im in need of replacing the oil pump pulley seal. it was suggested that i also replace the o-ring that goes between the oil pump body cover and the main oil pump part. can the oil pump body be removed without removing the whole pump? also, since some of the bolts are used to hold both the oil pump body cover and the to the housing to the motor, will this cause future leaks? i dont want to open a can of worms. many thanks
