Status
Not open for further replies.
1 - 1 of 1 Posts
Vivir el momento
Corolla
Discussion Starter #1 (Edited by Moderator)
Here is a list of all the available DIY threads available for the 8th gen Corolla.
If you have any new contributions or I managed to somehow miss a thread, then please PM me with the link and name and I will add it to the list right away. :)
Brakes, Steering & Suspension Maintenance & Repair:
DIY Front Brakes Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=346914
DIY Front Wheel Bearing Replacement with pics.
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/430409-front-bearing-replacement-fun-pics.html
DIY Front Driveline Repair
http://www.toyotanation.com/forum/showthread.php?t=319119
DIY Power Steering Pump and Pulley
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/399487-successful-diy-2000-corolla-power-steering-pump-pulley.html
DIY Rear Hub Wheel Bearing Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=332241
DIY Rear Strut Replacement Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=332248
DIY How to install front control arms 98 - 02
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/1021442-diy-how-install-front-control-arms-98-02-corolla.html
Engine Maintenance & Repair:
DIY: Oil Consumption Fix
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/402362-diy-oil-consumption-fix.html
DIY: Timing Chain Tensioner install
http://www.toyotanation.com/forum/showthread.php?t=334460
DIY Tune Up & Oil Change Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=355103
1ZZFE Engine Swap Tips Thread
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/1108962-hardtopte72-1zzfe-swap-tips-thread-everything-you-wanted-know.html
Engine Modifications:
DIY Radiator Cooling Shield Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=328228
Exterior Maintenance & Repair:
DIY: How to replace a broken outside door handle.
http://www.toyotanation.com/forum/showthread.php?t=300392
DIY : Adding foglights - 98-02
Interior Maintenance & Repair:
DIY write-up for instrument gauge cluster
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/139119-diy-write-up-instrument-gauge-cluster.html
DIY Shift Lock Control System Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=332492
DIY Window Lift Motor Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=327763
http://www.toyotanation.com/forum/showthread.php?t=139119
Interior Modifications:
Disable DRL Headlights
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/925865-disable-drl-daytime-running-lights.html
DIY Aftermarket Cigarette Lighter Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=329885
DIY Front Doors Speaker Replacement Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=331756
DIY How To Remove Tint Safely With A Rear Window Defogger
http://www.toyotanation.com/forum/showthread.php?t=330430
DIY Rear Speaker 6x9 Conversion Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=331857
DIY White Face Glow Gauge Corolla 98 - 02
http://www.toyotanation.com/forum/showthread.php?t=330450
DIY Disable Annoying Dinger: 2001-2002 Corolla
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/847345-finally-how-disabling-annoying-dingers-01-02-corollas.html
Miscellaneous:
SMOG Emissions Drive Tests Conditions Needed For Each "ECU Test"
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/1412378-diy-readiness-monitors-pre-check-before-smog-check.html
Pull Fuel Pump and either replace or check gas gauge sending unit
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/945354-fuel-pump-removal-sending-unit-testing.html
Wiring Remote Starter
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/624674-diy-remote-car-starter-install-tips-inside.html
DIY Vehicle Battery Maintenance
http://www.toyotanation.com/forum/showthread.php?t=355098
Key Will Not Turn to Lock Position / Can't Remove Key From The Ignition: Repair
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/735570-key-cannot-turned-lock-repair-experience.html
Known Issues & Fixes
http://www.toyotanation.com/forum/showthread.php?t=386174
Power Outlet fuse fix
http://www.toyotanation.com/forum/showthread.php?t=311421
Transmission Maintenance & Repair:
DIY: Automatic Transmission flush
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/404448-diy-automatic-transmission-flush.html
Video
A131L 3-Speed Transmission Fluid & Filter Write up and Pics
http://www.toyotanation.com/forum/showthread.php?p=3132707
How To: 2001 4 Speed Auto Transmission Filter Change
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/225196-how-2001-4-speed-auto-transmission-filter-change.html
General Information
Oil Consumption Discussion
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/235960-solution-oil-dissappearing-1zzfe-engine.html
8th Gen FAQ
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/294665-its-time-8th-gen-corollas-faq.html
1 - 1 of 1 Posts
Status
