Hello,
I drive a 2001 Toyota Camry LE with the 5SFE 4 cylinder. Currently have 120,000 miles on it.
A few days ago I was driving and my engine temperature went red hot, so I immediately pulled over to see what the problem was. Turned out the top of the radiator had a hairline crack, and I had lost some fluid. I had some extra coolant in the trunk, so I filled up the radiator and the overflow tank. I was only a mile away from home so I decided to limp it back and it really seemed to drive fine. The temperature stayed at its usual point and it never over heated on the way back home. So I bought a new radiator, some hoses and a fail safe thermostat, all from rockauto. I made sure I flushed out the system with a garden hose before putting the new radiator in. After installing the radiator and the new parts, I filled it up with coolant and proceeded to do the normal burping method IE: fill up the radiator with coolant start the engine, squeeze the top radiator hose and fill as needed. I was only able to get about 4 quarts into the whole system and as I put more and it was just all bubble over. I left the engine running for about 10 minutes and then tried to turn the heat on and it was not getting any heat. Meanwhile, the engine temperature stayed right at the center then tried to do more burping and adding fluid, and I was still getting the same result. I decided to see if driving it would make any difference, and I drove about two houses down, and the engine slowly started to overheat, so I immediately shut the engine off and let it cool. I was then able to pull the car into the driveway where I proceeded to lift the front of the car, add more coolant, squeeze the top, radiator hose and try to get maybe some air out of this system. When the car is idling, the temperature seems absolutely normal, but as soon as I try to drive it, the temperature increases and also my heat does not work at idle. there is one other issue with all of this that kind of makes my head scratch. The water pump we pull has some red residue in the weep hole but not at any point do I see fluid actively draining out of that weep hole. There is just some red residue on the inside of it. I have sprayed water up it to try and clean it out, but it seems as if the red residue comes back but only stay inside the weep hole. Just to reiterate, I do not see any fluid leaking out of the weep hole or even a residue of red fluid that would trickle down the water pump if there was fluid coming out. Also I replaced the water pump 25,000 miles ago when I did my timing belt.
So what’s happening here? Part of me thinks that may be fluid is not circulating in the system, which makes me think either there’s something wrong with the thermostat, if the water pump is bad, or if there is still just air in the system.
