1 - 20 of 183 Posts
Super Moderator
2005 Corolla CE
Ok everyone after much procrastinating I am going to make a compiled list of maintenance parts for the 5th and 6th Generation Camry and 2nd Generation Solara. A lot of these items will also benefit owners of 10th/2nd Gen Corolla/Matrix XR/XRS owners, Highlander, Rav4, Scion tC, and more. .
Disclaimer: Myself or Toyotanation are not liable for any damage or injury that may result from use of this guide. Vehicles should be diagnosed, maintained, and repaired by qualified technicians. Use this guide at your own risk.
Check the new car recommendation thread to assist you with any service recommendations:
http://www.toyotanation.com/forum/104-camry-5th-6th-gen-2002-2006-2007-2011-2nd-gen-solara-2004-2008/688353-hardtopte72-new-camry-solara-purchase-recommendations-thread.html
Here goes nothing!
Note: For the US market 5th and 6th Generation Camry, the 2AZFE is the 4 cylinder used from 2002-2009, the 1MZFE is the V6 used on SE models from 2002-2003 models and LE/XLE models from 2002-2006, the 3MZFE is the V6 used on SE models from 2004-2006, the 2GRFE is the V6 used from 2007-2011, and the 2ARFE is the 4 cylinder used from 2010-2011. For the 2nd Generation Solara, the 2AZFE is the 4 cylinder used from 2004-2008 and the 3MZFE is the V6 used from 2004-2008.
The Camry and Solara Generations are as follows:
2002-2006 Camry is Gen 5, which included revised V6 engines for the 2004 model year and a facelift for the 2005 model year
2007-2011 Camry is Gen 6, which included a revised I4 engine from the Gen 5, an all new V6 engine, and an all new I4 engine and a facelift for the 2010 model year
2004-2008 Solara is Gen 2, which included the I4 engine from the Gen 5, the Camry SE V6, and the revised from the Gen 6 and facelift for the 2007 model year
Oil Filters:
When doing an oil change, it is HIGHLY ADVISABLE to replace the oil pan drain plug gasket/crush washer. These can be purchased from Toyota, eBay, or Amazon from around 50 cents to 1 dollar each. I buy mine in packs of 10 for $5.50 shipped on eBay.
Part number: 90430-12031
Oil filters are an important part of the overall maintenance of your car. All filters are not created equal and filtering is not a job for the cheap. There are several acceptable oil filters available for the 5th and 6th Gen Camry. I will describe most of them below and cite whatever references I can. I will also add that I highly recommend using V6 Filters on the 2AZFE engine for increased capacity.
Oil filter terms:
OCI- oil change interval
ADBV- anti-drainback valve
Purolator: Purolator makes three different oil filters in their self named line. A standard "Premium Protection" filter, higher quality "Advanced Protection" filter, and synthetic oil "Maximum Protection" filter.
Purolator: Is the lower line filter. It is advertised with a 96.5 efficiency rating at 20 microns, 13g of "dirt holding" capacity and 5,000 mile oil change interval. It uses a rubber ADBV and paper/fiber media
2AZFE/2AZFXE: L14477
1MZ/3MZ V6/UZ V8 Toyota: L10241
Upsized MZ/UZ Toyota: L20195
2ARFE/2GRFE: L25608
PurolatorOne: Is the next in line filter. It is advertised with a 99% efficiency rating at 20 microns, 15g of "dirt holding" capacity and 10,000 mile oil change interval. It uses a silicone ADBV and paper/synthetic blend media.
2AZFE/2AZFXE: PL14477
1MZ/3MZ V6/UZ V8 Toyota: PL10241
Upsized MZ/UZ Toyota: PL20195
2ARFE/2GRFE: PL25608
Purolator Boss: Is the top of the line filter. It is advertised with a 99+ % efficiency rating at 20 microns, 27g of "dirt holding" capacity and 15,000 mile oil change interval with synthetic oils. It uses a silicone ADBV and a full synthetic media.
2AZFE/2AZFXE: PBL14477
1MZ/3MZ V6/UZ V8 Toyota: PBL10241
Upsized MZ/UZ Toyota: PBL20195
2ARFE/2GRFE: PBL25608
Bosch: These filters are made by Purolator ever since their merger. Two filters are offered in line with Purolator.
Bosch Premium: In line with a Purolator. Nearly identical in every way.
2AZFE/2AZFXE: 3325
1MZ/3MZ V6/UZ V8 Toyota: 3330
Upsized MZ/UZ Toyota: 3422
2ARFE/2GRFE: 3972
Bosch DistancePlus: This filter is basically a PurolatorOne with a larger case and filter area to hold more particles. It is rated 99% at 20 microns. This filter has been shown to be good to a 15K mile OCI.
2AZFE/2AZFXE: D3325
1MZ/3MZ V6/UZ V8 Toyota: D3330
Upsized MZ/UZ Toyota: D3422
Wix: Wix makes a very high quality line of filters. They also make the Napa brand filter.
Wix: High quality construct, silicone ADBV, and a tough case make this a good filter. 99% at 25 microns efficiency.
2AZFE/2AZFXE: 57145 or 51396
1MZ/3MZ V6/UZ V8 Toyota: 51348
Upsized MZ/UZ Toyota: 51516
2ARFE/2GRFE: 57047
Napa: All but recent Pro-Select are Wix made filters that expand on the line. Available in Pro-Select, Silver, and Gold (I don't see a Platinum listing). Which denote their place in the line. Pro-select is the low line, gold has top level features (more pleats, better filtering, etc.).
Pro-Select: This is a low line filter which recently appears to made on a contract basis (still likely Wix/Affinia). These use a controversial combo valve ADBV.
2AZFE/2AZFXE: SFI 27145
1MZ/3MZ V6/UZ V8 Toyota: SFI 21348
Upsized MZ/UZ Toyota: SFI 21516
2ARFE/2GRFE: SFI 27047
Silver: This is the mid level Wix made filter. Great filter for the money. Comparable to a Purolator Classic.
2AZFE/2AZFXE: SFL 37145
1MZ/3MZ V6/UZ V8 Toyota: FIL 31348
Upsized MZ/UZ Toyota: SFL 31516
2ARFE/2GRFE: FIL 37047
Nascar Select: This is their supposedly soon to be discontinued specialty line of filters. Features a unique "Spin-Flow" technology and a synthetic media. Claims to have some of the highest single pass efficiency in the industry.
From Napa "In traditional oil filters, unfiltered oil is forced under pressure through holes in the filter base plate directly to the top of the canister, creating turbulence in the filter. This constant turbulence concentrates the filtration of the dirty oil at one end of the filter media, resulting in only about 60 percent of the filter media doing the majority of the work.
The Spin-Flow technology, developed by Wix Filtration and used exclusively by NAPA for automotive applications, uses a ring of angled fins to force the dirty oil to flow in a circular motion around the filter media. This process evens out the flow of the dirty oil and virtually eliminates turbulence, thus using the entire filter media and maximizing the capacity and efficiency of the filter." "In addition to Spin-Flow technology, the NASCAR Select filter also features a newly designed filter media, combining cellulose with synthetic fibers. This new media, called T-52, was also developed by Wix Filtration for NAPA automotive use. T-52 greatly increases the filter's "Single-Pass Efficiency," which is a measure of how much of the oil's contaminates are removed in a single trip through the filter. NASCAR Select has one of the highest Single-Pass Efficiency ratings in the industry."
2AZFE/2AZFXE: NFI 91396
1MZ/3MZ V6/UZ V8 Toyota: NFI 91348
Gold: This is a top level filter. All the features you expect from a top level filter.
2AZFE/2AZFXE: FIL 7145
1MZ/3MZ V6/UZ V8 Toyota: FIL 1348
Upsized MZ/UZ Toyota: FIL 1516
2ARFE/2GRFE: FIL 7047
Platinum: This is their top of the line oil filter. This filter is specified specifically to be used with synthetic oil for extended drain intervals 10,000 miles or above. Tons of capacity at the expense of filtering ability.
2AZFE/2AZFXE: PFL 47145
1MZ/3MZ V6/UZ V8 Toyota: PFL 41348
Upsized MZ/UZ Toyota: PFL 41516
2ARFE/2GRFE: FFL 47047
Wix XP: Some say this is the same as the Napa Platinum. Some also say the data shows this filter has a terrible efficiency rating at 20 microns (50%). Regardless, Wix considers it their premium filter. It uses a wire backed synthetic media and is recommended for longer drain intervals on synthetic oil.
2AZFE/2AZFXE: 57145XP
1MZ/3MZ V6/UZ V8 Toyota: 51348XP
Upsized MZ/UZ Toyota: 51516XP
2ARFE/2GRFE: 57047XP
Mobil 1 and K&N: Great filters at a hefty price. These are 20 micron 99% filters made by Champion Labs. They feature all of the top of the line features you would expect from only the best. The K&N features a welded nut to aid in removal.
Mobil 1 Part Numbers:
2AZFE/2AZFXE: M1-103
1MZ/3MZ V6/UZ V8 Toyota: M1-102
Upsized MZ/UZ Toyota: M1-209
2ARFE/2GRFE: M1C-251
K&N Part Numbers:
2AZFE/2AZFXE: HP-1003
1MZ/3MZ V6/UZ V8 Toyota: HP-1002
Upsized MZ/UZ Toyota: HP-2009
2ARFE/2GRFE: PS7020
Denso: Denso makes the OEM Oil filter for these cars. It is made in several places. In spin-on form this is one of the most peculiar designed oil filters available. It features no end caps, rubber ADBV, and generally poor construction similar to a OCOD fram, though tests have shown them very reliable and generally having a filter media with a larger surface area than the competition. The cartridge type filters are of excellent quality and the Denso cartridge is the only cartridge I would run on a Toyota cartridge filter engine. Still a good reliable filter with good media even with its questionable design.
Available in three to four sizes depending on whether buying from Toyota or Denso directly.
2AZFE/2AZFXE: 90915-YZZF1/150-1001
1MZ/3MZ V6/UZ V8 Toyota: 90915-YZZG1/90915-YZZD1(older version)/150-2002 (V6) or 90915-YZZD3/150-1003 (V8)
2ARFE/2GRFE: 04152-YZZA1
Fram: I will refer only to the high quality Fram Extended Guard and the Fram Ultra line of filters. The others use cardboard end caps and are generally poorly constructed. Cheap is their only good quality.
Ultra: The Ultra is a very high quality and very robust filter right near the top of the high quality pack. It is designed for a 15K OCI, it's rated efficiency is 99% at 20 microns efficiency rating, and it features an awesome looking metal supported dual synthetic layer media. This new Fram Ultra filter appears to be the best filter ever made by Fram and right at the top level of oil filters. There really isn't a filter available that offers more. This is the filter I use on all of my vehicles.
2AZFE/2AZFXE: XG4967
1MZ/3MZ V6/UZ V8 Toyota: XG3614
Upsized MZ/UZ Toyota: XG3600
Those are the bulk of it. Most other oil filters are made by the above listed companies under other names (Motorcraft is Purolator, A/C Delco is a lower level Champion Labs, Carquest made by Wix).
Spark Plugs:
Spark plugs on these engines are recommended every 120K if using OEM equivalent plugs. These are dual precious metal plugs and are rated for longer life than the power plugs. I prefer Denso plugs as they are what came with the car. I have installed NGK on several cars and had no issues. These engines came with Iridium plugs so I will discuss these plugs only.
Plug gap for a Camry is .044 when using Iridium or Iridium "Power" and .040 if using Iridium Twin Tip, but the general consensus is you don't gap Iridium Plugs as they come pregapped.
NGK: NGK offers 2 types of Iridium plugs. An OEM long life Laser Iridium and a power plug called the Iridium IX.
NGK Laser Iridium: From NGK "Laser Iridium® spark plugs provide superior ignitability and long service life. Smallest tip diameter available Iridium / Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions". I used these on my BIL's Honda pilot because it came with them. Great plugs. The "A" plugs and "T" plugs are the same plugs, with the "A" being dealer only.
2AZFE/2AZFXE/1MZFE/3MZFE: PN: IFR6A11/IFR6T11. SN: 4589
2ARFE: PN: ILFR5T11. SN: 96779
2GRFE: PN: DILFR6D11 SN: 6176
NGK Iridium IX: From NGK "Designed specifically for the performance enthusiast. Iridium IX® offers extreme ignitability, improved throttle response and superior anti fouling". Used them on my neighbors Corolla. Very nice plugs and slightly better priced than the Lasers. According to NGK, these are around a 40-50K mile plug.
2AZFE/2AZFXE/1MZFE/3MZFE: PN: BKR6EIX-11 SN: 3764
2ARFE: PN: LFR5AIX11. SN: 4469
2GRFE: PN: LFR6AIX11 SN: 6619
Denso: Denso offers three types of plugs. OEM Long life Denso Iridium Long Life, Iridium Twin Tip (Iridium TT), and the power plug Denso Iridium Power. These are nearly identical to the NGK plugs in price, quality, and construction.
Denso Iridium Long Life: From Denso "Using the same laser welding process as the Iridium Power spark plug, Denso designed a long life spark plug factory installed on luxury vehicles by automakers such as GM, Toyota, Honda and Mitsubishi. Using its patented Iridium alloy, Denso was able to shrink the center electrode to 0.7mm, dramatically improving ignitability and longevity." I have these in my Corolla and Camry. These are the OEM plugs.
2AZFE/2AZFXE/1MZFE/3MZFE: PN: SK20R11. SN: 3297
2ARFE: PN: SK16HR11. SN: 3417
2GRFE: PN: FK20HR11 SN: 3426
Denso Iridium Twin Tip: From Denso "The Iridium TT Twin Tip Technology delivers far less obstruction to the spark allowing an omni-directional explosion. This minimizes the quenching effect and results in a more effective, more complete combustion. Better combustion means more power and better fuel economy, as fuel is burned more efficiently with each piston firing. The large center and ground electrodes seen on a Standard Plug increases “quenching” of the explosion, meaning the spark explosion is restricted by the electrodes above and below the gap, allowing it to spread to either side, but not grow with full range." These plugs are OEM in most newer Toyota engines. They are rated for 100K miles
2AZFE/2AZFXE/1MZFE/3MZFE: SN: 4702
2ARFE: SN: 4703
2GRFE: SN: 4704
Denso Iridium Power: Likely the same as NGK. Lower life but more performance. From Denso "This high-performance spark plug has the world’s smallest iridium center electrode that is a mere 0.4mm in diameter. The tip of the ground electrode is taper cut which reduces quenching and improves firing performance. This combination of DENSO technology provides improved horsepower, acceleration and fuel economy." Lexus owners have great reviews with these. According to Denso, these are a 30K mile plug.
2AZFE/2AZFXE/1MZFE/3MZFE: PN: IK20. SN: 5304
2ARFE: PN: IKH16. SN: 5343
Bosch: I have only read one person having a positive review for these. Use at your own risk.
Bosch Iridium: From Bosch "You don’t have to choose between high performance and long life in your iridium spark plug. Bosch Iridium is engineered to deliver both. The ultra fine wire design and laser welded tapered ground electrode deliver optimum performance, while the iridium center electrode and platinum ground electrode help it to go the distance."
2AZFE/2AZFXE/1MZFE/3MZFE: 9603
2ARFE: 9609
2GRFE: 9615
Autolite: No reviews on these. I wouldn't use them but they are here for your review.
Autolite Xtreme Performance Iridium: From Autolite "XP Xtreme Performance Spark Plugs are one of the brand's most technologically advanced spark plugs ever. With an iridium-enhanced .6 mm finewire design and patented platinum sidewire technology, these spark plugs provide better overall durability and a more focused ignition for better overall ignitability and optimum performance."
2AZFE/2AZFXE/1MZFE/3MZFE: XP3923
Champion:Same as Autolite:
Champion Iridium: From Champion "Champion Iridium: Champion Iridium spark plugs offer maximum performance regardless of engine or ignition type. Each plug has an extremely fine-wire iridium center electrode that is "laser-locked" to the center electrode, and a platinum V-trimmed ground electrode to ensure the longest life and greatest erosion resistance. Champion iridium plugs come with our exclusive Heat-Active™ alloy to reach operating temperatures quickly and maintain stable operating temperatures under varying engine loads. Champion iridium plugs deliver a consistently focused spark that provides the greatest engine performance regardless of engine type or ignition system. "
2AZFE/2AZFXE/1MZFE/3MZFE: 9806
2ARFE: 9006
2GRFE: 9044
Transmission Filters:
These transmissions use a felt filter element that should be replaced as part of normal maintenance. They are NOT screens or strainers as found other Toyota automatic transmissions.
Note: These can be very confusing and the parts stores don't list them all the same. Check your vehicle data plate to be absolutely sure.
2002-2004 Camry and 2004-03/05 Solara 2AZFE w/4 Speed U241E:
OEM Toyota: Filter - 35330-06010 Gasket - 35168-21011 or 21020 O-Ring - 90080-30077
Beck/Arnley*: 044-0316
Drive Works*: FK341
PowerTorque*: FK341
Duralast*: TF171
Napa Altrom - ATM 3632411
2005-2009 Camry and 03/2005-2008 Solara 2AZFE w/5 Speed U250E:
OEM Toyota: Filter - 35330-08010 Gasket - 35168-21011 or 35168-21020 O-Ring - 90080-30077
Beck/Arnley*: 044-0331
Pro King*: FK347
PowerTorque*: FK347
Duralast*: TF174 or T764
Napa Altrom - ATM 3632409
2002-2003 Camry 1MZFE w/4 speed U140E:
Drive Works*: FK341
PowerTorque*: FK341
Duralast*: TF171
2004-2006 Camry 1MZFE/3MZFE and 2004-2008 Solara 3MZFE w/5 speed U151E:
Pro King*: FK347
PowerTorque*: FK347
2007-2011 Camry 2GRFE w/6 speed U660E:
OEM Toyota: Filter - 35330-33050 or 35330-48020 Gasket - 35168-33080 O-Ring - 90301-27010
Beck Arnley*: 044-0356
Duralast*: TF637
Napa Altrom - ATM 3632408
2010-2011 Camry 2ARFE w/6 speed U760E:
OEM Toyota: Filter - 35330-73010 Gasket - 35168-73010 O-Ring - 90301-27010
* Note: These are all exactly the same filter sold at different outlets. They also all come in a kit with a filter, gasket, and o-ring included.
Air Filters:
Air filters are shown to be directly responsible for oil condition. There are a few available here as well. I will only discuss the OEM filter as I am a firm believer that cold air intakes are detrimental to filtering as most cone filters available filter worse than factory (and therefore flow more).
Denso: This is by far the best quality filter available. Featuring a 3 layer element to filter small, medium, and large particles and a perfect fit this filter is the best of the bunch. Available from Toyota as:
Gen 5 Camry 2AZFE and 1MZ/3MZ: 17801-0H010
Gen 6 Camry 2AZFE: 17801-0H050
Gen 6 Camry 2AFXE: 17801-0H010
Gen 6 Camry 2ARFE: 17801-0H050
Gen 6 Camry 2GRFE: 17801-AD010
Gen 2 Solara 2AZFE and 3MZFE: 17801-0H010
The rest of the filters either are of worse quality or mimic the denso without the 3 layer filtering.
Purolator:
Gen 5 Camry 2AZFE and 1MZ/3MZ: A35432 - Classic PA 35432 - PureOne
Gen 6 Camry 2AZFE: A35649 - Classic PA35649 - PureOne
Gen 6 Camry 2AFXE: A35432 - Classic PA 35432 - PureOne
Gen 6 Camry 2ARFE: A35649 - Classic PA35649 - PureOne
Gen 6 Camry 2GRFE: A45660 - Classic
Gen 2 Solara 2AZFE and 3MZFE: A35432 - Classic PA 35432 - PureOne
K&N:
Gen 5 Camry 2AZFE and 1MZ/3MZ: 332260
Gen 6 Camry 2AZFE: 332370
Gen 6 Camry 2AFXE: 332260
Gen 6 Camry 2ARFE: 332370
Gen 6 Camry 2GRFE: 332326
Gen 2 Solara 2AZFE and 3MZFE: 332260
Wix:
Gen 5 Camry 2AZFE and 1MZ/3MZ: 46673
Gen 6 Camry 2AZFE: 49223
Gen 6 Camry 2AFXE: 46673
Gen 6 Camry 2ARFE: 49223
Gen 6 Camry 2GRFE: 49172
Gen 2 Solara 2AZFE and 3MZFE: 46673
Fram:
Gen 5 Camry 2AZFE and 1MZ/3MZ: CA9360
Gen 6 Camry 2AZFE: CA10171
Gen 6 Camry 2AFXE: CA9360
Gen 6 Camry 2ARFE: CA10171
Gen 6 Camry 2GRFE: CA10169
Gen 2 Solara 2AZFE and 3MZFE: CA9360
Cabin Filters:
Many available here. Some are charcoal impregnated to reduce odors.
Denso: From Toyota:
Gen 5 Camry and Gen 2 Solara: 87139-YZZ05. Aftermarket 4531011
Gen 6: 87139-YZZ08. Aftermarket 4531019
Fram: Charcoal Impregnated fresh breeze.
Gen 5 Camry and Gen 2 Solara: CF10132
Gen 6: CF10285
ATP: Charcoal Impregnated
Gen 5 Camry and Gen 2 Solara: RA3
Gen 6: RA31
Wix:
Gen 5 Camry and Gen 2 Solara: 24883
Gen 6: 24483
TYC:
Gen 5 Camry and Gen 2 Solara: 800008P - Standard 800043P - Premium
Pentius:
Gen 5 Camry and Gen 2 Solara: PHB5479
Gen 6: PHB5667
Engine Oil:
The life blood of the engine. Synthetic oil is recommended for better wear protection, extended intervals, fuel economy, and startability. The decision of what kind of oil you run can make the difference between an oil burner, 200K miles, or your fuel economy. Not all oils are created equal. Running synthetic oil and changing at 3K is a waste of money. These oils are proven to go up to 15K miles between oil changes!
Take a look at these links before you decide what weight of oil to use.
http://www.bobistheoilguy.com/motor-oil-101/
http://www.zddplus.com/TechBrief13 - Oil Viscosity.pdf
http://www.lubricheck.com/demo/home/resources
Mobil 1: Oils are of excellent quality. TGMO (Toyota Genuine Motor Oil) is Mobil 1 oil with a special formulation. I will describe the synthetic lines.
Mobil 1 is grouped into 6 basic types of synthetic. Mobil 1 Annual Protection, Mobil 1, Mobil 1 Extended Performance, Mobil 1 Advanced Fuel Economy, Mobil 1 High Mileage, and Mobil 1 Emission System Protection.
The Mobil 1 oil is has shown to be a high quality oil for all engines. It is available from 0W40, 5W20, 5W30, 10W30, and 15W50.
Mobil 1 Advanced Fuel Economy: Is a great oil as well shown to be superior in quality to the Mobil 1 on a few occasions. It is available only a 0W20 or 0W30. This oil has all the benefits of the 5W20 or 5W30 oil respectively but offers cold weather operation and reduces cold start wear. This is the oil I used to run in all of my cars.
Mobil 1 Annual Protection: A higher end oil from Mobil 1. It is designed to be used for extended drains of up to 20K miles or 1 year. Available in 0W20, 5W20, and 5W30.
Mobil 1 Emission System Performance: A newer oil which is specifically engineered for modern diesel and gasoline engines with emission systems components like modern diesel particulate filters and catalytic converters in mind. Available in 0W30 and 5W30.
Mobil 1 Extended Performance: A higher end oil from Mobil 1. It is designed to be used for extended drains of up to 15K miles. Available in 0W20, 5W20, 5W30, and 10W30.
Mobil 1 High Mileage: For use in vehicles with over 75K miles. Has more seal conditioners, anti-wear additives, and detergents than other Mobil 1 oils. Available as a 5W30, 10W30, and 10W40.
Product data sheets:
M1 AFE 0W20: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-20_Advanced_Fuel_Economy.aspx
M1 AFE 0W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-30_Advanced_Fuel_Economy.aspx
M1 AP 0W20, 5W20, 5W30: https://www.mobil.com/English-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-Annual-Protection
M1 0W40: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx
M1 5W20: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_5W-20.aspx
M1 5W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_5W-30.aspx
M1 10W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_10W-30.aspx
M1 15W50: http://www.mobil.com/USA-English/Lubes/PDS/NAUSENPVLMOMobil1_15W-50.aspx
M1 ESP 0W30: http://www.mobil.com/english-US/Passenger-Vehicle-Lube/pds/NAXXMobil-1-ESP-X1-0W30
M1 ESP 5W30: http://www.mobil.com/english-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-ESP-Formula-5W30
M1 EP 0W20, 5W20, 5W30, 10W30: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Extended_Performance.aspx
M1 HM 5w30: http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
M1 HM 10W30: http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
M1 HM 10W40: http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
Pennzoil Platinum: Pennzoil's line of synthetic motor oil. The newest formulations are made from compressed natural gas, and are some of the cleanest oils available today. These oils, like many others, are made by SOPUS.
Pennzoil Platinum is now grouped into 3 basic types of synthetic oils: Pennzoil Platinum, Pennzoil Platinum High Mileage, and Pennzoil Ultra Platinum.
Pennzoil Ultra Platinum: Even better than Pennzoil Platinum. Claims to be 25% cleaner than Mobil 1, 35% cleaner than Valvoline SynPower, and 40% Cleaner than Castrol Edge with Syntec. Available in 0W-20, 0W40, 5W-20, 5W-30, and 10W-30.
Pennzoil Platinum: It is dubbed as one of the cleanest oils claiming to be 8% cleaner than Mobil 1, 17% Cleaner than Valvoline, and 20% Cleaner than Castrol. This is supposed to be a great oil for cleaning out your engine of varnish.
This oil comes in 4 basic sub-types: US, Euro, Euro Diesel, and Racing. The Euro diesel is specifically engineered for European diesel engines and includes:
Euro L: For gasoline engines or DPF (Diesel Particulate Filter) equipped diesel engines. Is ACEA C3 and Dexos approved.
Euro LX: Thinner variant of the Euro L that is ACEA C2/C3 approved.
Euro AV: Specifically engineered for high performance and TDI diesel engines. It has surpassed the requirements for VW and Peugot in house testing.
US is available in 0W-20, 5W-20, 5W-30, and 10W-30.
Euro is available in 0W30, 5W30, and 5W40
Euro L is available in 5W30
Euro LX is available in 0W30
Euro AV is available in 5W30
Racing is available in 10W60
Pennzoil Platinum High Mileage: For use in vehicles with over 75K miles. Has more seal conditioners, anti-wear additives, and detergents than other Pennzoil Platinum oils. This has become the go to oil for my fleet. Available in 5W20 and 5W30.
Pennzoil Ultra Platinum 0W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058458374/a315706a73d123b58828855fb6994dfc8a4dd3924dd8c4c4528632e56fb447db/Pennzoil-Ultra-Platinum-0W-20.pdf
Pennzoil Ultra Platinum 0W40: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058459415/cbaf42eae4dcbcd08bee4f669a8ee71a73584bf793056ec459c9cdd99445c116/Pennzoil-Ultra-Platinum-0W-40.pdf
Pennzoil Ultra Platinum 5W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058460104/c75c1494cc249bacf05b4f2da5c205b59d8dd8bd052c1e33e0d4b87161df05f9/Pennzoil-Ultra-Platinum-5W-20.pdf
Pennzoil Ultra Platinum 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058460926/206444cb877e3961f436c35ca2fb4560ebc862ecd9e5be9cb14fa15e88aa7517/Pennzoil-Ultra-Platinum-5W-30.pdf
Pennzoil Ultra Platinum 10W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-ultra-platinum/_jcr_content/productDetails.stream/1460058460214/9134574b6083111b75591aa2e70f66f34897b6029b7ff22cd4fe1b8de9116153/Pennzoil-Ultra-Platinum-10W-30.pdf
Pennzoil Platinum US 0W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058452796/ed3e433f9944b98910d0992a166dabefe5bb9422ae327a1253133dd2c60e751d/Pennzoil-Platinum-SAE-0W-20-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum US 5W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058454670/051b99d9a2e384330f91c740627502eb6b50a31ff803a838cd360f2efaa05fb5/Pennzoil-Platinum-SAE-5W-20-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum US 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058453075/73d957b370df2e49693e82ece9a0a5bb2f048868be34afadaf2c488ca81a57a5/Pennzoil-Platinum-SAE-5W-30-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum US 10W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1460058453505/81fce27fbfd53df17f24ef87c5723be40524d3e444f413ad35ccb21b7a4db077/Pennzoil-Platinum-SAE-10W-30-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum Euro 0W40: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815774/9f159ce8e902186deb64de107a2ec7b145e2a590d58d67c61e9d5399c1d875ee/Pennzoil_Platinum_Euro_SAE_0W-40_Full_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815731/33fd0db5f1226a42250ae0173f226ec995ccb5b1fb918d5f42a0f90ca641e61d/Pennzoil_Platinum_Euro_5W-30.pdf
Pennzoil Platinum Euro 5W40: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815565/a70e5779bc5c118d413f463890e816788dbfa1e92705df46265999796dfa4bb5/Platinum_Euro_SAE_5W-40_Full_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro L 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815811/38dd048487367f3433017e5a97b45db965c1328c7aad05e4399ee75a60ad9958/Platinum_Euro_L_SAE_5W-30_Fully_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro LX 0W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461698815640/df24ad43161f07dd0f6d2b935a6b483df556854b85d6a6790c36facdbaa99ca7/Platinum_Euro_LX_SAE_0W-30_Fully_Synthetic_Motor_Oil.pdf
Pennzoil Platinum Euro AV 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461707990494/2dc7a607b7a293a77794d06f3de890f6addc2931b97929d71eeb8d37c7c8ce46/Pennzoil-Euro-AV-SAE-5W-30.pdf
Pennzoil Platinum Racing 10W60: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum/_jcr_content/productDetails.stream/1461707989149/7142e42ade7f0e7917afd2c5b927da5ec07217b29d873f0a41be498550c2dfc1/Pennzoil-Platinum-Racing-10W-60.pdf
Pennzoil Platinum High Mileage 5W20: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/platinum-high-mileage/_jcr_content/productDetails.stream/1460058451538/353b0b70a22379d806d88d91afe221542ce985556329f0d22f2ea5ae38374342/Pennzoil-Platinum-High-Mileage-SAE-5W-20-Full-Synthetic-Motor-Oil.pdf
Pennzoil Platinum High Mileage 5W30: http://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/platinum-high-mileage/_jcr_content/productDetails.stream/1460058451820/c138f531548b65034bf93a6adb326d18e97cd458da7956caf5bae4bc9eb917a6/Pennzoil-Platinum-High-Mileage-SAE-5W-30-Full-Synthetic-Motor-Oil.pdf
Quaker State: Another high quality oil made by SOPUS.
Ultimate Durability: Some say this stuff is the same as Pennzoil Platinum in certain grades, while some say it's slightly different with a slight edge for the Platinum. The oil is marketed as highly durable with superior anti-wear properties. Available in the same grades as Pennzoil Platinum 0W20, 5W20, 5W30, 10W30, and 5W50.
Product Data Sheet: http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140003587117_201007020129.pdf
Valvoline: Another highly touted oil. Valvoline Synthetics are now grouped into two basic types of synthetic oils: Valvoline Syn Power and Valvoline Full Synthetic High Mileage with Maxlife Technology.
Syn-Power: The oil is marketed as highly durable with superior anti-sludge and deposit properties. Available in 0W20, 5W20, 5W30, 5W40, 10W30, and 20W50
Product Data Sheet: http://www.valvoline.com/pdf/synpower.pdf
Full Synthetic High Mileage with Maxlife Technology: Valvoline's newest synthetic oil. It is marketed as highly durable with superior anti-wear properties, claiming to provide 40% more anti-wear film than Mobil 1. Available in 0W20, 5W20, 5W30, and 10W30.
Product Data Sheet: http://content.valvoline.com/pdf/valvoline_full_synthetic_with_maxlife_technology.pdf
Castrol: Some say this a synthetic blend while some say its full synthetic. Nonetheless a very popular oil.
Edge with Syntec: Available in 0W20, 0W30, 5W20, 5W30, 5W40, 5W50, 10W30, and 10W40.
Product Data Sheet here: http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/Edge_BLACK_PDS_Sept_2011.pdf
Amsoil: Touted often as the absolute best and only oil that should be used. This oil is high quality from my research but the price, distribution network, and only me attitude make it an outcast.
Amsoil Signature Series: Available in 0W20, 0W30, 5W20, 5W30, and 10W30.
0W20: http://www.amsoil.com/storefront/asm.aspx
0W30: http://www.amsoil.com/storefront/azo.aspx
5W20: http://www.amsoil.com/storefront/alm.aspx
5W30: http://www.amsoil.com/storefront/asl.aspx
10W30: http://www.amsoil.com/storefront/atm.aspx
Royal Purple: Yet another high quality synthetic oil. Available more places than Amsoil, this oil has a loyal following of hard core enthusiasts.
HPS: Available in 0W-20, 0W-40, 5W-20, 5W-30, 5W-40, 10W-30, 10W-40, 15W-40 and 20W-50.
Product explanation sheet: http://www.royalpurpleconsumer.com/wp-content/uploads/PS_API_MotorOIl.pdf
Antifreeze/Coolant:
Coolant brings about more arguments than any fluid except maybe motor oil. The only real requirement is that the coolant be a P-HOAT (Phosphated Hybrid Organic Acid Technology) coolant that does not contain 2EHA (Dexcool or Dexclones), silicates, amines, or borates. I am an avid user of Toyota Pink and Zerex Asian Vehicle coolant. Other highly recommended coolants include Toyota Red Concentrate, Honda Type 2 (Honda Blue), Pentofrost A1 (Red), Pentofrost A2 (Green), Pentofrost A3 (Blue), Pentofrost A4 (Pink), Beck/Arnley Premium Extended Life Pink, Beck/Arnley Premium OE Extended Life Blue, Beck/Arnley Premium OE Red Concentrate, Beck/Arnley Premium OE Green Concentrate, Reochem OEM Premium Extended Life Red, Reochem OEM Premium Extended Life Pink, Reochem OEM Premium Extended Life Blue, and many other OEM coolants. Replace every 60-80K.
Note: With Pentofrost and Beck/Arnley, the only real differences between each of their individual coolants is the color, as the specs are identical between them.
Here are some data sheets/MSDS sheets:
Toyota/Aisin: Toyota and Aisin coolants are exactly the same product.
Super Long Life Coolant (Pink) - http://www.worldpac.com/tagged/Antifreeze-Coolant_00272SLLC2.pdf
Long Life Coolant (Red) - http://www.worldpac.com/tagged/Antifreeze-Coolant_002721LLAC.pdf
Aisin Super Long Life Pink - http://aisinaftermarket.com/uploads/4jetto45_AISIN_ANTIFREEZE_COOLANT_FEATURES_AND_BENEFITS_.pdf
Honda:
Type 2 (Honda Blue) - http://www.worldpac.com/tagged/Coolant_-_Honda.pdf
Zerex:
Asian Vehicle Formula - http://www.valvoline.com/pdf/zerex_asian_vehicle.pdf
Pentosin Pentofrost:
A1 (Red) - http://www.pentosin.net/specsheets/Pentofrost_spec_A1.pdf
A2 (Green) - http://www.pentosin.net/specsheets/Pentofrost_spec_A2.pdf
A3 (Blue) - http://www.pentosin.net/specsheets/Antifreeze_Pentofrost A3_Aug13.pdf
A4 (Pink) - http://www.pentosin.net/specsheets/Antifreeze_Pentofrost A4_Aug13.pdf
Beck/Arnley:
Extended Life Blue and Extended Life Pink - http://customerportal.fmpco.com/fmpnext/pdf/252-1501U Blue Coolant.pdf
Red Concentrate - http://www.maxmarketing.com/beckarnley/AC_Red_Chemical_Product_Data_Sheet NEW.pdf
Green Concentrate - http://www.maxmarketing.com/beckarnley/AC_Green_Chemical_Product_Data_Sheet.pdf
Reochem OEM Premium:
Extended Life Red - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_RED_86-374ROEM_R.pdf
Extended Life Pink - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_PINK_86-174POEM.pdf
Extended Life Blue - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_BLUE_86-174BOEM_B.pdf
Extended Life Green - http://www.recochem.com/us/media/uploads/downloads/OEM_CC_VC_GREEN_86-374GROEM.pdf
Transmission Fluid for A/T:
Another hot topic. I like Valvoline Maxlife the most for both T-IV and WS applications.
Toyota/Lexus Type T-IV: This fluid is made by Mobil and is called several names. It is sold as Mobil JWS3309, Audi/Volkswagon G-055-025-A2, Ford WSS-M2C924-A, GM GM9986195, Saab 3309. This is a synthetic blend fluid and should be replaced every 30K miles by drain and fill.
Product data sheet: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_ATF_3309.aspx
Castrol:
Castrol TransMax Full Synthetic Multi-Vehicle ATF: Meets the JASO-1A requirements for Toyota Type T-IV. Fully synthetic fluid which is likely a response to Valvoline Maxlife Dex/Merc as a low viscosity modern ATF. It likely also works for WS but doesn't directly say so (says recommended for all Toyota transmissions).
Product Data sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/09DFBB064CCF193E80257BA5006EB93F/$File/BPXE-99LBRT.pdf
Castrol Import TransMax Multi-Vehicle: Specifically made for import vehicles it meets the JASO-1A requirements for Toyota Type T-IV. Also a synthetic blend. Replace it every 30K.
Product Data sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4B94307E61A0AF6480257ADD007535BA/$File/Transmax Import MV PDS.pdf
Castrol TransMax High Mileage Multi-Vehicle ATF: Meets the JASO-1A requirements for Toyota Type T-IV. A high mileage fluid that claims to have additional seal conditioners and cleaning agents for higher mileage transmissions. Likely a synthetic blend.
Product Data sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/99010A169D77FF8C802579A200456CFB/$File/Castrol Transmax High Mileage PDS Am.pdf
Valvoline:
Valvoline MaxLife Dex/Merc: Fully synthetic, highly recommended and highly rated. This ATF is recommended even in WS transmissions and is my go to fluid for any Toyota transmission service.
http://www.valvoline.com/pdf/maxlife_atf.pdf
Valvoline Import Multi-Vehicle ATF: Now similar in formulation to Castrol Import Multi-Vehicle ATF with around a 1 cSt lower viscosity (6.9 vs 8). Fully synthetic fluid still and likely a good alternative to the Castrol Import which is more easily found in quart bottles. This fluid is sold at lots of places in the 1 gallon bottles. Highly recommended. This fluid is no longer WS compatible, unless it specifically says so on the back of the bottle due to a formulation change.
Product Data Sheet: http://www.valvoline.com/pdf/multi_vehicle_atf.pdf
Redline:
D4 ATF: Very highly rated boutique ATF that is recommended to replace with T-IV. I haven't found a single negative review on this stuff. However don't be confused. This ATF is comparatively very expensive (2-3 times the cost of Valvoline Maxlife per gallon).
D6 ATF: Just as highly rated as the D4, except for newer WS applications. This is a low viscosity modern ATF comparable to Maxlife and Dexron VI.
Product Data Sheets: http://www.redlineoil.com/content/files/tech/ATF PDS 2-10.pdf
Amsoil:
Signature Series Multi-Vehicle Synthetic ATF (ATF): Very highly rated boutique ATF that is recommended to replace with T-IV. I haven't found a single negative review on this stuff either. However don't be confused. Like Redline, this ATF is comparatively very expensive (2-3 times the cost of Valvoline Maxlife per gallon).
Signature Series Fuel Efficient Synthetic ATF (ATL):
Another highly rated boutique ATF just like the Multi-Vehicle Synthetic, except it's for WS applications. This is a low viscosity modern ATF comparable to Maxlife and Dexron VI.
Product Data Sheets: http://www.amsoil.com/lit/databulletins/g3110.pdf
Gear Oil for M/T:
Most agree on a few good oils. Toyota manual tranmissions need to have a GL4 oil to prevent damage to the yellow metal inside the transmission. Synthetic gear oil is amazing and works great in the cold for smooth buttery shifts. Replace all every 30K.
Redline MT90: My favorite. Available on Amazon or from Redline for about 13 bucks a quart.
Product Data sheet: http://www.redlineoil.com/product.aspx?pid=46&pcid=7
Amsoil Synthetic Manual Transmission oil: Another highly recommended yellow metal safe oil.
Product data sheet: http://www.amsoil.com/storefront/mtg.aspx
Mobil, Valvoline, and Castrol do not specify or list a GL4 compatibile gear oil.
Power Steering Fluid:
Replace every 2-3 years. The power steering requires any Dexron compatible ATF as opposed to the clear generic stuff. I prefer to use Valvoline Maxlife or Castrol Transmax. You can however use any Dexron compatible ATF you wish (I have even used Toyota T-IV with great results).
Brake Fluid:
Replace every 2-3 years. I prefer to use any available synthetic I can find at the auto parts store such as Wearever, Prestone, or Valvoline. Other high quality "boutique" fluids like Motul or other name brands may not be worth the cost for a daily driven car.
Brake Pads, Shoes, and Rotors:
Not all brakes are created equal. Rotor quality and pad quality can mean the difference between squeaks or brake fade in emergencies or stop and go driving. OEM pads are low dust ceramic in the front. I highly recommend using the OEM hardware when doing a brake job.
Pads and Shoes:
OEM Toyota: The OEM pads and shoes equipped on your vehicle. These are very high quality low dust pad usually made by either Sumitomo, Advics, Hitachi, or Akebono. I went over 120K miles on my OEM Toyota pads.
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - 04465-33240
2005-2006 V6 SE/XLE only - 04465-08030 or 04465-33350
Gen 6 - 04465-33471 or 04465-07010
Solara
Gen 2 - 04465-08030 or 04465-33350
Rear:
Camry
Gen 5 -
Disc:
I4 and V6 2002-2006 USA Build - 04466-06030
I4 and V6 2003-2006 Japan Build - 04466-33140
V6 2002-2006 Japan Build - 04466-33090
Drum:
2002-2004 I4 Base and LE - 04495-33010 or 04495-33030
2005-2006 I4 Base and LE - US Built: 04495-06040 Japan Built: 04495-33070
Gen 6 - 04466-06090 with Composition marking "FF"
Solara
Gen 2 - 04466-06030
Akebono: Very high quality replacement pads. Akebono makes OEM pads for Toyota and other manufacturers and offers 2 high quality pad lines. The hardware is generic and I prefer OEM hardware. I have used these several times with great results.
ProACT: http://www.rockauto.com/catalog/moreinfo.php?pk=1144658&cc=1442322
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - ACT908
2005-2006 V6 SE/XLE only - ACT906A
Gen 6 - ACT1222
Solara
Gen 2 - ACT906A
Rear:
Camry
Gen 5 -
USA Build - ACT828
Japan Build - ACT885
Gen 6 - ACT1212
Solara
Gen 2 - ACT828
Performance Ultra Premium Ceramic Pad: http://www.rockauto.com/catalog/moreinfo.php?pk=4495356&cc=1442322
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - ASP908
Gen 6 - ASP1222
Rear:
Camry
Gen 6 - ASP1212
ADVICS: Another high quality OEM pad maker for Toyota and others.
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - AD0908
2005-2006 V6 SE/XLE only - AD0906A
Gen 6 - AD1293
Solara
Gen 2 - AD0906A
Rear:
Camry
Gen 5 -
Japan Build - AD0885
Gen 6 - AD1212
Beck/Arnley: Beck/Arnley offers a few different lines of brake pads. I will only focus on the OEM Pad line which is literally a rebox of mostly the factory Sumitomo, Advics, Hitachi, or Akebono pads in a Beck/Arnley box. These pads are highly recommended.
OE Pads:
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - 089-1657
2005-2006 V6 SE/XLE only - 089-1679
Gen 6 - 089-1758
Solara
Gen 2 - 089-1679
Rear:
Camry
Gen 5 -
Disc:
USA Build - 089-1647
Japan Build - 089-1659
Drum:
2002-2004 I4 Base and LE - 081-2230
2005-2006 I4 Base and LE - US Built: 081-3252
Gen 6 - 089-1756
Solara
Gen 2 - 089-1647
Centric: Centric offers 3 Ceramic pad lines. One Posi-Quiet premium in house line ,another OEM line where they rebox OEM pads, and a high performance StopTech line.
Posi-Quiet Premium: http://www.rockauto.com/catalog/moreinfo.php?pk=1277584&cc=1433062
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - 106.09080
2005-2006 V6 SE/XLE only - 106.09060
Gen 6 - 105.12930
Solara
Gen 2 - 106.09060
Rear:
Camry
Gen 5 -
USA Build - 106.08280
Japan Build - 106.08850
Gen 6 - 10512120
Solara
Gen 2 - 106.08280
"100 Series" OE Formula Pads:
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - 100.09080
2005-2006 V6 SE/XLE only - 100.09060
Gen 6 - 100.12930
Solara
Gen 2 - 100.09060
Rear:
Camry
Gen 5 -
Japan Build - 100.08850
Gen 6 - 100.12120
StopTech High Performance: Comparable to EBC and Hawk, these High Performance pads are raved about for their performance and driveability.
http://www.rockauto.com/catalog/moreinfo.php?pk=2022444&cc=1433059
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - 309.09080
EBC: Comparable to the Centric line, these High Performance pads are raved about for their performance and driveability.
Note: EBC recommends to NOT upgrade the rear brake pads unless the SAME upgrade is fitted to the front to avoid brake imbalance. What this means is make sure that the rear brakes are not higher friction than the front.
Ultimax2: http://ebcbrakes.com/product/ultimax-brake-pads/ High quality OEM replacement pads with the "much coveted" GG friction rating.
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - UD908
2005-2006 V6 SE/XLE only - UD906
Solara
Gen 2 - UD906
Rear:
Camry
Gen 5 -
USA Build - UD828
Japan Build - UD885
Solara
Gen 2 - UD828
Green Stuff Sport: http://ebcbrakes.com/product/greenstuff-brake-pads/ "Greenstuff pads deliver improved stopping power with zero noise and normal lifetime."
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - DP21642
2005-2006 V6 SE/XLE only - DP21674
Gen 6 - DP21790
Solara
Gen 2 - DP21674
Rear:
Camry
Gen 5 -
USA Build - DP21715
Japan Build - DP21715
Gen 6 - DP21793
Solara
Gen 2 - DP21715
Red Stuff Fast: http://ebcbrakes.com/product/redstuff-brake-pads/ "Redstuff Ceramic pad for higher speed driving... deliver zero noise and extended lifetime."
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - DP31642C
2005-2006 V6 SE/XLE only - DP31674C
Gen 6 - DP31790C
Solara
Gen 2 - DP31674C
Rear:
Camry
Gen 5 -
USA Build - DP31715C
Japan Build - DP31716C
Gen 6 - DP31793C
Solara
Gen 2 - DP31715C
Yellow Stuff Race: http://ebcbrakes.com/product/yellows...nd-track-pads/ "For extended race use."
Front:
Camry
Gen 5 -
2005-2006 V6 SE/XLE only - DP41674R
Solara
Gen 2 - DP41674R
Rear:
Camry
Gen 5 -
USA Build - DP41715R
Japan Build - DP41716R
Solara
Gen 2 - DP41715R
Hawk: Comparable to EBC and StopTech these High Performance pads are raved about for their performance and driveability.
http://www.hawkpadsdirect.com/Hawk-Performance-HPS-High-Performance-Street-Brake-Pads-s/11.htm
HPS Street Pads:
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - HB474F.681
Gen 6 - HB647F.692
Rear:
Camry
Gen 6 - HB648F.607
Wagner: Thermoquiet are the premium Wagner line. Good overall reviews online as well. Apparently they are the number one global pad manufacturer.
http://www.rockauto.com/catalog/moreinfo.php?pk=369443&cc=1433062
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - QC908 w/hardware PD908 w/out hardware
2005-2006 V6 SE/XLE only - QC906 w/hardware PD906 w/out hardware
Gen 6 - QC1293 w/hardware PD1293 w/out hardware
Solara
Gen 2 - QC906 w/hardware PD906 w/out hardware
Rear:
Camry
Gen 5 -
USA Build - QC828 w/hardware PD828 w/out hardware
Japan Build - QC885 w/hardware PD885 w/out hardware
Gen 6 - QC1212 w/hardware PD1212 w/out hardware
Solara
Gen 2 - QC828 w/hardware PD828 w/out hardware
Wearever: Another very commonly used brake pad. Available in 4 lines I will touch only on the Gold and Ceramic lines for pads.
Gold: High quality ceramic pad that does not include hardware. Lifetime warranty
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - GNAD908
2005-2006 V6 SE/XLE only - GNKD906 (I do not recommend these Semi-Metallic pads as a replacement for Ceramic)
Gen 6 - GNAD1293
Solara
Gen 2 - GNKD906 (I do not recommend these Semi-Metallic pads as a replacement for Ceramic)
Rear:
Camry
Gen 5 -
USA Build - GNAD828
Japan Build - GNAD885
Gen 6 - GNAD1212
Solara
Gen 2 - GNAD828
Platinum: High quality ceramic pad that includes hardware and moly brake lube. I have used these with great results.
Front:
Camry
Gen 5 -
All 2002-2004 I4/V6 and 2005-2006 I4 and V6 LE only - PNAD908
2005-2006 V6 SE/XLE only - PNAD906
Gen 6 - PNAD1293
Solara
Gen 2 - PNAD906
Rear:
Camry
Gen 5 -
USA Build - PNAD828
Gen 6 - PNAD1212
Solara
Gen 2 - PNAD828
There are several other manufacturers of brake pads and shoes including: Bendix, Monroe, Midas, Raybestos, etc., that are either reboxes or similar quality. This list is not all inclusive but should provide a guide for good quality pads and shoes.
Brake Rotors:
Note: Some manufacturers list both stepped and plain hat rotors for the V6 SE/XLE Gen 5 Camry. Some manufacturers list only one type of rotor for all applications.
It appears that Toyota went as follows for their rotors:
2002 Models - Plain or stepped hat style.
2003-2004 Models - Stepped hat style.
2005-2006 Models - Plain hat style.
Some rotor manufacturers like Centric list the plain style as a 2002-2006 rotor and the stepped as a 2002-2004 listing. This leads me to believe that both rotors are interchangeable. Additionally, both rotors are 296mm by If all else fails, use the plain hat style rotor as it is the style that was used on the newest versions. Know that both rotors are 296mm wide and around 49mm tall. Until someone shows otherwise, it appears they will both work.
The Solara and V6 XLE/SE V6 Camry use the same front rotors. All Solara models list the later plain hat style.
OEM Toyota: High quality rotors that can be expected from an OEM manufacturer.
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - 43512-06040/43512-33090
V6 SE/XLE models - 43512-48011 (stepped hat) or 43512-08040 (plain hat)
Gen 6: 43512-06090
Solara
Gen 2: 43512-48011 (stepped hat) or 43512-08040 (plain hat)
Gen 5 Camry and Gen 2 Solara: 42431-06051
Gen 6 Camry: 42431-33130/42431-06110
Solara
Advics: Very high quality rotors from an OEM manufacturer. Advics claims that these rotors are made with identical materials and processes as the factory Toyota and Lexus rotors specifically.
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - A6F053
V6 SE/XLE models - A6F055 (plain hat)
Gen 6: A6F063
Solara
Gen 2: A6F055 (plain hat)
Rear -
Gen 6 Camry: A6R044
Beck/Arnley: Another high quality premium rotor. I have used these with good results. http://www.rockauto.com/catalog/moreinfo.php?pk=2237620&cc=1442326&jnid=1047&jpid=11
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - 083-2450
V6 SE/XLE models - 083-2820 (stepped hat) or 083-2940 (plain hat)
Gen 6: 083-3163
Solara
Gen 2: 083-2820 (stepped hat) or 083-2940 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: 083-2934
Gen 6 Camry: 083-3161
Centric: Centric offers many different rotors from a standard all the way to a drilled and slotted StopTech rotor. Higher models feature a corossion resistant E-coating. These are my preferred choice when OEM are too much.
C-TEK Standard: Standard Rotor
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - 121.44079
V6 SE/XLE models - 121.44088 (stepped hat) or 121.44125 (plain hat)
Gen 6: 121.44146
Solara
Gen 2: 121.44088 (stepped hat) or 121.44125 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: 121.44126
Gen 6 Camry: 121.44144
Premium: http://www.rockauto.com/catalog/moreinfo.php?pk=2028592&cc=1433059
Front:
Camry
Gen 5:
All other models except V6 SE/XLE - 120.44079 without cryogenically treated 120.44079 CRY with cryogenically treated
V6 SE/XLE models - 120.44088 (stepped hat) or 120.44125 (plain hat)
Gen 6: 120.44146
Solara
Gen 2: 120.44088 (stepped hat) or 120.44125 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: 120.44126
Gen 6 Camry: 120.44144
High Carbon Alloy: http://www.rockauto.com/catalog/moreinfo.php?pk=2043528&cc=1433059
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - 125.44079
V6 SE/XLE models - 125.44125 (plain hat)
Solara
Gen 2:
StopTech: http://www.rockauto.com/catalog/moreinfo.php?pk=1616284&cc=1433059
Front -
Camry
Gen 5:
Drilled - 128.44079L 128.44079R w/out cryogenic treatment 128.44079CL 128.44079CR w/ cryogenic treatment
Slotted - 126.44079SL 126.44079SR w/out cryogenic treatment 126.44079CSL 126.44079CSR w/ cryogenic treatment
Drilled and Slotted - 127.44079L 127.44079R w/out cryogenic treatment 127.44079CL 127.44079CR w/ cryogenic treatment
V6 SE/XLE -
Plain Hat:
Drilled - 128.44125L 128.44125R w/out cryogenic treatment 128.44125CL 128.44125CR w/ cryogenic treatment
Slotted - 126.44125SL 126.44125SR w/out cryogenic treatment 126.44125CSL 126.44125CSR w/ cryogenic treatment
Drilled and Slotted - 127.44125L 127.44125R w/out cryogenic treatment 127.44125CL 127.44125CR w/ cryogenic treatment
Stepped Hat:
Drilled - 128.44088L 128.44088R w/out cryogenic treatment 128.44088CL 128.44088CR w/ cryogenic treatment
Slotted - 126.44088SL 126.44088SR w/out cryogenic treatment 126.44088CSL 126.44088CSR w/ cryogenic treatment
Drilled and Slotted - 127.44088L 127.44088R w/out cryogenic treatment 127.44088CL 127.44088CR w/ cryogenic treatment
Gen 6:
Drilled - 128.44146L 128.44146R w/out cryogenic treatment 128.44146CL 128.44146CR w/ cryogenic treatment
Slotted - 126.44146SL 126.44146SR w/out cryogenic treatment 126.44146CSL 126.44146CSR w/ cryogenic treatment
Drilled and Slotted - 127.44146L 127.44146R w/out cryogenic treatment 127.44146CL 127.44146CR w/ cryogenic treatment
Solara
Gen 2:
Plain Hat:
Stepped Hat:
Rear -
Drilled - 128.44126L 128.44126R w/out cryogenic treatment 128.44126CL 128.44126CR w/ cryogenic treatment
Slotted - 126.44126SL 126.44126SR w/out cryogenic treatment 126.44126CSL 126.44126CSR w/ cryogenic treatment
Drilled and Slotted - 127.44126L 127.44126R w/out cryogenic treatment 127.44126CL 127.44126CR w/ cryogenic treatment
Gen 6 Camry:
Drilled - 128.44144L 128.44144R w/out cryogenic treatment 128.44144CL 128.44144CR w/ cryogenic treatment
Slotted - 126.44144SL 126.44144SR w/out cryogenic treatment 126.44144CSL 126.44144CSR w/ cryogenic treatment
Drilled and Slotted - 127.44144L 127.44144R w/out cryogenic treatment 127.44144CL 127.44144CR w/ cryogenic treatment
Brembo: Brembo blanks are the only choice for some owners. High quality Brembo blanks are comparable to OEM quality. Watch out for fakes.
http://brembo.mycarparts.net/products/Brembo-09955921?product_application_id=2247037876
Front -
Camry
Gen 5:
Part Number - 09.A386.10 (not painted) 09.A386.11 (painted) / 5 Digit Brembo Part Number - 25358
V6 SE/XLE models -
Stepped Hat: Part number - 09.A110.10 (not painted) or 09.A110.11 (painted) / 5 Digit Brembo Part Number - 25533
Plain Hat: Part Number - 09.B452.10 (not painted) or 09.B452.11 (painted) / 5 Digit Brembo Part Number - 25856
Gen 6:
Part Number - 09.A417.10 (not painted) or 09.A417.11 (painted) 5 Digit Brembo Number - 25961
Solara
Gen 2:
Rear -
Gen 5 Camry and Gen 2 Solara: Part Number - 08.A108.10 / 5 Digit Brembo Number - 25857
Gen 6 Camry: Part Number - 08.B566.10 / 5 Digit Brembo Number - 25964
EBC: High quality rotors for street and sport applications.
UPR Series: High quality replacement blanks.
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - UPR741
V6 SE/XLE models - UPR7227 (stepped hat) or UPR7223 (plain hat)
Gen 6: UPR7387
Solara
Gen 2: UPR7227 (stepped hat) or UPR7223 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: UPR7339
Gen 6 Camry: UPR7412
GD Series Rotor: High Quality Cross Drilled Rotors
http://ebcbrakes.com/product/3gd-sport-rotors/
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - GD741
V6 SE/XLE models - GD7227 (stepped hat) or UPR7223 (plain hat)
Gen 6: GD7387
Solara
Gen 2: GD7227 (stepped hat) or UPR7223 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: GD7339
Gen 6 Camry: GD7412
USR Series: High Quality Slotted Rotors
http://ebcbrakes.com/product/usr-slotted-rotors/
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - USR741
V6 SE/XLE models - UPR7227 (stepped hat) or USR7223 (plain hat)
Gen 6: USR7387
Solara
Gen 2: UPR7227 (stepped hat) or USR7223 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: USR7339
Gen 6 Camry: USR7412
Duralast: Autozone rotors. I have used them for years with no issues.
Duralast Standard:
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - 31260
V6 SE/XLE models - 31266 (stepped hat)
Gen 6: 44582
Solara
Gen 2: 31266 (stepped hat)
Rear -
Gen 5 Camry and Gen 2 Solara: 31322
Gen 6 Camry: 44581
Duralast Gold: Allegedly these are high carbon steel rotors. They also have an E-Coating for rust prevention.
Gen 5:
Camry
All other models except V6 SE/XLE - 31260DG
V6 SE/XLE models - 31266DG (stepped hat)
Gen 6: 44582DG
Solara
Gen 2: 31266DG (stepped hat)
Rear -
Gen 5 Camry and Gen 2 Solara: 31322DG
Gen 6: 44581DG
Wagner: Pretty standard Rotor
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - BD125612 or BD125612E w/ E-Coating
V6 SE/XLE models - BD126059 or BD126059E w/ E-Coating (stepped hat )
Gen 6: BD126407
Solara
Gen 2: BD126059 or BD126059E w/ E-Coating (stepped hat)
Rear -
Gen 5 Camry and Gen 2 Solara: BD126087
Gen 6 Camry: BD126489
Wearever: Another pretty standard rotor. I got two really bad sets of these and can no longer really recommend them, however the part number is here for your information.
Front -
Camry
Gen 5:
All other models except V6 SE/XLE - YH141723
V6 SE/XLE models - YH145324 (stepped hat) or YH145471 (plain hat)
Gen 6: YH145713
Solara
Gen 2: YH145324 (stepped hat) or YH145471 (plain hat)
Rear -
Gen 5 Camry and Gen 2 Solara: YH145411
Gen 6 Camry: YH145712
Super Moderator
2005 Corolla CE
Discussion Starter #2 (Edited)
Chassis and Suspension Parts
These cars have pretty high quality parts from the factory. As they get up in age and mileage, these parts may wear out. In general, OEM parts are the highest quality, though they cost a considerable amount more.
Note: Toyota changed the strut design on Camry models between 2003 and 2004 depending on the build location. You will need to verify your build location and build date by the door jamb or VIN to ensure you get the correct struts for Gen 5/Gen 5.5 models. Toyota changed the strut design on Solara models between 2005 and 2006. You will need to verify your build date by the door jamb or VIN to ensure you get the correct struts for your Gen 2 Solara model.[/SIZE]
Strut Assemblies
OEM Toyota:
Camry
Front Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built LE/XLE I4: Left - 48520-A9110 and Right - 48510-A9190
2002-08/2003 US Built LE/XLE V6: Left - 48520-A9110 and Right - 48510-A9190
2002-06/2003 Japan Built LE/XLE I4: Left - 48520-39695 and Right - 48510-80147
2002-06/2003 Japan Built LE/XLE V6: Left - 48520-39695 and Right - 48510-80147
2002-08/2003 US Built SE I4: Left - 48520-A9120 and Right - 48510-A9200
2002-08/2003 US Built SE V6: Left - 48520-A9120 and Right - 48510-A9200
2002-06/2003 Japan Built SE I4: Left - 48520-39705 and Right - 48510-80148
2002-06/2003 Japan Built SE V6: Left - 48520-39705 and Right - 48510-80148
09/2003-2006 US Built LE/XLE I4: Left - 48520-A9250 and Right - 48510-A9390 Japan Built:
09/2003-2006 US Built LE/XLE V6: Left - 48520-A9250 and Right - 48510-A9390
07/2003-2006 Japan Built LE/XLE I4: Left - 48520-39565 and Right - 48510-80117
07/2003-2006 Japan Built LE/XLE V6: Left - 48520-39545 and Right - 48510-80108
09/2003-2006 US Built SE I4: Left - 48520-A9330 and Right - 48510-A9620
09/2003-2006 US Built SE V6: Left - 48520-39735 and Right - 48510-80165
07/2003-2006 Japan Built SE I4: Left - 48520-39735 and Right - 48510-80165
07/2003-2006 Japan Built SE V6: Left - 48520-39735 and Right - 48510-80165
Gen 6:
2007-2011 LE/XLE I4 - US Built and Japan Built: Left - 48520-09F40 and Right - 48510-09M90
2007-2011 SE I4 - US Built: Left - 48520-09F60 and Right - 48510-09N10
2007-2011 LE/XLE V6 - US Built and Japan Built: Left - 48520-09F70 and Right - 48510-09N20
2007-2011 SE V6 - US Built: Left - 48520-09F90 and Right - 48510-09N40
2007-2011 Hybrid - US Built: Left - 48520-09K00 and Right - 48510-09R40 Japan Built: Left - 48520-80104 and Right - 48510-80327
Rear Strut Only -
Gen 5/Gen 5.5:
2002-05/08/2003 US Built and Japan Built LE/XLE I4: Left - 48540-39605 and Right - 48530-80164
2002-08/2003 US Built LE/XLE V6: Left - 48540-39605 and Right - 48530-80164
2002-06/2003 Japan Built Built LE/XLE V6: Left - 48540-39605 and Right - 48530-80164
2002-08/2003 US Built and 2002-06/2003 Japan Built SE I4: Left - 48540-39615 and Right - 48530-80165
2002-08/2003 US Built SE V6: Left - 48540-39615 and Right - 48530-80165
2002-06/2003 Japan Built SE V6: Left - 48540-39615 and Right - 48530-80165
09/2003-2006 US Built and 07/2003-2006 Japan Built LE/XLE I4: Left - 48540-39465 and Right - 48530-39885
09/2003-2006 US Built LE/XLE V6: Left - 48540-39465 and Right - 48530-39885
07/2003-2006 Japan Built LE/XLE V6: Left - 48540-39465 and Right - 48530-39885
09/2003-2006 US Built and 07/2003-2006 SE I4: Left - 48540-39635 and Right - 48530-80196
09/2003-2006 US Built SE V6: Left - 48540-39635 and Right - 48530-80196
07/2003-2006 Japan Built SE V6: Left - 48540-39635 and Right - 48530-80196
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 48540-09660 and Right - 48530-09K70
2007-2011 SE I4 and V6 - US Built: Left - 48540-09680 and Right - 48530-09K90
2007-2011 Hybrid - US Built: Left - 48540-09810 and Right - 48530-09N60 Japan Built: Left - 48540-39795 and Right - 48530-80370
Solara
Gen 2:
Front Strut Only -
2004-11/2005 Coupe - Without Sport Package: Left 48520-A9400 and Right 48510-A9350 With Sport Package: Left 48520-A9230 and Right 48510-A9370
2004-11/2005 Convertible - Left 48520-A9240 and Right 48510-A9380
12/2005-2008 Coupe -Without Sport Package: Left 48520-A9410 and Right 48510-A9730 With Sport Package: Left 48520-A9420 and Right48510-A9740
12/2005-2008 Convertible - Left 48520-09J90 and Right 48510-09Q40
Rear Strut Only -
2004-11/2005 Coupe - Without Sport Package: Left 48540-A9280 and Right 48530-A9600 With Sport Package: Left 48540-A9290 and Right48530-A9610
2004-11/2005 Convertible - Left 48540-A9260 and Right 48530-A9230
12/2005-2008 Coupe - Without Sport Package: Left 48540-A9340 and Right 48530-A9660 With Sport Package: Left 48540-A9350 and Right48530-A9670
12/2005-2008 Convertible - Left 48540-09840 and Right 48530-09P30
KYB: High quality replacements. KYB makes most struts and shocks for Toyota models.
Camry
Front Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 334339 and Right - 334338
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 334387 and Right - 334386
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 339024 and Right - 339023
2007-2011 SE I4 and V6 - US Built: Left - 339184 and Right - 339183
Front Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - SR4151 and Right - SR4150
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - SR4143 and Right - SR4142
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - SR4109 and Right - SR4108
Rear Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 334341 and Right - 334340
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 334389 and Right - 334388
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 339044 and Right - 339043
2007-2011 SE I4 and V6 - US Built: Left - 335071 and Right - 335070
Rear Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - SR4059 and Right - SR4058
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - SR4086 and Right - SR4085
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - SR4113 and Right - SR4112
Solara
Gen 2:
Front Strut Only -
2004-11/2005 Coupe and Convertible: Left - 334387 and Right - 334386
12/2005-2008 Coupe and Convertible: Left - 339193 and Right - 339192
Rear Strut Only -
2004-11/2005 Coupe and Convertible: Left - 334389 and Right - 334388
12/2005-2008 Coupe and Convertible: Left - 339215 and Right - 339214
Monroe: Generally good reviews from the OESpectrum line listed below.
Camry
Front Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 71491 and Right - 71490
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 72206 and Right - 72205
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - 72308 and Right - 72307
Front Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 171491 and Right - 171490
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 172206 and Right - 172205
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 172308 and Right - 172307
Rear Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 71493 and Right - 71492
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 72208 and Right - 72207
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - 72310 and Right - 72309
2007-2011 SE I4 and V6 - US Built: Left - 72385 and Right - 72384
Rear Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 171493 and Right - 171492
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 172208 and Right - 172207
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - 172310 and Right - 172309
Solara
Gen 2:
Front Strut Only -
2004-11/2005 Coupe and Convertible: Left - 72206 and Right - 72205
12/2005-2008 Coupe and Convertible: Left - 72308 and Right - 72307
Rear Strut Only -
2004-11/2005 Coupe and Convertible: Left - 72208 and Right - 72207
12/2005-2008 Coupe and Convertible: Left - 72640 and Right - 72309
Front Quick Struts -
2004-11/2005 Coupe and Convertible: Left - 172206 and Right - 172205
Rear Quick Struts
12/2005-2008 Coupe and Convertible: Left - 172640 and Right - 272309
Gabriel: Generally good reviews out of these.
Camry
Front Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - G56673 and Right - G56674
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - G56721 and Right - G56722
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - G56888 and Right - G56889
Front Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - G57041 and Right - G57042
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - G57076 and Right - G57077
Rear Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - G56675 and Right - G56676
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - G56728 and Right - G56729
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - G52103 and Right - G52104
Rear Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - G57043 and Right - G57044
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - G57078 and Right - G57079
Solara
Gen 2:
Rear Strut Only -
2004-11/2005 Coupe and Convertible: Left - G56728 and Right - G56729
Rear Quick Struts -
2004-11/2005 Coupe and Convertible: Left - G57078 and Right - G57079
FCS: These actually have pretty good reviews as quick struts go. There is not much information at all on them aside from some online reviews.
Camry
Front Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6 LE/XLE: Left - 1332368L and Right - 1332368R
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6 LE/XLE: Left - 1332367L and Right - 1332367R
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 1331582L and Right - 1331582R
Rear Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6 LE/XLE: Left - 1332369L and Right - 1332369R
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6 LE/XLE/SE: Left - 1332360L and Right - 1332360R
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 1331607L and Right - 1331607R
Unity: I only know of one person who ran these and he was happy with them. Like the FCS, there is not much information on them.
Camry
Front Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6 LE/XLE: Left - 11701 and Right - 11702
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6 LE/XLE: Left - 11711 and Right - 11712
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 11741 and Right - 11742
Rear Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6 LE/XLE: Left - 15341 and Right - 15342
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6 LE/XLE: Left - 15351 and Right - 15352
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 15361 and Right - 15362
Sensen: These are very hit or miss in quality. Overall, the reviews are not good.
Camry
Front Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 42141169 and Right - 42141168
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 42140852 and Right - 42140851
Gen 6:
2007-2011 LE/XLE I4 and V6 - US Built and Japan Built: Left - 42140768 and Right - 42140767
Front Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 92140139 and Right - 92140138
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 92140124 and Right - 92140123
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - 92140182 and Right - 92140181
Rear Strut Only -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 42141171 and Right - 42141170
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 42140854 and Right - 42140853
Gen 6:
42140814 and Right - 42140813
Rear Quick Strut -
Gen 5/Gen 5.5:
2002-08/2003 US Built and 2002-06/2003 Japan Built I4 and V6: Left - 92140135 and Right - 92140134
09/2003-2006 US Built and 07/2003-2006 Japan Built I4 and V6: Left - 92140137 and Right - 92140136
Gen 6:
2007-2011 LE/XLE/SE I4 and V6 - US Built and Japan Built: Left - 92140184 and Right - 92140183
Strut Mounts
OEM Toyota: These are the highest quality mounts available. The aftermarket mounts are not even close to the quality of the OEM mount.
Camry
Mounts:
Front -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: 48609-06090
Gen 6:
2007-2011 LE/XLE/SE I4 - US and Japan Built: 48609-06200
2007-2011 LE/XLE/SE V6 and Hybrid - US and Japan Built: 48609-06190
Rear -
Gen 5/5.5:
2002-05/2004 US and Japan Built I4, 2002-08/2003 US Built V6, and 2002-06/2003 Japan Built V6: Left - 48760-06200 and Right - 48750-06200
09/2003-2006 US Built I4 and V6: Left - 48760-06062 and Right - 48750-06062
07/2003-2006 Japan Built I4 and V6: Left - 48760-33062 and Right - 48750-33062
Gen 6:
2007-2011 US Built LE/XLE/Hybrid I4 and V6: Left - 48760-06180 and Right - 48750-06180
2007-2011 US Built SE I4 and V6: Left - 48760-06100 and Right - 48750-06100
2007-2011 Japan Built LE/XLE/Hybrid I4 and V6: Left - 48760-33080 and Right - 48750-33080
Front Mount Bearing:
Gen 5 and Gen 6 2002-2011 All trims, All Engines, All Build Locations - 90903-63014
Solara
Gen 2:
Front -
2004-11/2005: 48609-06090
12/2005-2008: 48609-06091
Rear -
2004-11/2005: Coupe Without Sport Package and Convertible 48760-06062 / Coupe with Sport Package 48760-AA011
12/2005-2008: Coupe and Convertible 48760-06190
Front Mount Bearing -
2004-2008: 90903-63014
KYB: While KYB makes the factory struts, they do not make the factory mount. These are clearly inferior to the OEM mount and comparable to most aftermarket mounts.
Camry
Mounts:
Front -
Gen 5/Gen5.5:
2002-2006 All trims, All Engines, All Build Locations: SM5423
Gen 6:
2007-2011 All trims, All Engines, All Build Locations: SM5637
Rear -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: SM5175
Gen 6:
2007-2011 All trims, All Engines, All Build Locations: SM5722
Solara
Gen 2:
Front -
2004-11/2005: SM5423
Rear -
2004-11/2005: SM5175
12/2005-2008: SM5722
Monroe: Pretty much the same as KYB/Moog.
Camry
Mounts:
Front -
Gen 5/Gen5.5:
2002-2006 All trims, All Engines, All Build Locations: 904989
Gen 6:
2007-2011 All trims, All Engines, All Build Locations: 906986
Rear -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: 903904
Gen 6:
2007-2011 All trims, All Engines, All Build Locations: Left - 908966 and Right - 908965
Solara
Gen 2:
Front -
2004-11/2005: 904989
12/2005-2008: 906986
Rear -
2004-11/2005: 903904
12/2005-2008: Left 908966 and Right 908965
Moog: Pretty much the same as Monroe/KYB.
Camry
Mounts:
Front -
Gen 5/Gen5.5:
2002-2006 All trims, All Engines, All Build Locations: K90658
Gen 6:
2007-2011 All trims, All Engines, All Build Locations: K160263
Rear -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: K90285
Solara
Gen 2:
Front -
2004-2008: K90658
Gabriel: Pretty much the same as Monroe/KYB.
Camry
Mounts:
Front -
Gen 5/Gen5.5:
2002-2006 All trims, All Engines, All Build Locations: 143202
Rear -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: 142837
Solara
Gen 2:
Front -
2004-2008: 143202
MEVOTECH: Pretty much the same as Monroe/KYB.
Camry
Mounts:
Front -
Gen 5/Gen5.5:
2002-2006 All trims, All Engines, All Build Locations: MP904989
Rear -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: MP903904
Solara
Gen 2:
Front -
2004-2008: MP904989
Rear -
12/2005-2008: Left MP908966 and Right MP908965
Sensen: Unsure of the quality as I haven't seen any reviews. I cannot imagine it is good though.
Camry
Mounts:
Front -
Gen 5/Gen5.5:
2002-2006 All trims, All Engines, All Build Locations: M73630
Rear -
Gen 5/Gen 5.5:
2002-2006 All trims, All Engines, All Build Locations: M70050
Wiper Blades:
The OEM wiper blades on Gen 5 are of the outdated frame design. They have 6 pressure points that make contact with the glass and when the blade wears out streaking occurs. I have updated my 6th Gen (2007-2011) Camry blades to OEM Toyota/Denso Designer 8th Gen Honda Accord (2008-2012) length wiper blades because due to the location of the arms on the 6th Gen Camry, the Accord blades cover more windshield. This is the same with the 5th Gen (2002-2006) Camry, except using 10th Gen (2009-2013) Corolla wiper blades. There are also several frameless style blades available with the Denso Designer being the same exact blade as OEM Gen 6 style. The major advantages to OEM Gen 6 Style blades is that they allow for insert replacement only which are very cheap and they last FOREVER. Lengths for 5th Gen Camry and 2nd Gen Solara are 24 inch for the driver side and 19 inch for the passenger side. Lengths for 6th Gen Camry are 24 inch for the driver side 20 inch for the passenger side. Lengths for 8th Gen Accord are 26 inch for the driver side and 19 inch for the passenger side. Lengths for 10th Gen Corolla are 26 inch for the driver side 16 inch for the passenger side.
OEM Toyota Improved Style:
2002-2006 Camry and 2004-2008 Solara: Driver - 85222-06110 Passenger - 85212-47040
2007-2011 Camry: Driver - 85222-06110 Passenger - 85212-06110
2008-2012 Honda Accord: Driver - 85222-02250 or 85222-0T030 Passenger - 85212-47040
2009-2013 Corolla: Driver - 85222-02250 or 85222-0T030 Passenger - 85212-02230 or 85212-28170
Denso Designer Blade:
2002-2006 Camry and 2004-2008 Solara: Driver - 1603124 Passenger - 1603119
2007-2011 Camry: Driver - 1603124 Passenger - 1603120
2008-2012 Honda Accord: Driver - 1603126 Passenger - 1603119
2009-2013 Corolla: Driver - 1603126 Passenger - 1603116
Replacement Inserts: (Blades above come with inserts. These are only needed when the originals are worn out).
2002-2006 Camry and 2004-2008 Solara: Driver - 85214-06140 Passenger - 85214-30390
2007-2011 Camry: Driver - 85214-06140 Passenger - 85214-06130
2008-2012 Honda Accord: Driver - 85214-68020 Passenger - 85214-30390
2009-2013 Corolla: Driver - 85214-68020 Passenger - 85214-28090
With these lengths you can check out any frame-less beam style blades from Anco, Bosch, Valeo or Trico.
Drive Belts:
The highly recommended belts for these cars include OEM/Bando, Gates/Napa Micro-V, and the Goodyear Gatorback.
OEM Toyota/Bando: The OEM belts are made by Bando and can be purchased from a dealership or aftermarket.
Gen 5 Camry and Gen 2 Solara 2AZFE:
Toyota: 90916-A2005
Bando: 7PK1940 76.4" and 7PK1935 76.2"
Gen 6 Camry 2AZFE:
Toyota: 90916-02653/90916-A2011
Bando: 7PK1905
Gen 6 Camry 2AZFXE:
Toyota: 99364-C1050
Bando: 4PK1050
Gen 6 Camry 2ARFE:
Toyota:
P/S - 90916-A2022
Alt & A/C - 90916-02671
Bando:
P/S - 3PK1200
Alt & A/C - 4PK1240
Gen 5 Camry and Gen 2 Solara 1MZFE/3MZFE:
Toyota:
P/S - 90080-91088-83/90916-A2009
Alt & A/C - 99366-21040-83
Bando:
P/S - 4PK880
Alt & A/C - 6PK1040
Gen 6 Camry 2GRFE:
Toyota: 90916-A2010
Bando: 7PK2090
Gates/Napa Micro-V: Very high quality belts. I have used them with great results.
Gen 5 Camry and Gen 2 Solara 2AZFE: K070763 w/o "enhancement kit" 76 7/8" or 7PK1930 "w/enhancement kit" 76"
Gen 6 Camry 2AZFE: K070750
Gen 6 Camry 2AZFXE: K040415
Gen 6 Camry 2ARFE:
P/S - K030471
Alt & A/C - K040488
P/S - K040347
Alt & A/C - K060408
Gen 6 Camry 2GRFE: K070822
Continental Elite: Very high quality belts. I have used them with great results.
Gen 5 Camry and Gen 2 Solara 2AZFE: 4070763 "standard length" 76.3" or 4070762 "OEM length" 76.2"
Gen 6 Camry 2AZFE: 4070750
Gen 6 Camry 2AZFXE: 4040412
Gen 6 Camry 2ARFE:
P/S - 4030472
Alt & A/C - 4040488
P/S - 4040347
Alt & A/C - 4060407
Gen 6 Camry 2GRFE: 4070825
PCV Valve and Hose:
2002-2006 Gen 5/5.5 Camry and 2004-2006 Gen 2 Solara 2AZFE:
Valve: 12204-28020
Hose: 12262-0H010
2002-2003 Gen 5 Camry 1MZFE non-VVT-i:
Valve: 12204-20020
Grommet: 90480-18001
Hose: 12261-20011
2004-2006 Gen 5/5.5 Camry 1MZFE VVT-i/3MZFE and 2004-2006 Gen 2 Solara 3MZFE:
Valve: 12204-20040
Hose: 12261-20011/12261-20091
2007-2008 Solara 3MZFE:
Valve: 12204-20060
2007-2011 Gen 6 Camry 2AZFE/2AZFXE and 2007-2008 Gen 2 Solara 2AZFE:
Valve: 12204-28030
Hose: 12262-0H010
2007-2011 Gen Camry 6.5 2GRFE:
Valve: 12204-31040/12204-31120
Hose: 12261-0P030
2010-2011 Gen 6.5 Camry 2ARFE:
Note: The PCV valve on the 2ARFE is located on the ventilation block under the intake manifold.
Valve: 12204-36020
Feel free to PM or reply with any feedback and/or additions. Hope this helps!!
Super Moderator
2005 Corolla CE
So is this a typo....?
"Lengths for Gen 5 Camry: 24 inch Drivers side 18 inch Passenger side"
haha yes. I meant they listed 18"
:thanks:
Super Moderator
2005 Corolla CE
Discussion Starter #10
I plan to do shocks in the future.
Awesome !
Probs put a note somewhere in case someone from australia searches, some parts may not be the same.
eg, wipers for audm gen 5 camrys are 22" drivers 20" Passenger (made this silly mistake -__-)
Top TN contributor
Awesome !
.....and for the J-vin 05 Camry, 19"er driver's side works just fine instead of the 18s, as it overlaps the passenger side...no conflict and more wiper coverage...
Super Moderator
2005 Corolla CE
Discussion Starter #14
With wipers you are usually find to run an inch or two bigger on one side for coverage.
My Corolla uses 2 inch longer driver and 1 inch short passenger for great increased wiping area.
It's just not the factory length.
Most of this is for North American models. I'm sure Australia has more differences than wipers.
Top TN contributor
18" and 24"
Yeah everyone says 18" and yet I've got 19" on mine and it's just fine....really...I'll take a pic in the morning and post it here...
Here's the fitment of 19" and 24" wipers....19" Goodyear (passenger), 24" RainEx...other brands might be different lengths I guess, but this combination fits JUUUUuuuussst fine...
Super Moderator
2005 Corolla CE
Discussion Starter #18
Added information for Castrol Fully Synthetic and High Mileage ATF.
Super Moderator
2005 Corolla CE
Discussion Starter #19 (Edited)
Updated information on Valvoline Import Multi-Vehicle ATF.
So I was getting some mixed signals on this fluid. The bottles I saw and used specified this fluid was a WS compatible low viscosity fluid like Maxlife DexMerc. However the Valvoline website and new product labels (even on 1 gallons) stated this fluid was only good up to T-IV spec and had a 1 cSt higher viscosity (6.9 vs. 5.9 of the Maxlife DexMerc) bringing out of WS compliance.
So I emailed the Valvoline tech line and with this inquiry below:
Hello I am seeking to clarify a discrepancy between available information for Valvoline Import Multi-Vehicle ATF.
For years now I regularly used Valvoline Maxlife Dex/Merc as my go to fluid for modern Toyota transmissions since it was the only locally available WS compatible ATF on the market.
On a fluid run at Advance Auto Parts I noticed a new blue one gallon bottle next to the Maxlife Dex/Merc which I found to be the Valvoline Import Multi-Vehicle 1 Gallon Part #820681. This fluid label also interestingly enough claimed to meet modern low viscoity ATF specs like: Toyota WS, Honda DW1, and Nissan Matic-J specification which leads me to believe it was a modern fluid. This was great as Maxlife Dex/Merc isn't always well stocked locally and the availability of a second fluid would help me on some jobs where I was short.
Later on I wanted to read the Product Data Sheet and found that the only available information on the Ashland/Valvoline Website and online pointed me to a 1 quart bottle of Valvoline Import Multi-Vehicle ATF Part #788699. This is a problem as the product data sheet points this one quart bottle as an older, higher viscosity ATF, more similar to Toyota T-IV spec and not thin enough to be used in WS applications (or other modern ATF). All available information points to this fluid being older high viscosity fluid, and the one gallon bottles I find at Advance Auto Parts continue to point out the fluid is suitable for modern low viscosity ATF specs (like WS).
So is the fluid different from 1 gallon to 1 quart bottles? Has the formulation for this fluid changed over the years? Is there an updated product data sheet to reflect the new modern fluid characteristics? If not, why does the label claim the fluid is suitable for the newer specifications?
Thank you and I look forward to your response,
I received this response from Matt and Valvoline:
Mr. XXXXXX, thank you for contacting Valvoline Product Support
Indeed there has been a formulation change with the Valvoline Import Multi Vehicle Fluid. Last year we have removed the specifications Toyota WS, Honda DW-1, and Nissan Matic -J. If you have an older bottle of Import Multi Vehicle that states on the bottle it will cover WS, DW-1, and Matic-J that means the older formulation will cover them. The new formulation will not. The Import Multi Vehicle will cover many new specifications but we now favor the MaxLife ATF to cover WS, DW-1, and Matic J. To find a current product sheet for Maxlife ATF and the Import Multi Vehicle ATF visit our website www.valvoline.com.
If you have any further questions, please feel free to contact us via phone at 800 TEAM VAL or by email at [email protected] for assistance.
Thank you and have a great day.
Matt
So it looks like the current formulation isn't the modern ATF like Maxlife is and isn't compatible with newer Toyotas or other imports that specify modern ATF and may be in your stable.
I will be updating the sticky.
1 - 20 of 183 Posts
