 basic sub-types: US, Euro, Euro Diesel, and Racing. The Euro diesel is specifically engineered for European diesel engines and includes:
Euro L: For gasoline engines or DPF (Diesel Particulate Filter) equipped diesel engines. Is ACEA C3 and Dexos approved.
Euro LX: Thinner variant of the Euro L that is ACEA C2/C3 approved.
Euro AV: Specifically engineered for high performance and TDI diesel engines. It has surpassed the requirements for VW and Peugot in house testing.
US is available in 0W-20, 5W-20, 5W-30, and 10W-30.
Euro is available in 0W30, 5W30, and 5W40
Euro L is available in 5W30
Euro LX is available in 0W30
Euro AV is available in 5W30
Racing is available in 10W60
Pennzoil Platinum High Mileage: For use in vehicles with over 75K miles. Has more seal conditioners, anti-wear additives, and detergents than other Pennzoil Platinum oils. This has become the go to oil for my fleet. Available in 5W20 and 5W30.
Pennzoil Ultra Platinum 0W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058458374/a315706a73d123b58828855fb6994dfc8a4dd3924dd8c4c4528632e56fb447db/Pennzoil-Ultra-Platinum-0W-20.pdf
Pennzoil Ultra Platinum 0W40: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058459415/cbaf42eae4dcbcd08bee4f669a8ee71a73584bf793056ec459c9cdd99445c116/Pennzoil-Ultra-Platinum-0W-40.pdf
Pennzoil Ultra Platinum 5W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058460104/c75c1494cc249bacf05b4f2da5c205b59d8dd8bd052c1e33e0d4b87161df05f9/Pennzoil-Ultra-Platinum-5W-20.pdf
Pennzoil Ultra Platinum 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058460926/206444cb877e3961f436c35ca2fb4560ebc862ecd9e5be9cb14fa15e88aa7517/Pennzoil-Ultra-Platinum-5W-30.pdf
Pennzoil Ultra Platinum 10W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058460214/9134574b6083111b75591aa2e70f66f34897b6029b7ff22cd4fe1b8de9116153/Pennzoil-Ultra-Platinum-10W-30.pdf
Pennzoil Platinum US 0W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058452796/ed3e433f9944b98910d0992a166dabefe5bb9422ae327a1253133dd2c60e751d/Pennzoil-Platinum-SAE-0W-20-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum US 5W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058454670/051b99d9a2e384330f91c740627502eb6b50a31ff803a838cd360f2efaa05fb5/Pennzoil-Platinum-SAE-5W-20-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum US 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058453075/73d957b370df2e49693e82ece9a0a5bb2f048868be34afadaf2c488ca81a57a5/Pennzoil-Platinum-SAE-5W-30-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum US 10W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058453505/81fce27fbfd53df17f24ef87c5723be40524d3e444f413ad35ccb21b7a4db077/Pennzoil-Platinum-SAE-10W-30-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum Euro 0W40: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815774/9f159ce8e902186deb64de107a2ec7b145e2a590d58d67c61e9d5399c1d875ee/Pennzoil_Platinum_Euro_SAE_0W-40_Full_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815731/33fd0db5f1226a42250ae0173f226ec995ccb5b1fb918d5f42a0f90ca641e61d/Pennzoil_Platinum_Euro_5W-30.pdf
Pennzoil Platinum Euro 5W40: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815565/a70e5779bc5c118d413f463890e816788dbfa1e92705df46265999796dfa4bb5/Platinum_Euro_SAE_5W-40_Full_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro L 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815811/38dd048487367f3433017e5a97b45db965c1328c7aad05e4399ee75a60ad9958/Platinum_Euro_L_SAE_5W-30_Fully_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro LX 0W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815640/df24ad43161f07dd0f6d2b935a6b483df556854b85d6a6790c36facdbaa99ca7/Platinum_Euro_LX_SAE_0W-30_Fully_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro AV 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461707990494/2dc7a607b7a293a77794d06f3de890f6addc2931b97929d71eeb8d37c7c8ce46/Pennzoil-Euro-AV-SAE-5W-30.pdf
Pennzoil Platinum Racing 10W60: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461707989149/7142e42ade7f0e7917afd2c5b927da5ec07217b29d873f0a41be498550c2dfc1/Pennzoil-Platinum-Racing-10W-60.pdf
Pennzoil Platinum High Mileage 5W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/platinum-high-mileage/_jcr_content/productDetails.stream/1460058451538/353b0b70a22379d806d88d91afe221542ce985556329f0d22f2ea5ae38374342/Pennzoil-Platinum-High-Mileage-SAE-5W-20-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum High Mileage 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/platinum-high-mileage/_jcr_content/productDetails.stream/1460058451820/c138f531548b65034bf93a6adb326d18e97cd458da7956caf5bae4bc9eb917a6/Pennzoil-Platinum-High-Mileage-SAE-5W-30-Full-Synthetic-Motor-Oil.pdf
Quaker State: Another high quality oil made by SOPUS.
Ultimate Durability: Some say this stuff is the same as Pennzoil Platinum in certain grades, while some say it's slightly different with a slight edge for the Platinum. The oil is marketed as highly durable with superior anti-wear properties. Available in the same grades as Pennzoil Platinum 0W20, 5W20, 5W30, 10W30, and 5W50.
Product Data Sheet: http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140003587117_201007020129.pdf
Valvoline: Another highly touted oil.
Syn-Power: Available in 0W20, 5W20, 5W30, 5W40, 10W30, and 20W50.
Product sheet here:http://www.valvoline.com/pdf/synpower.pdf
Castrol: Some say this a synthetic blend while some say its full synthetic. Nonetheless a very popular oil.
Edge with Syntec: Available in 0W20, 0W30, 5W20, 5W30, 5W40, 5W50, 10W30, and 10W40.
Product Data Sheet here: http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/Edge_BLACK_PDS_Sept_2011.pdf
Amsoil: Touted often as the absolute best and only oil that should be used. This oil is high quality from my research but the price, distribution network, and only me attitude make it an outcast.
Amsoil Signature Series: Available in 0W20, 0W30, 5W20, 5W30, and 10W30.
0W20: http://www.amsoil.com/storefront/asm.aspx
0W30: http://www.amsoil.com/storefront/azo.aspx
5W20: http://www.amsoil.com/storefront/alm.aspx
5W30: http://www.amsoil.com/storefront/asl.aspx
10W30: http://www.amsoil.com/storefront/atm.aspx
Royal Purple: Yet another high quality synthetic oil. Available more places than Amsoil, this oil has a loyal following of hard core enthusiasts.
HPS: Available in 0W-20, 0W-40, 5W-20, 5W-30, 5W-40, 10W-30, 10W-40, 15W-40 and 20W-50.
Product explanation sheet: http://www.royalpurpleconsumer.com/wp-content/uploads/PS_API_MotorOIl.pdf
Antifreeze/Coolant:
Coolant brings about more arguments than any fluid except maybe motor oil. The only real requirement is that the coolant be a P-HOAT (Phosphated Hybrid Organic Acid Technology) coolant that does not contain 2EHA (Dexcool or Dexclones), silicates, amines, or borates. I am an avid user of Toyota Pink and Zerex Asian Vehicle coolant. Other highly recommended coolants include Toyota Red Concentrate, Honda Type 2 (Honda Blue), Pentofrost A1 (Red), Pentofrost A2 (Green), Pentofrost A3 (Blue), Pentofrost A4 (Pink), Beck/Arnley Premium Extended Life Pink, Beck/Arnley Premium OE Extended Life Blue, Beck/Arnley Premium OE Red Concentrate, Beck/Arnley Premium OE Green Concentrate, Reochem OEM Premium Extended Life Red, Reochem OEM Premium Extended Life Pink, Reochem OEM Premium Extended Life Blue, and many other OEM coolants. Replace every 60-80K.
Note: With Pentofrost and Beck/Arnley, the only real differences between each of their individual coolants is the color, as the specs are identical between them.
Here are some data sheets/MSDS sheets:
Toyota/Aisin: Toyota and Aisin coolants are exactly the same product.
Super Long Life Coolant (Pink) - http://www.worldpac.com/tagged/Antifreeze-Coolant_00272SLLC2.pdf
Long Life Coolant (Red) - http://www.worldpac.com/tagged/Antifreeze-Coolant_002721LLAC.pdf
Aisin Super Long Life Pink - http://aisinaftermarket.com/uploads/4jetto45_AISIN_ANTIFREEZE_COOLANT_FEATURES_AND_BENEFITS_.pdf
Honda:
Type 2 (Honda Blue) - http://www.worldpac.com/tagged/Coolant_-_Honda.pdf
Zerex:
Asian Vehicle Formula - http://www.valvoline.com/pdf/zerex_asian_vehicle.pdf
Pentosin Pentofrost:
A1 (Red) - http://www.pentosin.net/specsheets/Pentofrost_spec_A1.pdf
A2 (Green) - http://www.pentosin.net/specsheets/Pentofrost_spec_A2.pdf
A3 (Blue) - http://www.pentosin.net/specsheets/Antifreeze_Pentofrost A3_Aug13.pdf
A4 (Pink) - http://www.pentosin.net/specsheets/Antifreeze_Pentofrost A4_Aug13.pdf
Beck/Arnley:
Extended Life Blue and Extended Life Pink - http://customerportal.fmpco.com/fmpnext/pdf/252-1501U Blue Coolant.pdf
Red Concentrate - http://www.maxmarketing.com/beckarnley/AC_Red_Chemical_Product_Data_Sheet NEW.pdf
Green Concentrate - http://www.maxmarketing.com/beckarnley/AC_Green_Chemical_Product_Data_Sheet.pdf
Reochem OEM Premium:
Extended Life Red - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_RED_86-374ROEM_R.pdf
Extended Life Pink - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_PINK_86-174POEM.pdf
Extended Life Blue - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_BLUE_86-174BOEM_B.pdf
Extended Life Green - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_GREEN_86-374GROEM.pdf
Transmission Fluid for A/T:
Another hot topic. Original specification is for Dexron II or Dexron III depending on the year. All these specifications have moved towards Dexron III. I (HardtopTE72) have personally used the newer more modern synthetic Valvoline Maxlife in these older transmissions. Any fluid that meets Dexron III specification will work just fine. In general transmission fluids can be thinner in viscosity than the original (and likely outdated) fluid but not the other way around. Dexron VI which is around a 5 cSt fluid replaces all Dexron applications including the 7+ cSt Dexron II spec. While fluids like Maxlife and Dexron VI are initially thinner, they are also vastly superior. One of the main benefits is that they are more shear stable. Meaning while they start thinner, they stay relaitively close in viscosity compared to conventional Dexron III or Dexron III which shears down pretty significantly. In short, newer and thinner fluid works fine.
Castrol:
Castrol TransMax Full Synthetic Multi-Vehicle ATF: Meets the requirements for Dexron III. Fully synthetic fluid which is likely a response to Valvoline Maxlife Dex/Merc as a low viscosity modern ATF. It likely also works for WS but doesn't directly say so (says recommended for all Toyota transmissions).
Product Data sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/09DFBB064CCF193E80257BA5006EB93F/$File/BPXE-99LBRT.pdf
Castrol Import TransMax Multi-Vehicle: Meets the requirements for Dexron III. Also a synthetic blend. Replace it every 30K.
Product Data sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4B94307E61A0AF6480257ADD007535BA/$File/Transmax Import MV PDS.pdf
Castrol TransMax High Mileage Multi-Vehicle ATF: Meets the requirements for Dexron III. A high mileage fluid that claims to have additional seal conditioners and cleaning agents for higher mileage transmissions. Likely a synthetic blend.
Product Data sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/99010A169D77FF8C802579A200456CFB/$File/Castrol Transmax High Mileage PDS Am.pdf
Valvoline:
Valvoline MaxLife Dex/Merc: Fully synthetic, highly recommended and highly rated. This ATF is recommended even in WS transmissions and is my go to fluid for any Toyota transmission service.
http://www.valvoline.com/pdf/maxlife_atf.pdf
Valvoline Import Multi-Vehicle ATF: Now similar in formulation to Castrol Import Multi-Vehicle ATF with around a 1 cSt lower viscosity (6.9 vs 8). Fully synthetic fluid still and likely a good alternative to the Castrol Import which is more easily found in quart bottles. This fluid is sold at lots of places in the 1 gallon bottles. Highly recommended.
Product Data Sheet: http://www.valvoline.com/pdf/multi_vehicle_atf.pdf
Redline:
D4 ATF: Very highly rated boutique ATF that meets the requirements for Dexron III. I haven't found a single negative review on this stuff. However don't be confused. This ATF is comparatively very expensive (2-3 times the cost of Valvoline Maxlife per gallon).
Product Data Sheet: http://www.redlineoil.com/content/files/tech/ATF PDS 2-10.pdf
Amsoil:
Signature Series Multi-Vehicle Synthetic ATF: Very highly rated boutique ATF that meets the requirements for Dexron III. I haven't found a single negative review on this stuff either. However don't be confused. Like Redline, this ATF is comparatively very expensive (2-3 times the cost of Valvoline Maxlife per gallon).
Product Data Sheet: http://www.amsoil.com/lit/databulletins/g3110.pdf
Mobil 1:
Mobil 1 Synthetic ATF: A highly recommended (and kind of expensive) fully synthetic Dexron III ATF.
Product Data Sheet: http://catalog.mooreballiewoil.com/asset/pds13.pdf
Gear Oil for M/T:
Most agree on a few good oils. Toyota manual tranmissions need to have a GL4 oil to prevent damage to the yellow metal inside the transmission. Synthetic gear oil is amazing and works great in the cold for smooth buttery shifts. Replace all every 30K.
Redline MT90: My favorite. Available on Amazon or from Redline for about 13 bucks a quart.
Product Data sheet: http://www.redlineoil.com/product.aspx?pid=46&pcid=7
Amsoil Synthetic Manual Transmission oil: Another highly recommended yellow metal safe oil.
Product data sheet: http://www.amsoil.com/storefront/mtg.aspx
Royal Purple Max Gear: Well recommended, yellow metal safe oil.
Description sheet: http://royalpurpleconsumer.com/product-categories/automotive/#!max-gear
Mobil, Valvoline, and Castrol do not specify or list a GL4 compatibile gear oil.
Power Steering Fluid:
Replace every 2-3 years. The power steering requires any Dexron compatible ATF as opposed to the clear generic stuff. I prefer to use Valvoline Maxlife or Castrol Transmax. You can however use any Dexron compatible ATF you wish (I have even used Toyota T-IV with great results).
Brake Fluid:
Replace every 2-3 years. I prefer to use any available synthetic DOT 3 or DOT4 fluid I can find at the auto parts store such as Wearever, Prestone, or Valvoline. Other high quality "boutique" fluids like Motul or other name brands may not be worth the cost for a daily driven car.
Spark Plugs:
Spark plugs on these engines are recommended every 60-90K if using OEM equivalent plugs. The Gen 4 uses a "Waste-Spark" system and came standard with Double Platinum/Twin-Tip Spark Plugs. The Gen 3 uses either an individual COP or Distributor and as such has the option to use the Iridium Long Life plugs. The Iridium Long Life are better in every way compared to their Platinum counterparts. I prefer Denso plugs as they are what comes factory on most Toyotas (NGK to a lesser degree). I have installed NGK on several cars and had no issues. Plug gap for a 5SFE and 1MZFE is .44 while the plug gap for the 3VZFE is .32. The general consensus is you don't gap Iridium or Double Platinum Plugs as they come pregapped. My preference would be the Denso Iridium Twin-Tip for Gen 3 and 4 or NGK Laser Platinum for Gen 4 only. The 2AZFE powered Solara is recommended to use Iridium only.
NGK:
Copper:
Gen 3 Camry 5SFE: PN: BKR6E11. SN: 2756
Gen 3 Camry 3VZFE: PN: BCPR6E11. SN: 5632
Gen 3 Camry 1MZFE: PN: BKR6E11. SN: 2756
Gen 4 Camry and Gen 1 Solara 5SFE: PN: BKR6EYA. SN: 7990
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: BKR6EYA. SN: 7990
Platinum:
Gen 3 Camry 5SFE: PN: BKR6EGP. SN: 7092
Gen 3 Camry 3VZFE: PN: BCPR6EGP. SN: 7088
Gen 3 Camry 1MZFE: PN: BKR6EGP. SN: 7092
Gen 4 Camry and Gen 1 Solara 5SFE: PN: BKR6EGP. SN: 7092
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: BKR6EGP. SN: 7092
Laser Platinum:
Gen 3 Camry 5SFE: PN: BKR6EP11. SN: 2978
Gen 3 Camry 3VZFE: PN: BCPR6EP11. SN: 3350
Gen 3 Camry 1MZFE: PN: BKR6EP11. SN: 2978
Gen 4 Camry and Gen 1 Solara 5SFE: PN: BKR6EKPB11. SN: 3452
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: BKR6EKPB11. SN: 3452
NGK Iridium IX:
Gen 3 Camry 5SFE: PN: BKR6EIX11. SN: 3764
Gen 3 Camry 3VZFE: PN: BCPR6EIX11. SN: 4919
Gen 3 Camry 1MZFE: PN: BKR6EIX11. SN: 3764
Gen 4 Camry and Gen 1 Solara 5SFE: PN: BKR6EIX11. SN: 3764
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: BKR6EIX11. SN: 3764
Gen 1 Solara 2AZFE: PN: BKR6EIX11. SN: 3764
NGK Laser Iridium: Great plugs. The "A" plugs and "T" plugs are the same plugs, with the "A" being dealer only.
Gen 3 5SFE: PN: IFR6A11/IFR6T11. SN: 4589
Gen 3 1MZFE: PN: IFR6A11/IFR6T11. SN: 4589
Gen 1 Solara 2AZFE: PN: IFR6A11/IFR6T11. SN: 4589
Denso:
Copper:
Gen 3 Camry 5SFE: PN: K20R-U11. SN: 3139
Gen 3 Camry 3VZFE: PN: K16R-U. SN: 3119
Gen 3 Camry 1MZFE: PN: K20R-U11. SN: 3139
Gen 4 Camry and Gen 1 Solara 5SFE: PN: K20TR11. SN: 3195
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: K20TR11. SN: 3195
Platinum Twin Tip:
Gen 3 Camry 5SFE: PN: PK20TT. SN: 4504
Gen 3 Camry 3VZFE: PN: PK16TT. SN: 4503
Gen 3 Camry 1MZFE: PN: PK20TT. SN: 4504
Gen 4 Camry and Gen 1 Solara 5SFE: PN: PK20TT. SN: 4504
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: PK20TT. SN: 4504
Double Platinum:
Gen 3 Camry 5SFE: PN: PK20R11. SN: 3128
Gen 3 Camry 3VZFE: PN: PK16R8. SN: 3301
Gen 3 Camry 1MZFE: PN: PK20R11. SN: 3128
Gen 4 Camry and Gen 1 Solara 5SFE: PN: PK20TR11. SN: 3253
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: PK20TR11. SN: 3253
Denso Iridium Power:
Gen 3 Camry 5SFE: PN: IK20. SN: 5304
Gen 3 Camry 3VZFE: PN: IK16. SN: 5303
Gen 3 Camry 1MZFE: PN: IK20. SN: 5304
Gen 4 Camry and Gen 1 Solara 5SFE: PN: IK20. SN: 5304
Gen 4 Camry and Gen 1 Solara 1MZFE: PN: IK20. SN: 5304
Gen 1 Solara 2AZFE: PN: IK20. SN: 5304
Denso Iridium Twin-Tip:
Gen 3 Camry 5SFE: SN: 4702
Gen 3 Camry 1MZFE: SN: 4702
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 4702
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 4702
Gen 1 Solara 2AZFE: SN: 4702
Denso Iridium Long Life:
Gen 3 Camry 5SFE: PN: SK20R11. SN: 3297
Gen 3 Camry 3VZFE: PN: SK16PR-F8. SN: 3435
Gen 3 1MZFE: PN: SK20R11. SN: 3297
Gen 1 Solara 2AZFE: PN: SK20R11. SN: 3297
Bosch: I have only read one person having a positive review for these. Use at your own risk.
Copper:
Gen 3 Camry 5SFE: PN: FR7DCX. SN: 7956
Gen 3 Camry 1MZFE: PN: FR7DCX. SN: 7956
Gen 4 Camry and Gen 1 Solara 5SFE: FR8DCX. SN: 7957
Gen 4 Camry and Gen 1 Solara 1MZFE: FR8DCX. SN: 7957
Platinum:
Gen 3 Camry 5SFE: SN: 6705 or 6724
Gen 3 Camry 1MZFE: SN: 6705 or 6724
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 41801
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 41801
Double Platinum:
Gen 3 Camry 5SFE: SN: 8101
Gen 3 Camry 1MZFE: SN: 8101
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 8101
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 8101
Bosch Iridium:
Gen 3 Camry 5SFE: SN: 9603
Gen 3 Camry 1MZFE: SN: 9603
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 9603
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 9603
Gen 1 Solara 2AZFE: SN: 9603
Autolite: No reviews on these. I wouldn't use them but they are here for your review.
Copper:
Gen 3 Camry 5SFE: SN: 3923
Gen 3 Camry 3VZFE: SN: 5503
Gen 3 Camry 1MZFE: SN: 3923
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 3923
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 3923
Platinum:
Gen 3 5SFE: SN: AP3923
Gen 3 3VZFE: SN: AP5503
Gen 3 Camry 1MZFE: SN: AP3923:
Gen 4 Camry and Gen 1 Solara 5SFE: SN: AP3923
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: AP3923
Double Platinum:
Gen 3 Camry 5SFE: SN: APP3923
Gen 3 Camry 3VZFE: SN: APP5503
Gen 3 1MZFE: SN: APP3923
Gen 4 Camry and Gen 1 Solara 5SFE: SN: APP3923
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: APP3923
Autolite Xtreme Performance Iridium:
Gen 3 Camry 5SFE: SN: XP3923
Gen 3 Camry 3VZFE: SN: XP5503
Gen 3 Camry 1MZFE: SN: XP3923
Gen 4 Camry and Gen 1 Solara 5SFE: SN: XP3923
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: XP3923
Gen 1 Solara 2AZFE: XP3923
Champion: Same as Autolite:
Copper:
Gen 3 Camry 5SFE: SN: 71C2
Gen 3 Camry 1MZFE: SN: 71C2
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 318
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 318
Platinum:
Gen 3 Camry 5SFE: SN: 3071
Gen 3 Camry 1MZFE: SN: 3071
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 33182
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 33182
Double Platinum:
Gen 3 Camry 5SFE: SN: 7071
Gen 3 Camry 1MZFE: SN: 7071
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 7318
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 7318
Champion Iridium:
Gen 3 Camry 5SFE: SN: 9201
Gen 3 Camry 1MZFE: SN: 9201
Gen 4 Camry and Gen 1 Solara 5SFE: SN: 9202
Gen 4 Camry and Gen 1 Solara 1MZFE: SN: 9202
Gen 1 Solara 2AZFE: SN: 9806
Brake Pads, Shoes, and Rotors:
Not all brakes are created equal. Rotor quality and pad quality can mean the difference between squeaks or brake fade in emergencies or stop and go driving. OEM pads are low dust ceramic in the front. I highly recommend using the OEM hardware when doing a brake job.
Pads and Shoes
Note: For the Solara, Toyota made a mid year change for brakes in the 2000 model year. You need to check your build date to ensure you order the correct parts. The cut off is September, 1999 and includes changes to the rear brake pads from the 1997-1999 V6 Camry brakes, to the 2000-2001 V6 Camry brakes.
OEM Toyota: The OEM pads and shoes equipped on your vehicle. These are very high quality low dust pad usually made by either Advics or Akebono. I went over 120K miles on my OEM Toyota pads.
Front:
Camry
Gen 3:
I4: 04465-33020
V6: 04465-33060
Gen 4:
I4:
14" Wheels - 04465-33210
15" Wheels - 04465-33220
V6: 04465-33121
Solara
Gen 1:
I4 and V6: 04465-33121
Rear:
Camry
Disc:
Gen 3:
I4 and V6: 04466-32050
Gen 4:
V6:
1997-1999 - 04466-33040
2000-2001 - USA Production: 04466-33060 Japan Production: 04466-32030
Solara
Gen 1:
V6:
1999-09/1999 (2000) - 04466-33040
10/1999(2000)-2003 - 04466-33060
Drum:
Gen 3 Camry: 04495-06010
Gen 4 Camry: 04495-06010
Gen 1 Solara: 04495-06010
Akebono: Very high quality replacement pads. Akebono makes OEM pads for Toyota and other manufacturers and offers 2 high quality pad lines. The hardware is generic and I prefer OEM hardware. I have used these several times with great results.
ProACT: http://www.rockauto.com/catalog/more...658&cc=1442322
Front:
Camry
Gen 3:
I4: ACT562
V6: ACT476
Gen 4:
I4:
14" Wheels - ACT562
15" Wheels - ACT476
V6: ACT707
Solara
Gen 1:
I4 and V6: ACT707
Rear:
Camry
Disc:
Gen 3:
I4 and V6: ACT325
Gen 4:
V6:
1997-1999 - ACT325
2000-2001 - USA Production: ACT828 Japan Production: ACT835
Solara
Gen 1:
V6:
1999-09/1999 (2000) - ACT325
10/1999(2000)-2003 - ACT828
ADVICS: Another high quality OEM pad maker for Toyota and others.
Front:
Camry
Gen 3:
I4: AD0562
V6: AD0476
Gen 4:
I4:
14" Wheels - AD0562
15" Wheels - AD0476
V6: AD0707
Solara
Gen 1:
I4 and V6: AD0707
Rear:
Camry
Disc:
Gen 3:
I4 and V6: AD0325
Gen 4:
V6:
1997-1999 - AD0325
2000-2001 - Japan Production: AD0835
Solara
Gen 1:
V6:
1999-09/1999 (2000) - AD0325
Beck/Arnley: Beck/Arnley offers a few different lines of brake pads. I will only focus on the OEM Pad line which is literally a rebox of the factory Sumitomo, Advics, Hitachi, or Akebono pads in a Beck/Arnley box. These pads are highly recommended.
OE Pads:
Front:
Camry
Gen 3:
I4: 089-1453
V6: 089-1379
Gen 4:
I4:
14" Wheels - 089-1453
15" Wheels - 089-1379
V6: 089-1538
Solara
Gen 1:
I4 and V6: 089-1538
Rear:
Camry
Disc:
Gen 3:
I4 and V6: 089-1311
Gen 4:
V6:
1997-1999 - 089-1311
2000-2001 - Japan Production: 089-1670
Solara
Gen 1:
V6:
1999-09/1999 (2000) - 089-1311
Centric: Centric offers 3 Ceramic pad lines. One Posi-Quiet premium in house line ,another OEM line where they rebox OEM pads, and a high performance StopTech line.
Posi-Quiet Premium: http://www.rockauto.com/catalog/more...584&cc=1433062
Front:
Camry
Gen 3:
I4: 10505621
V6: 10504761
Gen 4:
I4:
14" Wheels - 10505621
15" Wheels - 10604761
V6: 10607070
Solara
Gen 1:
I4 and V6: 10607070
Rear:
Camry
Disc:
Gen 3:
I4 and V6: 10503250
Gen 4:
V6:
1997-1999 - 10503250
2000-2001 - USA Production: 10508281 Japan Production: 10508350
Solara
Gen 1:
V6:
1999-09/1999 (2000) - 10503250
10/1999(2000)-2003 - 10508281
OE Formula Pads:
Front:Camry
Gen 4:
V6: 10007070
Solara
Gen 1:
I4 and V6: 10007070
Rear:
Camry
Gen 4:
V6:
2000-2001 - Japan Production: 10008350
StopTech High Performance:
http://www.rockauto.com/catalog/more...444&cc=1433059
Front:
Camry
Gen 3:
I4: 30903250
V6: 30904760
Gen 4:
I4:
14" Wheels - 30905620
15" Wheels - 30904760
V6: 30907070
Solara
Gen 1:
I4 and V6: 30907070
Rear:
Camry
Disc:
Gen 3:
I4 and V6: 30903250
Gen 4:
V6:
1997-1999 - 30903250
2000-2001 - Japan Production: 30908350
Solara
Gen 1:
V6:
1999-09/1999 (2000) - 30903250
Hawk: Comparable to StopTech these High Performance pads are raved about for their performance and driveability.
http://www.hawkpadsdirect.com/Hawk-P...-Pads-s/11.htm
HPS Street Pads:
Front:
Camry
Gen 3:
I4: HB310F.689
V6: HB318F.669
Gen 4:
I4:
14" Wheels - HB310F.689
15" Wheels - HB318F.669
V6: HB320F.669
Solara
Gen 1:
I4 and V6: HB320F.669
Rear:
Camry
Disc:
Gen 3:
I4 and V6: HB401F.587
Gen 4:
V6:
1997-1999 - HB401F.587
Solara
Gen 1:
V6:
1999-09/1999 (2000) - HB401F.587
EBC: Comparable to the Centric line, these High Performance pads are raved about for their performance and driveability.
Note: EBC recommends to NOT upgrade the rear brake pads unless the SAME upgrade is fitted to the front to avoid brake imbalance. What this means is make sure that the rear brakes are not higher friction than the front.
Ultimax2: http://ebcbrakes.com/product/ultimax-brake-pads/ High quality OEM replacement pads with the "much coveted" GG friction rating.
Front:
Camry
Gen 3:
I4: UD562
V6: UD476
Gen 4:
I4:
14" Wheels - UD562
15" Wheels - UD476
V6: UD707
Solara
Gen 1:
I4 and V6: UD707
Rear:
Camry
Disc:
Gen 3:
I4 and V6: UD325
Gen 4:
V6:
1997-1999 - UD325
2000-2001 - USA Production: UD828 Japan Production: UD835
Solara
Gen 1:
V6:
1999-09/1999 (2000) - UD325
10/1999(2000)-2003 - UD828
Green Stuff Sport: http://ebcbrakes.com/product/greenstuff-brake-pads/ "Greenstuff pads deliver improved stopping power with zero noise and normal lifetime."
Front:
Camry
Gen 3:
I4: DP2964
V6: DP2874
Gen 4:
I4:
14" Wheels - DP2964
15" Wheels - DP2874
V6: DP21133
Solara
Gen 1:
I4 and V6: DP21133
Rear:
Camry
Disc:
Gen 3:
I4 and V6: DP2628
Gen 4:
V6:
1997-1999 - DP2628
2000-2001 - USA Production: DP21715 Japan Production: DP21456
Solara
Gen 1:
V6:
1999-09/1999 (2000) - DP2628
10/1999(2000)-2003 - DP21715
Red Stuff Fast: http://ebcbrakes.com/product/redstuff-brake-pads/ "Redstuff Ceramic pad for higher speed driving... deliver zero noise and extended lifetime."
Front:
Camry
Gen 3:
I4: DP3964C
V6: DP3874C
Gen 4:
I4:
14" Wheels - DP3964C
15" Wheels - DP3874C
V6: DP31133C
Solara
Gen 1:
I4 and V6: DP31133C
Rear:
Camry
Disc:
Gen 3:
I4 and V6: DP3628C
Gen 4:
V6:
1997-1999 - DP3628C
2000-2001 - USA Production: DP31715C Japan Production: DP31456C
Solara
Gen 1:
V6:
1999-09/1999 (2000) - DP3628C
10/1999(2000)-2003 - DP31715C
Yellow Stuff Race: http://ebcbrakes.com/product/yellowstuff-street-and-track-pads/ "For extended race use."
Front:
Camry
Gen 3:
V6: DP4874R
Gen 4:
I4:
15" Wheels - DP4874R
V6: DP41133R
Solara
Gen 1:
I4 and V6: DP41133R
Rear:
Camry
Disc:
Gen 3:
I4 and V6: DP3628C
Gen 4:
V6:
1997-1999 - DP4628R
2000-2001 - USA Production: DP41715R Japan Production: DP41456R
Solara
Gen 1:
V6:
1999-09/1999 (2000) - DP4628R
10/1999(2000)-2003 - DP41715R
Wagner: Thermoquiet are the premium Wagner line. Good overall reviews online as well. Apparently they are the number one global pad manufacturer.
http://www.rockauto.com/catalog/more...443&cc=1433062
Front:
Camry
Gen 3:
I4: QC562 (with hardware) PD562 (without hardware)
V6: QC476 (with hardware) PD476 (without hardware)
Gen 4:
I4:
14" Wheels - QC562 (with hardware) PD562 (without hardware)
15" Wheels - QC476 (with hardware) PD476 (without hardware)
V6: QC707 (with hardware)
Solara
Gen 1:
I4 and V6: QC707 (with hardware)
Rear:
Camry
Disc:
Gen 3:
I4 and V6: QC325 (with hardware) PD325 (without hardware)
Gen 4:
V6:
1997-1999 - QC325 (with hardware) PD325 (without hardware)
2000-2001 - USA Production: QC828 (with hardware) PD828 (without hardware) Japan Production: QC835 (with hardware) PD835 (without hardware)
Solara
Gen 1:
V6:
1999-09/1999 (2000) - QC325 (with hardware) PD325 (without hardware)
10/1999(2000)-2003 - QC828 (with hardware) PD828 (without hardware)
Wearever: Another very commonly used brake pad. Available in 4 lines I will touch only on the Gold and Ceramic lines for pads and Silver for shoes:
Silver: Economical bonded brake shoes in the silver line.
Gen 3 and Gen 4 Camry and Gen 1 Solara (1992-2003) -
Rear: NB587
Gold: High quality ceramic pad that does not include hardware. Lifetime warranty
Front:
Camry
Gen 3:
I4: GNAD562
V6: GNAD476
Gen 4:
I4:
14" Wheels - GNAD562
15" Wheels - GNAD476
V6: GNAD707
Solara
Gen 1:
I4 and V6: GNAD707
Rear:
Camry
Disc:
Gen 3:
I4 and V6: GNAD325
Gen 4:
V6:
1997-1999 - GNAD325
2000-2001 - USA Production: GNAD828 Japan Production: GNAD835
Solara
Gen 1:
V6:
1999-09/1999 (2000) - GNAD325
10/1999(2000)-2003 - GNAD828
Platinum: High quality ceramic pad that includes hardware and moly brake lube. I have used these with great results.
Front:
Camry
Gen 3:
I4: PXD562H
V6: PXD476H
Gen 4:
I4:
14" Wheels - PXD562H
15" Wheels - PXD476H
V6: PXD707H
Solara
Gen 1:
I4 and V6: PXD707H
Rear:
Camry
Disc:
Gen 3:
I4 and V6: PXD325H
Gen 4:
V6:
1997-1999 - PXD325H
2000-2001 - USA Production: PXD828H Japan Production: PXD835H
Solara
Gen 1:
V6:
1999-09/1999 (2000) - PXD325H
10/1999(2000)-2003 - PXD828H
Brembo: Brembo is leading name in brake performance and technology. They also have an OEM line which may be a rebox of other pads.
http://brembo.mycarparts.net/products/Brembo-P83061N?product_application_id=2246976998
Front:
Camry
Gen 3:
I4: P83034N
Gen 4:
I4:
14" Wheels - P83034N
V6: P83040N
Solara
Gen 1:
I4 and V6: P83040N
Rear:
Disc:
Gen 3:
I4 and V6: P83015N
Gen 4:
V6:
1997-1999 - P83015N
2000-2001 - USA Production: P83110N Japan Production: P83063N
Solara
Gen 1:
V6:
1999-09/1999 (2000) - P83015N
10/1999(2000)-2003 - P83110N
There are several other manufacturers of brake pads and shoes including: Bendix, Monroe, Midas, Raybestos, etc., that are either reboxes or similar quality. This list is not all inclusive but should provide a guide for good quality pads and shoes.
Brake Rotors and Drums:
OEM Toyota: High quality rotors that can be expected from an OEM manufacturer.
Front:
Camry
Gen 3:
I4: 43512-06010
V6: 43512-06031
Gen 4:
I4:
14" Wheels - 43512-06010
15" Wheels - 43512-06031
V6: 43512-06031
Solara:
Gen 1:
I4 and V6: 43512-06031
Rear:
Camry
Gen 3:
Disc -
Coupe/Sedan - 42431-33060/42431-06020
Wagon - 42431-33030
Drum -
Coupe/Sedan/Wagon - 42431-33110
Gen 4 Camry and Gen 1 Solara:
Disc -
V6: 42431-33060/42431-06020
Drum -
I4: 42431-33110
Advics: Very high quality rotors from an OEM manufacturer. Advics claims that these rotors are made with identical materials and processes as the factory Toyota and Lexus rotors specifically.
Front:
Camry
Gen 3:
I4: A6F062
V6: A6F054
Gen 4:
I4:
14" Wheels - A6F062
15" Wheels - A6F054
V6: A6F054
Solara:
Gen 1:
I4 and V6: A6F054
Beck/Arnley: Another high quality premium rotor. I have used these with good results.
Front:
Camry
Gen 3:
I4: 083-2449
V6: 083-2450
Gen 4:
I4:
14" Wheels - 083-2449
15" Wheels - 083-2450
V6: 083-2450
Solara:
Gen 1:
I4 and V6: 083-2450
Rear:
Camry
Gen 3:
Coupe/Sedan - 083-2443
Wagon - 083-2504
V6: 083-2443
Centric: Centric offers many different rotors from a standard all the way to a drilled and slotted StopTech rotor. Higher models feature a corrosion resistant E-coating. These are a preferred choice when OEM are too much.
C-TEK Standard: Standard Rotor
Front:
Camry
Gen 3:
I4: 12144078
V6: 12144079
Gen 4:
I4:
14" Wheels - 12144078
15" Wheels - 12144079
V6: 12144079
Solara:
Gen 1:
I4 and V6: 12144079
Rear:
Camry
Gen 3:
Coupe/Sedan - 12144085
Wagon - 12144080
V6: 12144085
Premium: http://www.rockauto.com/catalog/more...592&cc=1433059
Front:
Camry
Gen 3:
I4: 12044078
V6: 12044079CRY w/Crogenically Treated 12044079 w/out Crogenically Treated
Gen 4:
I4:
14" Wheels - 12044078
15" Wheels - 12044079CRY w/Crogenically Treated 12044079 w/out Crogenically Treated
Solara:
Gen 1:
I4 and V6: 12044079CRY w/Crogenically Treated 12044079 w/out Crogenically Treated
Rear:
Camry
Gen 3:
Coupe/Sedan - 12044085
Wagon - 12044080
V6: 12044085
High Carbon Alloy: http://www.rockauto.com/catalog/moreinfo.php?pk=2043528&cc=1433059
Front:
Camry
Gen 3:
V6: 12544079
Gen 4:
I4:
15" Wheels - 12544079
V6: 12544079
Solara:
Gen 1:
I4 and V6: 12544079
StopTech: http://www.rockauto.com/catalog/more...284&cc=1433059
Front:
Camry
Gen 3:
I4:
Drilled - 12844078L 12844078R
Slotted - 12644078L 12644078R
Drilled and Slotted - 12744078L 12744078R
V6:
Drilled - 12844079L 12844079R
Slotted - 12644079L 12644079R
Drilled and Slotted - 12744079L 12744079R
Gen 4:
I4:
14" Wheels -
15" Wheels -
V6:
Solara:
Gen 1:
I4 and V6:
Rear:
Camry
Gen 3:
Coupe/Sedan -
Drilled - 12844085L 12844085R
Slotted - 12644085L 12644085R
Drilled and Slotted - 12744085L 12744085R
Wagon -
Drilled - 12844080L 12844080R
Slotted - 12644080L 12644080R
Drilled and Slotted - 12744080L 12744080R
V6:
Brembo: Brembo blanks are the only choice for some owners. High quality Brembo blanks are comparable to OEM quality. Watch out for fakes.
http://brembo.mycarparts.net/products/Brembo-09955921?product_application_id=2247037876
Front:
Camry
Gen 3:
I4: Part Number - 09.5623.10 / 5 Digit Brembo Number - 25357
V6: Part Number - 09.A386.10 (not painted) 09.A386.11 (painted) / 5 Digit Brembo Part Number - 25358
Gen 4:
I4:
14" Wheels - Part Number - 09.5623.10 / 5 Digit Brembo Number - 25357
15" Wheels - Part Number - 09.A.386.10 (not painted) 09.A386.11 (painted) / 5 Digit Brembo Part Number - 25358
V6: Part Number - 09.A.386.10 (not painted) 09.A386.11 (painted) / 5 Digit Brembo Part Number - 25358
Solara:
Gen 1:
I4 and V6: 09.A.386.10 (not painted) 09.A386.11 (painted) / 5 Digit Brembo Part Number - 25358
Rear:
Camry
Gen 3:
Coupe/Sedan - Part Number - 08.5625.20 / 5 Digit Brembo Number - 25161
Wagon - Part Number - 08.9179.10 / 5 Digit Brembo Number - 25552
V6: Part Number - 08.5625.20 / 5 Digit Brembo Number - 25161
EBC: High quality rotors for street and sport applications.
UPR Series: High quality replacement blanks.
Front:
Camry
Gen 3:
I4: UPR739
V6: UPR741
Gen 4:
I4:
14" Wheels - UPR739
15" Wheels - UPR741
V6: UPR741
Solara:
Gen 1:
I4 and V6: UPR741
Rear:
Gen 3:
Coupe/Sedan - UPR826
Wagon - UPR7228
V6: UPR826
GD Series Rotor: High Quality Cross Drilled Rotors
http://ebcbrakes.com/product/3gd-sport-rotors/
Front:
Camry
Gen 3:
I4: GD739
V6: GD741
Gen 4:
I4:
14" Wheels - GD739
15" Wheels - GD741
V6: GD741
Solara:
Gen 1:
I4 and V6: GD741
Rear:
Camry
Gen 3:
Coupe/Sedan - GD826
Wagon - GD7228
V6: GD826
USR Series: High Quality Slotted Rotors
http://ebcbrakes.com/product/usr-slotted-rotors/
Front:
Camry
Gen 3:
I4: USR739
V6: USR741
Gen 4:
I4:
14" Wheels - USR739
15" Wheels - USR741
V6: USR741
Solara:
Gen 1:
I4 and V6: USR741
Rear:
Camry
Gen 3:
Coupe/Sedan - USR826
Wagon - USR7228
V6: USR826
Duralast:
Standard: I have used them for years with no issues.
Front:
Camry
Gen 3:
I4: 3291
V6: 31260
Gen 4:
I4:
14" Wheels - 3291
15" Wheels - 31260
V6: 31260
Solara:
Gen 1:
I4 and V6: 31260
Rear:
Camry
Gen 3:
Coupe/Sedan - 31075
Wagon - 31110
V6: 31075
Gold: Allegedly these are high carbon steel rotors. They also have an E-Coating for rust prevention.
Front:
Camry
Gen 3:
I4: 3291DG
V6: 31260DG
Gen 4:
I4:
14" Wheels - 3291DG
15" Wheels - 31260DG
V6: 31260DG
Solara:
Gen 1:
I4 and V6: 31260DG
Wagner: Pretty standard Rotor
Front:
Camry
Gen 3:
I4: BD125222
V6: BD125223
Gen 4:
I4:
14" Wheels - BD125222
15" Wheels - BD125223
V6: BD125223
Solara:
Gen 1:
I4 and V6: BD125223
Rear:
Camry
Gen 3:
Coupe/Sedan - BD125217
Wagon - BD125260
V6: BD12517
Chassis and Suspension Parts
Once your suspension is shot from the decades of driving, here are the most prevalent options for replacement. While I have no experience with any of them personally, I gather from forum posts as well as Amazon comments that the below are the best for you to choose from in their respective categories. Let me also say that I believe that one thing that almost everyone has said is that all of the below have mounts that are inferior to OEM; however, the advantage to these are that they come as a single unit for easy installation (as opposed to ordering an OEM mount and all the other hardware for you to put together and install yourself. I will only list the “quick-strut” type, which comes as a complete and easily installed unit. There is “economy” and “original ride quality”.
Original Ride Quality:
Monroe Quick-Strut: From Monroe: "Monroe® Quick-Strut® units include all the components required for strut replacement in a single, fully-assembled unit. They feature pre-assembled replacement bearing plate, upper and lower spring isolators, upper spring seat, coil spring, boot kit, and a premium strut."
Gen3 5sfe:
Left Front: 171980
Passenger Front: 171979
Driver Rear: 171958
Passenger Rear: 171957
Gen4 5sfe:
Left Front: 171679
Passenger Front: 171678
Driver Rear: 171681
Passenger Rear: 171680
Gen4 1mzfe:
Left Front: 271679
Right Front: 271678
Left Rear: 271681
Right Rear: 271680
KYB: Strut Plus
Gen3:
Left Front:
Right Front:
Left Rear:
Right Rear:
Gen4 5sfe:
Left Front:
Right Front:
Left Rear:
Right Rear:
Gen4 1mzfe:
Left Front:
Right Front:
Left Rear:
Right Rear:
Economy
Unity:
Gen3:
Left Front:
Right Front:
Left Rear:
Right Rear:
Gen4:
Left Front:
Right Front:
Left Rear:
Right Rear:
Sensen:
Gen3:
Left Front:
Right Front:
Left Rear:
Right Rear:
Gen4:
Left Front:
Right Front:
Left Rear:
Right Rear:
Wiper Blades:
The OEM wiper blades for the 3rd and 4th Gen Camry and 1st Gen Solara are of the outdated frame design. They have 6 pressure points that make contact with the glass and when the blade wears out streaking occurs. I have updated the OEM style blades on my cars to the updated OEM Toyota/Denso Designer wiper blades available on newer models. There are also several frameless style blades available with the Denso Designer being the same exact blade as OEM. Lengths for the 3rd and 4th Gen Camry are 21 inches for the driver side and 19 inches for the passenger side and lengths for the 1st Gen Solara are 22 inches for the driver side and 21 inches for the passenger side. I highly recommend switching the Gen 3 and 4 Camry driver to either a 20" or 22" driver side to give you the added convenience of insert replacement available through the dealer parts department. For the Solara, I highly recommend attempting to fit a 22" passenger side or moving down to a 20" passenger side for the same reasons.
OEM Toyota Improved Style:
1992-2001 Camry: Driver - 85212-0T020 (22") or 85212-06110 (20") Passenger - 85212-47040
1999-2003 Solara: Driver - 85212-0T020 (22") Passenger - 85212-0T020 (22") or 85212-06110 (20")
Note: Toyota has no 21" blades in the new design so 3rd and 4th Gen Camry owners will either need to try the 22" Venza Blade or go with the 20" Camry Blade for the Driver side.
Denso Designer Blade:
1992-2001 Camry: Driver - 1603122 (22") or 1603120 (20"), or 1603121 (3rd and 4th Gen Camry 21") Passenger - 1603119
1999-2003 Solara: Driver - 1603122 (22") Passenger - 1603122 (22") or 1603120 (20")
Note: Using the 1603121 1992-2001 21" Blade means you won't be able to use OEM Toyota replacement inserts when they wear out.
Replacement Inserts: (Blades above come with inserts. These are only needed when the originals are worn out).
1992-2001 Camry: Driver - 85214-0T040 (22") or 85214-06130 (20") Passenger - 85214-30390
1999-2003 Solara: Driver - 85214-0T040 (22") Passenger - 85214-0T040 (22") or 85214-06130 (20")
With these lengths you can check out any frame-less beam style blades from Rain-X, Anco, Bosch, Valeo or Trico.
Drive Belts:
The highly recommended belts for these cars include OEM/Bando, Gates/Napa Micro-V, and the Goodyear Gatorback. If you have a squeak you can't adjust, are doing a timing belt replacement job, or they are cracked, glazed, or broken, replacing the belts is a good idea.
OEM Toyota: The OEM belts are made by Mitsuboshi, Bando, or Dayco and can be purchased from a dealership or aftermarket.
Gen 3
Camry 5SFE:
P/S - 99363-30750
Alt with A/C - 99365-71110-78 or 99365-81110-78
Alt without A/C - 90916-02356-83
Gen 3 Camry 3VZFE:
P/S - 90916-02350-83
Alt with A/C - 99366-71050-78 or 90916-02374-78
Alt without A/C - 99366-80940-83
Gen 3 Camry 1MZFE:
P/S - 90080-91088-83 or 90916-02386-83
Alt with A/C - 90916-02401-83
Alt without A/C - 99366-80950-83
P/S - 99363-30750
Alt with A/C - 90080-91122-83
Alt without A/C - 90916-02671
Gen 1 Solara 2AZFE:
90916-A2012
Bando: Very high quality belts. I have used them with great results.
Gen 3 Camry 5SFE:
P/S - 3PK750
Alt with A/C - 5PK1105
Alt without A/C - 5PK990
Gen 3 Camry 3VZFE:
P/S - 4PK800
Alt with A/C - 6PK1055
Alt without A/C - 6PK940
Gen 3 Camry 1MZFE:
P/S - 4PK875
Alt with A/C - 6PK1045
P/S - 3PK750
Alt with A/C - 90916-02671
P/S - 4PK880
Alt with A/C - 6PK1035
Alt without A/C - 6PK1035
Gen 1 Solara 2AZFE:
7PK1935
Continental Elite: Very high quality belts. I have used them with great results.
Gen 3 Camry 5SFE:
P/S - 4030295
Alt with A/C - 4050435
Alt without A/C - 4050390
Gen 3 Camry 3VZFE:
P/S - 4040315
Alt with A/C - 4060415
Alt without A/C - 4060370
Gen 3 Camry 1MZFE:
P/S - 4040347
Alt with A/C - 4060410
P/S - 4030295
Alt with A/C - 4050433
P/S - 4040347
Alt with A/C - 4060407
Gen 1 Solara 2AZFE:
4070760
Napa/Gates Micro-V:
Gen 3 Camry 5SFE:
P/S - K030295
Alt with A/C - K050435
Alt without A/C - K050390
Gen 3 Camry 3VZFE:
P/S - K040320
Alt with A/C - K060415
Alt without A/C - K060370
Gen 3 Camry 1MZFE:
P/S - K040347
Alt with A/C - K060410
P/S - K050390
Alt with A/C - K050433
P/S - K060407
Alt with A/C - K060407
Gen 1 Solara 2AZFE:
K070763 w/o "enhancement kit" 76 7/8" or 7PK1930 "w/enhancement kit" 76"
Dayco:
Gen 3 Camry 5SFE:
P/S - 5030295
Alt with A/C - 5050433
Alt without A/C - 5030295
Gen 3 Camry 3VZFE:
P/S - 5040315
Alt with A/C - 5060415
Alt without A/C - 5060370
Gen 3 Camry 1MZFE:
P/S - 5040347
Alt with A/C - 5060408
P/S - 5030295
Alt without A/C - 5050390
P/S - 5040347
Gen 1 Solara 2AZFE:
5070763
Denso O2/Air Fuel Sensor p/n table:
Battery:
All Gen 3 & 4 Camrys in the USA market take a BCI group 35 battery. Be aware there is a group 25 battery that is the exact same size, but with the pos/neg terminals swapped. Don't use one of those by mistake!
In the northern areas (Canadian market?), Camry vehicles were sometimes ordered with a "Winter Weather Package", that had a bigger group 24F battery.
Feel free to reply with any recommended additions or updates and I or a mod will see if I we can get to them.
Super Moderator
2005 Corolla CE
Post reserved for maintenance sticky additions
Camry LE ('00 & '09)
Yeah, I started it, then had a second child so I just posted what I had and have not had much time to work on it any more.
Of course you can update it as you please and add it to the sticky.
I tried to leave out anything that I was not reasonably sure about, but there may be mistakes (but as far as the internet goes, I think there is more fact here then many other places ;) ).
Super Moderator
2005 Corolla CE
I have been going through and updating all the stickies. I just made some significant updates to the cooling, fuel filter, transmission filter, transmission fluid, and minor updates to some other sections. I will edit/update/complete as I have time and since the thread is yours, you also have the power to do so.
Great job. I see you formatted your bold/underline/italics a little different so I stuck to that.
Super Moderator
2005 Corolla CE
Did some more updates to the spark plug, wiper blade, and gear oil sections. I'll check back again in a few weeks to update the brake information.
Dave in KCMO
03 Camry 4-Cyl
Suspension updates for Monroe Quickstruts Part numbers
Gen3 5sfe: (I have a 1996 I-4 - Assume this is Gen 3)
Left Front: 171980
Driver Rear: 171958
To throw a wrench into the hotly debated ATF topic...
Two years ago when I contacted Valvoline about my 2001 Camry V6 I got the reply below. There is no mention of using "Valvoline Import Multi-Vehicle Automatic Transmission Fluid" for this particular car. I believe that fluid is for Toyota's requiring Type T, T-II, and T-IV except hybrids. This from Valvoline...
Your 2001 Toyota Camry came factory filled with Dexron III ATF in both the automatic transmission and the power steering reservoir, you have a couple different fluid options. Valvoline Dex/Merc ATF and our Valvoline MaxLife ATF product are Dexron III compatible and will both be suitable for mixture or replacement in the automatic transmission and power steering reservoir on your Toyota Camry.
The Valvoline MaxLife ATF product is designed and formulated as a synthetic ATF with seal conditioners, to assist in keeping high mileage vehicles from developing leaks from seals that are dry-rotted or cracked. The Valvoline Dex/Merc ATF product is a conventional product designed for applications that don't require a synthetic fluid and meets or exceeds all the Dexron III ATF requirements.
Super Moderator
2005 Corolla CE
T-III is literally just Dexron III. In some TSBs, Toyota even calls it Dexron III:
http://toyota-club.net/files/2010/tsb_tc001-02.pdf
This is from the product data sheet on the Valvoline Import Multi-Vehicle fluid (see bold):
Recommended for use in GM , Ford, Toyota, Honda, Nissan, Hyundai and other imported vehicles Suitable for use in:
Ford MERCON® applications
GM DEXRON® - II and DEXRON® - III applications
BMW LT 71141 and ETL - 7045E applications
Nissan/Infiniti Nissan ATF, Matic D, Matic K and Matic J applications Mitsubishi Diamond SP - II and SP - III applications
Subaru ATF - HP Hyundai/ KIA SP - II and SP - III applications
Toyota/Lexus Type T, T - III and T - IV applications
Honda/Acura ATF - Z1 (except in CVTs) applications
Mercedes Benz NAG1 applications
Volvo passenger car applications (except AW - 1) Volkswagen /Audi TL52162
Reactions: Cami&Hugh
Super Moderator
Added battery size info at the bottom.
Super Moderator
2005 Corolla CE
Major addition to the brake pad and rotor section. That section should be correct based on lots of research from many different sources.
I don't know why the Valvoline rep didn't mention it then. They said MaxLife ATF and Dex/Merc ATF, with no mention of the Import Multi-Vehicle trans fluid. If you are right then I have 3 different Valvoline trans fluids to choose from. More confusion. I'll take my chances on the Supertech ATF "used in vehicles that previously used Dex II and III. It has worked just fine so far.
Super Moderator
2005 Corolla CE
Added full Wix XP filter info.
Reactions: Sean D
Super Moderator
2005 Corolla CE
Added Advics and Beck/Arnley pad and rotor info.
BAM! It's SPAM!!!
99 Camry XLE V6
According to Mobil 1, the correct size oil filter for the 1MZ is M1-102, which I've been using, instead of the M1-209 that you posted, but I'm assuming that you posted an oversized version.
Super Moderator
2005 Corolla CE
Added Reochem OEM Premium Coolant for the Canadian owners.
Fixed.
I appreciate all the impressive helpful info ! I just got my first Toyota from original owner. She faithfully took it to dealer for all scheduled maintenance and any problems. It is a year 2000 V-6 Camry LE, with auto trans. Mileage is 213K. She decided to sell it rather than fix the broken shifter cable. I found the needed help with that job here.
Thanks !! :laugh:
Just thought I'd throw in my first post. I was digging around for info on cabin air filters for my 2000 Camry LE....called my local Toy dealer, and asked a service tech if my car even had one. He said they didn't start putting them in till 03 or 04. Also, do I really NEED a torque wrench for installing new spark plugs? Manual says to torque them to 13 ft-lbs.....lowest my torque goes is 20. Thanks in advance for any help!
Many people hand-tighten their spark plugs.
Also, there is a diy of a cabin air filter install from a es300 somewhere on this site. From what I remember, the camry has an empty space that's sealed off where the filter can go, you just have to cut the plastic and get the cover off of an es300.
1 - 20 of 71 Posts
