Hey guys, I'm out of town and thought I'd pick your experience for when I get back.
My uncle's got a '95 5S-FE. There's an oil leak the seeps down and coats the oil pan and transmission pan, I'm trying to think about it before I get back and dye it.
I put a new o-ring on the distributor and cleaned it up...it stayed clean. There's a little divot under the distributor that has oil in it, and the bundle of vacuum lines right under the distributor is oily. When the engine's running (idling), I don't see any oil seeping down to the divot, but I pop open the hood and the oil there is fresh. Valve cover gasket and spark plug tube seals are nearly brand new, no leakage around them.
Anything other than the VC or distributor that could be leaking? As I've verified the VC, I'm thinking the distributor bore is enlarged or something.
Thanks as usual
Thanks as usual
