1 - 4 of 4 Posts
I have a 99 1mzfe 5-speed and have run into a dead end... I am having clutch problems... the clutch and bearings are brand new, but I just started having trouble where the clutch pedal does not return. So I did some troubleshooting: master cylinder was not leaking, release (slave) was not leaking. Which led me to believe that the release fork was faulty/damaged. I had no idea how a solid piece of cast metal would be damaged, but I ordered the fork anyway from the Toyota house. Took the bitch apart, replaced the fork. Drove for 10 minutes and the clutch stopped returning again. Troubleshooting again: The only thing I came up with was that if the master cylinder wasn't leaking, the piston was sticking in the bore. So I just bought and replaced my master cylinder. Ok, now my pedal is returning, but I can not select a gear without SERIOUSLY jamming the hell out of the shifter. TROUBLESHOOTING AGAIN: brings me back to the release fork:
"Release fork is not installed properly." I am sick and tired of walking in circles with this car. Can someone please tell me what the hell is the matter and how I can remedy it? Taking it to a mechanic is my LAST resort, as I have always diagnosed and worked on this car myself (excluding the recall and block replacement, as performed at the Toyota house).
93 Camry LE
Well..did you bleed the clutch after you replaced the master cylinder? If I were you..I would have replaced both master AND slave cylinders BEFORE replacing the fork. MUCH less work and MUCH less money!
2002 Camry
If you are sure you reassembled the clutch fork and release bearing correctly - i think there is a possibility your new pressure plate is bad and has weak springs.
1 - 4 of 4 Posts
