41 - 60 of 61 Posts
2020 Avalon XSE - Ruby Flare Pearl
DMattinson, I would just call her and use the numbers for reference and see what her response is. Good luck, CSM-H
I also wonder if it has to do with the fact that I am in SE Toyota region vs. the national
Just for reference; 7yr/100K miles... $925. 8yr/125K miles for $1405..... Not worried about engine or trans, my concern it the electronics!! Good luck, CSM-H
Same here. I want my infotainment, radar cruise, safety sensors to work the life of my car.
2021 Avalon XLE Hybrid
I have bought two from Troy but on my 2019 this lady was cheaper and will send you a list of all prices.
[email protected]
Thanks for the info. I just bought a 7 year, 100k Toyota Extra Care Platinum $0 deductible warranty from Jennifer for $1,040. First extended warranty that I have ever bought for a car. I don’t think it is a bad price. I have a 2021 Avalon Hybrid XLE.
2019 Avalon Limited
Avalon Limited 2019
I don't buy extended anything. My rationale is that the seller has already figured out the average claims costs and the necessary premium to breakeven or make a bit. It's like odds in Vegas. For what it is worth I had a 2000 Avalon and sold it for my 2019 Limited. Had 138,584 miles on it.
I track every expense. Here's a list of everything, and the date and mileage when the expense occured. Biggest expense was Timing belt change at recommended mileage. My total expenses over the 18 years was $11,774 which includes Oil Changes, New Tires, New Batteries. I would never had made back the money for a warranty even if I had it for 18 year.
22-Feb-00​
5​
Purchased Car
01-Jul-00​
3631​
Oil & Filter Change ($28.51)
07-Jul-00​
3776​
CD Changer Replaced - Errors 1 & 3 Randomly
27-Jan-01​
9803​
Oil & Filter Change ($29.96)
24-Feb-01​
10560​
F/E Align (Lifetime) & Rotate
28-Aug-01​
15015​
F/E Align (No Rotate, Rears Slick, Need New Rears)
28-Aug-01​
15015​
Oil & Filter Change ($18.25), Change Trans Fluid
28-Aug-01​
15015​
15k Mile Check
30-Aug-01​
15088​
New Tires - Yokohama
09-Jan-02​
21075​
Oil & Filter Change ($23.44)
09-Jan-02​
21075​
F/E Align & Rotate
06-Jul-02​
26060​
Oil & Filter Change ($23.73)
06-Jul-02​
26060​
F/E Align & Rotate (No adjustment needed)
03-Oct-02​
32128​
F/E Align & Rotate, Radiator Flush, Air Filter 30k Mile Check
03-Oct-02​
32128​
26-Oct-02​
32668​
Stop Light Bulbs (2) - Rear Window (1)
09-Apr-03​
37222​
Oil & Filter Change ($23.65)
08-Aug-03​
39961​
05-Dec-03​
45620​
Oil & Filter Change ($10.74)
18-Dec-03​
45962​
New Tires - Goodyear
28-Feb-04​
47620​
F/E Align
13-Apr-04​
48397​
Battery
13-Apr-04​
48401​
Battery Cable Ends & Clean
10-May-04​
51325​
F/E Align & Rotate
10-May-04​
51325​
Oil & Filter Change ($26.33)
08-Dec-04​
55982​
Oil & Filter Change ($29.49)
26-Apr-05​
58862​
Oil & Filter Change ($23.15)
26-Apr-05​
58862​
F/E Align & Rotate
05-Nov-05​
63714​
Battery Replace - Warranty
15-Nov-05​
64004​
Fix Flat Tires
15-Nov-05​
64004​
Oil & Filter Change ($25.49)
20-Feb-06​
65933​
Brakes/Pads: Front(120) Rear(170), Front Rotors(94), LeftTailLtAssy(232)
29-Jun-06​
69074​
Oil & Filter Change ($33.03)
27-Sep-06​
70436​
Starter
04-Oct-06​
70540​
Battery - Sam's Warranty
12-Dec-06​
71771​
New Tires - Bridgestone (407) Inspect Shimmy (20) + F/E Align
25-Jun-07​
74473​
75k Check - AirFlt(15),CabinFlt(40),ATF(37)Oil/Tire/Cool(22),Spark(42)Labor(254
25-Jun-07​
74473​
Oil & Filter Change ($0)
08-Mar-08​
79432​
Oil & Filter Change ($20.98)
08-Mar-08​
79432​
Fuel System Clean - Intake, Throttle, Injectors
04-Apr-08​
79887​
TimingBelt(Lbr286Belt45)WaterPump(132+99)Belts(29)AAntiFFrz(20)Subwoofer((291+50)Misc(13)
19-Jan-09​
84641​
Oil & Filter Change ($25.37)
16-Jul-09​
88587​
22-Jul-09​
88687​
28-Jul-09​
88745​
Mass Air Sensor Replacement - Code 0171
24-Jun-10​
93214​
Oil & Filter Change ($31.82)
24-Jun-10​
93214​
Rt. Torque Mount (205), Fuel System Cleaning (150)
15-Mar-11​
97383​
New Tires (2 - Yokahama)
02-Jun-11​
98947​
Oil & Filter Change ($25.60)
21-Mar-12​
103695​
Oil & Filter Change ($35.70)
21-Mar-12​
103695​
ATF
18-Apr-12​
103990​
Wipers
21-Mar-12​
104025​
Wipers - OEM
21-Jun-12​
104744​
Steering Wheel Recall (Note ODOM Light Out)
20-Dec-12​
107900​
Body & Bumper Dents & Repaint
29-Jan-13​
108365​
105K Check - Engine Air Filter (21), Cabin Air Filter (60) (ToDo KnockSensor,OilGasketSparkCover)
29-Jan-13​
108365​
Oil & Filter Change ($31.95) Free Change Certificate for Next
19-Mar-13​
108984​
New Tires (4 Kumho Solus)
21-Mar-13​
108992​
F/E Align ($79.95), Knock Sensor ($780.21 - Part $380, Labor $400.21)
21-Aug-13​
111442​
Repair Garage Scrapes
14-Oct-13​
112047​
Battery - Interstate 3Yr Warranty at any Interstate Dealer
20-Dec-13​
113070​
Driver's Window Motor - Part 333.44, Labor 269.01
20-Jan-14​
113639​
Oil & Filter Change ($30.18)
20-Jan-14​
113639​
F/E Allign ($79.95) & Rotate ($20)
22-Jan-14​
113693​
Valve Cover Gaskets, Plenum Gasket, Spark Plug Tube Guards
13-Dec-14​
118743​
Oil & Filter Change ($40.06)
09-Jan-15​
119092​
Starter
23-Jun-15​
121679​
F/E Align
07-Dec-15​
124584​
Oil & Filter Change ($25.82)
10-Dec-15​
124638​
Rear brakes, Pads, Surface Rotors (314). Engine Torque Mount (192), Power Steering Hose, clamps and Refill (61)
20-Jan-16​
125429​
Rear Tires (2)
05-Aug-16​
128670​
Alternator & New Battery(N/C)
10-Oct-16​
129387​
Oil & Filter Change ($31.55)
21-Jan-17​
131339​
Right Rear Tire - Nail - NC except Insurance
21-Mar-17​
132431​
Engine Thermostat,Gasket (185), Cooling System Flush (80)
14-Apr-17​
133000​
Fuse for Cigar Lighter (5-Pack)
29-Apr-17​
133337​
New Spare Tire
08-Aug-17​
134462​
Oil & Filter Change (25.55)
26-Jul-18​
138584​
Sold to Carmax - No repairs in 2018
Sorry guys but I have better things to spend my money on than a TOYOTA extended warranty. If it was a GM, Ford or Dodge I could see it. I had a Ram that was awful. I have had many Honda's and Toyota's over the years. Never an issue. Call it luck but I believe in build quality and you get that with Toyota and Honda. All manufacturers have their problems but my experience has been the Toyota, Honda cars have been by far the best. I don't dump a car unless it has at least 130,000 miles...(my '94 Civic has 324,810 miles). The only car I got an extended warranty on was my 2010 Corvette. Turns out I needed it. I get the peace of mind some of you want but take that money and put it in a special account just in case. Chances are you will still have that money years later. Just my two cents....
I had a 2014 Avalon with 74,000 miles on it. The sunroof started making a popping noise that turned out to be a $2,000 repair. I recently traded it in on a 2021 Avalon XLE Hybrid. I bought the Toyota Platinum $0 deductible 7 year, 100,000 mile extended warranty. Lots of peace of mind for me.
2019 Avalon Limited, Advanced Safety Package, BlackVue DR-750 Dash Cam, Ceramic Pro Coating, XPel
Everyone is different in their tolerance for the unanticipated breakdown. Personally, I would never drive anywhere over 100 miles from home without having Roadside Assistance Coverage, just in case. In our area, AAA runs over $100 a year and the Platinum VSA agreement includes this Roadside Assistance coverage, so in my view, I've already recovered 2/3 of the cost of the 10 year Platinum zero deductible plan just with the plans Roadside Assistance Plan. Roughly $500 gamble that I'll never need the plan, but over 10 years, $500 is about $1 a week. Extremely cheap peace of mind, for me anyhow.
YMMV.
Reactions: Kadena
YMMV.
Just exactly the way I figure it. I have a 2021 Avalon Hybrid XLE. I bought a 7 year, 100000 mile Platinum Extended Warranty on it. This is the first extended warranty that I have ever purchased. On my previous car, a 2014 Avalon I had to have my sunroof repaired at 74,000 miles at a cost of $2,000. I have peace of mind now that I have purchased the extended warranty on this car. Worth it to me.
There's always that chance that someone will benefit from that extended warranty, but for most of us it makes no sense. It is a simple calculation, done by the statisticians: what are the chances of certain costs to be necessary on average, times the costs? So, for example, if they know that on average 1 in 10 cars will need $1000 worth of repairs, it means that average car requires $100 worth of repairs. Now, would they sell extended warranty for that amount? Not a chance! They will sell it for $1000, with $900 profit. Sure enough, there may even be 1 in 100 cars that will require more than $1000 worth or repairs, and it may even be your car. But the probability of that is low. Yes, you do get "peace of mind", but they get good profit selling it to you. This is how insurance works.
Jennifer is legit. Sent her an email and she sent me the following price list.
341971
How about house insurance? I just pay and pay and never get anything in return. Same for car insurance.
Former: '11 Avalon,'12 Prius v Current: '19 Rav4h, '21 Avalon hybrid
In 50 years of home and auto ownership I have recovered for a totaled Porsche and for a tree falling on my roof during a hurricane. You insure for the big things, things you can't afford not to have covered. Modern cars aren't like the '30s cars I learned on or the $25 Model A engine I had a friend buy.
I just got a 2019 Avalon with 45k miles, off lease. The last paper the manager offered was warranty options, and the "all in" price was, I forget, either $4K or $5K. I will have to look into the better priced options.
Oh, wrt Roadside Assistance. Do they tow you to wherever you desire, or only to a dealer? I've been going to the same mechanic for at least 30 years, and he's conveneintly close by.
They will tow you to the nearest Toyota dealer of the location where your car is disabled.
Has anyone used this extended warranty? How easy was it to get repairs covered? I am considering it for the 10 yr/100k miles although still o. The fence just because these Avalons or Toyota in general are such reliable cars.
Does anyone have some experience where this came in handy for a costly repair?
Thank you
Can't answer directly since I'm still under the 3/36 warranty, but it is re-assuring (to me anyhow) every time I pull in to the dealer's service area, for any reason, that the service writer knows I'm still under the basic warranty, and also have the additional 7 years / 64K Platinum warranty. So far there have been only regular maintenance trips or an entune is screwed up again trip.
Reactions: Adisb
My 2020 Limited continues its campaign of hate. The latest issue is my auto-exit seat (or whatever it’s called) stopped working. I checked and re-checked the settings, exercised the full range of the seat, reset the memory positions. Turned the setting to off, partial, and full a dozen times and it still won’t work. It’s been over a week of trying. This car is begging to get punted long before 3/36 is up, no matter how crazy the auto market is.
41 - 60 of 61 Posts
