How to I remove 1/2 qt. of fluid from the transmission with out loosening the transmission plug again. I bought a brake bleeder pump from checkers, the one with the hand pump with gauge and tried to put 1/4" ID clear tubing inside the transmission dip stick hole, to try to suck out the transmission fluid, but it did not work. Don't know if the tubing is inside far enough, but i put it in as far as it could. So now i'm trying to locate the trans cooler line, so i can probably suck fluid out from there. Can anybody show a pic of where it is on a 98 camry v6 1mzfe engine. Also if you guys have any method you can share, please feel free to add your comment. Thanks in advance.
