1 - 6 of 6 Posts
G
A neighbour had her Yaris engine written off as the oil pump failed. I
believe some Toyota engines do not have the oil pump interlocked with the
crank shaft and taken off the timing belt. Is that so? Is the Yaris one of
these?
G
Discussion Starter · #2 ·
"L2007" <[email protected]> wrote in message
news:[email protected]
>these?
I am not sure what you mean by "interlocked with the crank shaft," but the
effect of an oil pump that is driven directly by the crank shaft and a pump
that is driven by the timing belt or chain is the same. If the engine is
moving, so is the oil pump.
Ray O
G
Discussion Starter · #3 ·
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
> message news:[email protected]
>>these?
> pump that is driven by the timing belt or chain is the same. If the
> engine is moving, so is the oil pump.
So if the chain breaks no oil and no engine.
G
Discussion Starter · #4 ·
>>>of these?
>> the effect of an oil pump that is driven directly by the crank shaft and
>> a pump that is driven by the timing belt or chain is the same. If the
If the timing chain or belt breaks, the engine will not run. If the engine
is not running, neither the crank shaft or timing belt/chain will drive the
oil pump.
I am surprised that your neighbour's Yaris's oil pump failed because I
cannot recall ever hearing of a Toyota oil pump failing. Mechanical oil
pumps are very simple devices, and since they are moving oil, they are
always well-lubricated.
Ray O
G
Discussion Starter · #5 ·
>>>>the crank shaft and taken off the timing belt. Is that so? Is the Yaris
>>>>one of these?
> engine is not running, neither the crank shaft or timing belt/chain will
> drive the oil pump.
If the pump is off a belt and the belt snaps at say 70mph, In a car with
manual gear change the driver could drop down the gears using engine brake
to stop which means the engine is turning with no oil pump running, which
could mean serious problems. Not fail safe.
It is the first I have heard of. An oil pump failing is such a rare thing
on any car. I asked her if there was oil in it, she replied, yes. She was
on a fast A road doing around 65mph. The engine was written off, which
meant the car financially was. The rest of it is fine, so someone somewhere
will buy it cheap and drop in an engine, or recon the seized engine.
G
Discussion Starter · #6 ·
>>>> message
>>>>>one of these?
>>>> and a pump that is driven by the timing belt or chain is the same. If
>>>> the engine is moving, so is the oil pump.
>> drive the oil pump.
Yes, this is a possibility if the engine is free-wheeling
(non-interference). If it is an interference engine and something snaps at
70 MPH, I would not count on engine braking.
The trend in newer Toyotas seems to be towards interference engines with
timing chains.
> somewhere will buy it cheap and drop in an engine, or recon the seized
> engine.
One person's junk is another person's opportunity!
Ray O
1 - 6 of 6 Posts
