I was driving home on the freeway one night when my "check oil" light started to flicker. I immediately tried to get off the freeway, however, the nearest exit was roughly 1/4 mile away. Upon reaching the exit, the oil light began to stay on, rather than flicker on-off. As I pulled into a gas station off the freeway, there was a sound emitted from the engine - coming from the timing belt side. I shut the car off as soon as I pulled in.
I had the car towed and it was diagnosed as a faulty oil pump. The oil pump was replaced and the car is back in action.
My question is, did the failing oil pump cause any permanent damage to the bearings or valve train? It feels like the idle on the car has gotten worse since this incident.
*On a side note, I had my mechanic change all the seals (oil pump, crankshaft, …) on the timing belts side because they were leaking. Any correlation to the failed pump?
She's been with me a solid 240K, was hoping to see 300k
