21 - 26 of 26 Posts
hope this helps
hey guys just woundering how can i make a 22re motor get up and go wat mods do you suggest and is a turbo out of the question cheers logan
G'day ace, i have a mate with a hilux and he put a turbo on it himself with an intercooler on top with a scoop, he said that it doesn't go faster but holds more speed up hills and better for towing trailers, but if you want more speed maybe try porting the head, extractors, sidedraft carbs.:D
hello... i am wondering if there is any replacement parts for the corona 1987 i will like to put a 4age engine in it but i want to know about the parts before i consider the project... anybody there can help with info.. will appreciate...
Ok, 10 years after the last post here's a few more:
Removed the restrictive OEM air cleaner( on the Asian Carb.) that had an approx. opening of 1 1/2'' dia inlet for fresh air and installed an old weber carb. air filter the square 2 piece square chrome cover and base plate, notched out the square base and rounded the edges a little to fit the round Asian carb. and drilled a hole in the cover to install the bolt to tighten it down on the carb. ......... 100% better! can feel the increase in performance. Oh, BTW the 32/36 weber didnt work so well, the rebuilt Asian Carb. works better.
Rear Brakes: see my thread:
21 - 26 of 26 Posts
