181 - 183 of 183 Posts
In the US, RockAuto, dealership parts website, dealership, local auto store.
Thanks for the reply. Happy Holidays mate.
Do you have a link to those sites? I mostly want to see if there are OEM online retailers that are reasonable and authentic.
I have a 4 cylinder and want to just reconfirm the fluid brands for ATF, P/S, coolant. I understand the stickies, but things can always change and I hope to find updated guidance. Thanks.
https://www.rockauto.com/ <<< If I can get a Toyota OEM Denso part from them, then I will get it from them.
https://parts.olathetoyota.com/ <<< I usually use them as a reference for part numbers and as an optional place to get parts.
2002 Models - Plain or stepped hat style.
If your rotor is warped, I'd suggest the stepped hat style.
We have a 2002 ES300 that was serviced at 10k miles under TSB BR002R-02 because of brake vibration. The TSB updated the rotors to stepped hat style.
2002-2003 Es300 Owners - Useful Info
(At around 75k miles, I had to get new rotors again. I got 120.44088 from Amazon because of free shipping.)
Also see reviews for the plain style with two 1 star reviews about it being warped:
Amazon.com: Centric 120.44125 Premium Brake Rotor: Automotive
versus the stepped hat:
Amazon.com: Centric Parts INC 120.44088 Premium Brake Rotor with E-Coating: Automotive
More discussions:
Disc Brake Rotor Design
"A heat dam is often machined into the area between the friction surface and hat on most rotors. The dam is a thinner section of metal that reduces heat transfer from the rotor surface to the hat. This protects the wheel hub and bearings from the heat and also allows the rotor to flex when it gets hot to reduce the risk of warping and cracking.
Brake rotors: "Plain hat vs "stepped hat"?
"Stepped type is known as a heat break or heat dam to reduce heat transfer to the hub section, and then transferring to your car's hub (Wheel bearing and CV Joint).
It looks like Scotty Kilmer also got the stepped hat style for his wife's ES300:
