I puchased a Hanes repair manual and was looking at the capacity section for all the oils so i could change them. Then I searched a bit on these forums and found some conflicting info that also was found in the owners manual for the truck. It is a 1990 4x4 and this is what i found
Hanes Oweners man
Diff (front) = 2.9 qts 1.79 qts
Diff (rear) = 2.5 qts 2.3qts
transfer case 3.4 qts 1.2 qts
The transfer case is a big difference is qts and i was just wondering how much you guys all put in and wah tis the correct ammounts. Thanks.. I plan on using Redline MT90 (GL-4) for transmissin and transfer case and Redline 75/90 (GL-5) gear oil for the differential. Is that correct
remove the fill plugs, after draining and replaceing drain plugs, FILL TIL IT RUNS BACK OUT OF THE FILL HOLE, reinstall the fill plug !--- end of story.
