I recently pulled my throttle body off the car to inspect, and was pretty horrified how dirty it was. The air control valve was caked too, I can't believe it was even working. What I thought was throttle cables needing lubricant turned out to be a TB so dirty the valve was sticking.
Then I came across a YouTube video that compared a cheapo catch can off Amazon with a Mishimoto unit, and they are essentially identical except for different fittings. I was convinced that it's worth doing for the $18-19 I paid.
The one tiny error I made, was after I cut the hoses to length I got them backwards. It made for a slightly less clean install, but I left it as is because no one but me is gonna be looking under there (well I guess you now too). If I had attached them correctly the two hoses would be side by side making it look more factory.
All I needed was 4ft of fuel line, a 90 degree 3/8" PCV elbow, a straight 3/8" male to male nipple fitting, one Allen bolt and nut with a 10-13mm sleeve spacer and lock washer, and the catch can. I'll prob switch the hose clamps out to 3/8" fuel injection hose clamps to clean up the install at the same time I switch the hoses how I meant to have them. I was able to modify the bracket that came with the catch can, and I didn't have to drill a single hole into my car which I always aim for.
Please don't tell me it's stupid to add this, the less oil getting burned by the engine the better. After 5-6k miles I'll take a picture showing what it collects.
I was surprised the only examples I could find of 5sfe with catch cans were very ugly installs with hoses going all over the engine bay. Mine already looks a lot better than examples I've seen and I didn't get the hoses right haha. The cannisters can actually be unscrewed and removed as well. It takes some hand yoga, but it's doable. It's only one fastener to remove if I decide to do it that way.
If you decide to do your own, add it to this thread so future people can easily find it! Cheers
