I have a 1999 Camry with a 2.2 engine and am replacing the front crank seal, oil pump seal and gaskets. My repair manual has you put the oil pan back on using a silicone type of sealant. However, my local parts house shows a gasket for this.
Any suggestions? If I do use the gasket, should I use it dry or with a thin coat of RTV?
