1 - 3 of 3 Posts
S
Guest
I went to a different oil change place. They informed me that my "Oil
is on bypass". He couldn't tell me what that means, but said there
wasn't any oil up in the filter because it was bypassed. Can someone
explain? TIA
M
Guest
Discussion Starter #2
Im not sure what he means or how he knows without cutting open the
filter and again im guessing here. There is a bypass valve in the filter
for when pressure is to high it bypasses it, as when its thick cold oil
or a clogged filter it bypasses it . What type of filter, how many miles
on it, was oil real black. Call them back because 4 cil have also an
anti drain valve in filters since filter is mounted upside down to
prevent draining and " No oil in filter" starts. You should be able to
remove filter and oil stays inside, the only way to know its empty is
cut it open. And pressure Bypass should be only under pressure . So how
does he know, you should have kept the old filter. It sounds like you "
oil change Pro" is a hack.
T
The way it is supposed to work is that If blockage occurs in the
filter, bypass valves open. This allows oil to go around the filter and
back to the engine. Dirty oil is better than no oil.
It is no big deal if you change your oil and filter regularly. I do my
own, and in the 30 years of changing my own oil, I had it happen once.
1 - 3 of 3 Posts
