GR
Core or circuit?
Did you get a great price? We’re you already on the waitlist?Circuit won't be manufactured till late summer, barring even more delay. This is a Core with all three packages.
Congrats! Now to keep people from hitting your car....I did it.
No. CA models had a pre-cat and a cat. Fed models only had one cat. Pre-OBD-II 7A-FE fed models (1993-1995.5) didn’t have EGR whereas same model year CA did. Might be other differences I’m forgetting about too like downstream O2 sensors.Are all 1.8 L 7AFE engines rated for CA emissions requirement?
For the purpose of doing an engine swap, as long as the engine were to have an egr port, assuming all what you stated above is correct, I would be good to place a "mystery 7AFE" engine into my CA emissions 97 corolla?No. CA models had a pre-cat and a cat. Fed models only had one cat. Pre-OBD-II 7A-FE fed models (1993-1995.5) didn’t have EGR whereas same model year CA did. Might be other differences I’m forgetting about too like downstream O2 sensors.
I'm being told that all 7afe engines after 1995 are OB ll versions?If you have a 1997 you have to make sure it’s an OBD-II version as the OBD-I version (1993-1995.5) has an adjustable distributor and lacks a crank position sensor. Other than that I think you’d be ok.
1995 was a transition year so some 95s are and some are not. 1996 and 1997 are all OBD2I'm being told that all 7afe engines after 1995 are OB ll versions?
The bare blocks are the same, head, cams, intake manifold, and oil pump and timing sprocket are different.For the purpose of doing an engine swap, as long as the engine were to have an egr port, assuming all what you stated above is correct, I would be good to place a "mystery 7AFE" engine into my CA emissions 97 corolla?
Is there a way to designate a CA emissions engines from the other emissions types engines?
Hybird SportApex or nightshade.
rebuilt title 💔Dude what the fuck I just found a Corolla with 17k miles man what the this is the stuff I’d expect to be on BaT.
1997 TOYOT COROLLA DX - cars & trucks - by owner - vehicle...
1997 Toyota Corolla DX 17,634 miles original 1 owner car NO RUST OR ROT POWER WINDOWS & DOOR LOCKS RUNS & DRIVES GREAT $4,500newjersey.craigslist.org
