Official second generation Avalon picture thread!
89779 121
Let's see them :cool:
:Bruce:
1 - 20 of 122 Posts
2000 Toyota Avalon
where did you get your HID lights? Is it the same for the High Beam, Low Beam, and Fog Lights?
I have HID on the Low Beams and not for high because i barely use High Beams. if You were to add HID on high beam, use will lose daytime running light (DRL). For the fog lights, It uses same type of bulb as low beam. The Bulb type is "9006 (HB4)". If you want pictures where I placed the ballast (For the Low Beams) just ask. I don't know where a secure place to put the ballast for the fog lights.
I got it from:
http://cgi.ebay.com/ebaymotors/HID-...f2QQitemZ250518321906QQptZCarQ5fAudioQ5fVideo
I'm currently using 55W HID kit, They are brighter. Some people sell 35W Kit? but they aren't as bright as 55W Kit but bright then Halogen.
I recommend you put Relay Harness. to protect the car's factory electrical system because without the Relay Harness, the ballast draws more power throw the factory electrical system, will might burn the whole system.
http://cgi.ebay.com/ebaymotors/9006-HID-Xenon-Relay-Wiring-Harness-W-25-Fuse-40-AMP_W0QQitemZ180438396860QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2a02f76fbc
:D:welcome:
I got it from:
http://cgi.ebay.com/ebaymotors/HID-XENON-CONVERSION-KIT-H1-H3-H4-H7-9005-9006-50W-55W_W0QQcmdZViewItemQQhashZitem3a540e3af2QQitemZ250518321906QQptZCarQ5fAudioQ5fVideo
:D:welcome:
Can you put a silverstar ultra bulb for the high beam and put the hid for the fog lights and low beam. Could you post your picture on where you placed you ballasts so when i buy the HID lights i will have an idea of placement.:thumbsup:
2000 Toyota Avalon
Yes you can and here are the pics:
http://picasaweb.google.com/Lilaznkid506/Desktop#5429364881714367138
I used zipties to secure in place
http://picasaweb.google.com/Lilaznkid506/Desktop#5429364897818568930
I screw in the hole near the reservoir
http://picasaweb.google.com/Lilaznkid506/Desktop#5429364910971261746
The Relay Harness, place in with the other wires on top of the fans.
1 - 20 of 122 Posts
