Van was leaking a bit of oil, gasket between flanges in exhaust pipes were leaking, van was very sluggish going uphill, idle rough sometimes and stalled a few time during idle, engine light on and very poor gas milage when I bought it a year ago.
Update of what I have done since, welded the flanges together to sealed the leak, changed all fluids and filters, disconnected the oil reservoir pump because of faulty oil float, added a litre of Lucas oil treatment. Drove 6000km and van burnt 1/2 litre of oil and ran prefect! Its still a bit wet where it was leaking but parked van for 2 weeks and happy to report NO oil on ground. Engine light on because 1 of 2 bolts holding down the O2 sensor was so rusted it broke off, its currently held down by a clamp.
Had a Toyota mechanic who owns a Previa himself look over the van while I was in Florida. He told me I need new plugs, wires, distributor rotor and change the valve covers while I am at it. "DO NOT remove distributor or timing will be f***ed". The exhaust system is so rusted that it can't be taken apart and put back together, "so new pipes or weld a new O2 sensor to the pipe".
PS. I think it was the Lucas oil treament that slowed the leaks and improved engine performance. I will do a regular oil change and see if van struggles like it did.
