So, my car is a Geo Prizm 90 hatchback 4afe model. So recently I started having my oil light come on when i was idling my car when i got back to it after I got out to do something for a minute and left my car sitting there on. it seemed to blink on and off with the rpms flucuating. Also i had noticed that sometimes when Id take off it would light up for just a second and I'd barely notice it.
Read it might just be the sending unit, so I bought a new one and installed it. I read it was 24mm. When taking mine out, i had to use a 27mm socket to remove it. It looked different and when I compared the one I took out compared to the new Light sending unit i bought, and crossed them with pictures I seen of ones on Rockauto, the one that came out, seemed to be a Oil pressure gauge sending unit.? This is weird, as the light always seemed to work right when it was supposed to on my car. Like, when Id almost kill the motor by throwing it into 5th gear for no other reason going 10mph or something, the light would come on. So, ? what the heck ? If I bought a new pressure GAUGE and installed it, would it run both my light on my dash and an oil pressure gauge both if i ran 2 wires on to it? has anyone ever tried this before? Why or how does teh gauge turn the low pressure light on and off?
My new gauge doesnt even turn on when i try to trip it on, so i dont know why its not working it might just be faulty. i even tried to make sure i had it tigthtened down enough by retightening, or just adding another turn to it, i was afraid to strip it, and i double checked it after it wouldtn trip on the light and it turned another half turn or more, and then I noticed it tightening down; i could feel it getting tighter. so i thought, this is enough here. I tried the ohm meter and tests i read on another topic, ohm to the sensor and body will have resistance car off, ohm from sensor to body will have no resistance motor is on. and the wire while grounded and key on will show oil light on.
Q's are, can the gauge work my light? Can i run 2 things from it both light and gauges? (why odesnt gauges just have a light too?) Does a pressure gauge only need one wire to the sensor output to get the reading to function? maybe pos neg.?
Old:
New:
https://www.rockauto.com/info/1085/7.0016__ra_p.jpg
Old:
New:
