1 - 2 of 2 Posts
I know the oil leaks when I went under the car to changed my oil for every 3k miles.. the oil leaks under the engines...and I am trying to understand where are the main sources oil can be leaking out of? can you explain where the sources of oil leaks? i have had replaced O-Ring (distrubotor) and gasket (top) where spart plugs go in.... right now, I am trying to understand where the oil engines go into the engines? my car 1996 Toyota Camry with 108700 miles, and the car has not given me any problems... I would appreciate if someone explains where the engine oil can be leaks?
2002 Camry
After reading your post, i have a couple suggestions for you. Maybe you have little experience on how an engine works or fixing them. Take the easy routes, here would be my choices, either just keep adding oil, or take it in.
1 - 2 of 2 Posts
