1 - 12 of 12 Posts
Discussion Starter · #2 ·
Hubcentric
Oh yeah one more thing, I am a Tool Maker/Machinist so I intend to make my own Hubcentric rings, so I know about the difference with the hubs already..........just do not know about the offset set up ??
· Auto-Cross Addict
A bigger offset will cause your tires to stick out further than your fenders. They also will start to rub on your fenders, along with shortening your turning radius.
· Auto-Cross Addict
Wheel spacers are a cheap way for people to buy small offset wheels and make them stick out.
Low-rider!:lol:
· Grenaded piston
You got it backwards.
Lower offset = more it sticks out. IE: Closer to fender
Higher offset = sits more inside the wheel well.
http://www.tirerack.com/wheels/tech/offset.htm
amerikim said:
V6on the accord maybe?
rgr that, dylansdad stated that his was a v6 accord...which sports the 5lugs unlike the 4bangers
and like jackfrost said, you'd prolly end up rubbing suspension components but you can't be sure till the wheel's actually on there...spacers are the way to go if you get the right ones
"As for spacers, 99% of them are not made properly. They are just thin pieces of metal with multiple bolt patterns drilled in. They have two main problems:
1. do not ensure sufficient lug-to-stud thread engagement; and
2. do not replicate the vehicle's hub for proper centering of the wheel.
Only use PROPER spacers that address these two problems."
from spectrabluecam's great thread of tire info...http://www.toyotanation.com/forum/showthread.php?s=&threadid=15167
so i stick with my "if you get the right ones" statement
1 - 12 of 12 Posts
