1 - 6 of 6 Posts
· Super Moderator
2020 Prius Prime Limited
OK all you HL fanatics - in this thread you can find specs for your 4th Gen HL. DIY info will be placed in a different sticky; this area is for specs for the 4th Gen HL (filter types, part numbers, etc.). Moderators will edit posts in this thread to keep them relevant to technical specs for the proper generation of HL.
2011HL
An interesting link found in the Gen 2 forum that deals with tire rims on the various models and years
· Super Moderator
2021 HiHy Platinum AWD
Part2GR-FKSA25A-FXE (Hybrid)
Gasoline87 AKI (91 RON)
Top Tier Gas recommended
87 AKI (91 RON)
Oil filter04152YZZA190915YZZN1
Air Filter17801F002017801F0050
Cabin Air Filter87139YZZ37 (plain)
8713958010 (Charcoal activated)
87139YZZ37 (plain)
Oil0W-20
5.8 quarts
002790W20, then size of container code
0W-16
4.8 quarts
0027916, the size of container code (note same part number on bottle for API SN and SP, with SP having more moly)
Spark Plugs9091901263
Denso FK20HBR8
Gap: 0.031 in (0.8 mm)
9091901289
Denso FC16HR-Q8
Wipers18" (Passenger)
852140E130 (refill)
26" (Driver)
852140E151 (refill)
18" (Passenger)
852140E130 (refill)
26" (Driver)
852140E151 (refill)
Hybrid Battery interior filtern/aG92DJ48020
Front Turn signal74437443
Front side marker194194
Rear turn Signal74407440
Reverse921921
2nd row map lights194194
Front visor lights194194
Front lower door light194194
Rear cargoDE3175DE3175
Front rotor435120E060435120E060
Front pads04465025300446502530
Rear rotor424310E070424310E070
Rear pads04466024300446602430
Brake FluidDOT 3 or DOT 4DOT 3 or DOT 4
Transmission fluidToyota WS
8 quarts (including torque converter)
Toyota WS
4.6 quarts
Rear Differential FluidToyota Genuine Differential Gear Oil LX
0.56 quarts
75w85 GL-5
Toyota WS
1.8 quarts
Transfer CaseToyota Genuine Differential Gear Oil LX
0.41 quarts
75w85 GL-5
n/a
1 - 6 of 6 Posts
