oil change: regular or synthetic?
4094 Views 26 Replies 20 Participants Last post by  Svtrit
I have a 07 toyota camry. I want to have oil change this week. When I called the dealer, they told me there are two options: regular and synthetic. Which one should I choose? Synthetic is more expensive, ~80, and regular is only half of the price. I would like to hear any opinions about that.
1 - 20 of 27 Posts
I use synthetic.
Do what you want as long as the oil meets the GF-4 specification explained in your owner's manual.
You could also do a search and you will come across probably hundreds of threads asking the same exact question...
EDIT: Welcome to TN.
Here is a search of just this forum: http://www.toyotanation.com/forum/search.php?searchid=1119529
what does "~80" mean? don't tell me the dealer wants to charge you $80 for an oil change?
HAHA you can do a regular conventional oil change yourself for like $13 or a synthetic one for $25...$80 is outrageous!
Go with a good synthetic and change oil and filter every 7500. Get it done at a cheaper place.
Great idea if you want to void your warranty!
aaaah the weekly oil discussion
simply put, TRD's above post prety much covers it...
synthetic oil isnt subject to thermal breakdown as conventional dino oil is, for its molecules dont break down and they keep their form, thus allowing the oil to have an extended use period...however, synthetic, like all oils, gets contaminated easily and still should be changed regularly, to prevent debirs and dirt in the oil from damaging bearings.
i dont reccomend 10k oil intervals, just stick with the regular 5k intervals
one of the best ways to go is to mix a quart of synthetic with your dino oil, for you get the protection of sythetic and its more resistant to dirt...toyota reccomends a synthetic blend for all new vehicles, and thats just what a synthetic blend oil is
all in all, id always adhere to 5k ol change intervals, just to keep your car safe and not void your warrenty
i mean, i use synthetic myself and i still adhere to 3k intervals...call me crazy, but my engine has 56k and still looks brand new inside
check out www.bobistheoilguy.com for more info.
Do you guys think its ok with bringing the Camry to shops such as Goodyear, Jiffylube, Midas, for your first oil change?
Shane
you can do it, just keep a close eye on them
and briong your own filter such as a K&N, mobil 1 or toyota filter! the fiulters quick lube places use are shit!
to be honest with you tho, its cheaper and easier to just do it yourself...its a very quick process and very easy to do as well...
i trust the quality of my own handiwork over quick lube places, as they seldom double check their work and can lead to mistakes...at the dealer i work in i ALWAYS get cars from walmart, firestone etc with loose filter and drain plugs....
no sense taking chances with your engine
KN and Mobil filters are rather expensive at ~$10 ea. Wix, Napa Gold, Purolator Premium and Purolator Pure One filters can be had for ~$4 to $6 each and are well regarded in terms of quality. Toyota filters run ~$4-5 each.
80 bucks for an oil change?? Are they giving you back rubs while you wait? I say pick either syn or dino, stick to 5k. And more importantly, if you must have someone change it for you, how about going to a local mechanic who you'll get to know and vice versa?
So, on a I4 or V6? On my V6, I buy the filter from the dealer for $3.25 + tax, and oil, I'm using Mobil 1 Synthetic, 5 quart from Wal-Mart for $19.97, and 1 quart for $4.70. For a V6, 6 quarts is what I need to get the level to exactly where it needs to be, between low and max ... if you don't wanna pay that much for full Synthetic, go get Synthetic Blend Phillip 66 by the case, 12 quarts for $19.97 from Sams Club, or $20.92 from WalMart, and it's good for 2 oil changes ...
For V6 (6 Quarts + Filter):
Full Synthetic: 19.97 + 4.70 + 3.25 = $27.92 + tax
Synthetic Blend: 9.99 + 3.25 = $13.24 + tax
For I4, 5 quart is more than enough ...
So ... 5 Quarts + Filter:
Full Synthetic: 19.97 + 3.25 = $23.22 + tax
Synthetic Blend: 8.32 + 3.25 = $11.57 + tax
Takes me 10 minutes to drive my car up a ramp (I don't have a ramp, but I drive them through a bunch of cardboards which I get from my company), go under my car, release the filter cap, drain part of the oil out of the filter, then remove the filter, and remove the drain plug ...
Takes another 5 minutes to clean the filter up and replace the filter element ... I usually leave the gasket and o-ring till when I wanna put em' back ... then go back into my house ... watch a movie or two, or TV, might wanna get some food ... usually after 2-3 hours, I'll just go back out, and usually I wouldn't see any drippings left ...
Then it'd take less than 2 minutes to put the o-ring/gasket on, and another 5 minutes to go under the car and install the filter and drain plug back on ...
Takes 5 minutes to put all 6 quarts of oil back in ... 5 minutes to start engine, reset meter, check leak, and check level ...
Total time needed just for the process: 10 + 5 + 2 + 5 = 22 minutes ... excluding the 2-3 hours you spend having fun ...
By doing this, you save money, you get to understand your car better, you get a sense of satisfaction ... and you know what the heck is under your car ... and not wasting a single minute at all, like you do when waiting for oil change at the dealership/Iffy Lube ... and you're sure than you drained every single drop of old oil, and you're sure that your filter is new, unlike dealers/Iffy Lube that scams you, charging you things for what they didn't do ...
Changing oil is like a hobby to me ... if you bring your car to me (LA area, Diamond Bar) ... I'd be glad to do it for 10-20% cheaper than what your dealer is gonna charge you ... and in the process, I could teach you how to do it yourself next time ... :)
Or if you want, you can bring all the oil/filter needed, and I'll do it for 6 pack of Corona Extra ... :p
Reactions: 1
I have been using Amsoil syn oil and their filter for the last year in my V6.
Although Amsoil is more expensive and not readily available, I will continue to use it @ the 5k interval.
I have always been a proponent of synthetic oil and will soon be changing my wife's RAV4 over.
IMHO, Amsoil is over-rated ... Mobil 1 / German Castrol ... equally good ... I'd throw them away after 5k miles anyway, so no difference ...
I've been using AMSOIL and their filters on the Camry also.
amsoil > mobil 1
oil analysis has said it time and time again.
Synthetic is 2x price but changes every 5k vs [email protected] price is neutral, but synthetic is much better on the engine
1 - 20 of 27 Posts
