1 - 7 of 7 Posts
1997 T100 SR5 4x4
Will the on board generator on the 2014 Tacoma's run a 110V Hobart wire welder? I'm thinking it probably won't but thought I'd ask anyway.
Steve........
1997 T100 SR5 4x4
Thanks, I thought so but just wanted to double check.
Steve.............
2001 Avln, 2009 Taco
It is called an "inverter." If your "welder" draws less than 400 Watts it would work.
I cannot imagine any type of welder drawing less than 15,000 watts.
1997 T100 SR5 4x4
Discussion Starter #6
I'm pretty sure it draws way more than that. I'll have to look just to know from now on.
Steve.........
A typical 120 volt welder is going to use somewhere around 3000 watts at full output. The limited duty cycle prevents tripping the breaker on a typical 15 or 20 amp circuit.
In case you end up shopping for a generator...
1 - 7 of 7 Posts
