1999 Camry with the 1ZMFE V6. First code was P0340, put a new plug in because the OEM one was crushed. Still had the code, tested the Sensor, 1210 OHM reading, wiring was good (no short or open). Finally gave a new sensor a shot(I was guessing at this point). Reset, and drop, yeh! No light right? Wrong! Dirty F*cker is back, with a harder problem!
Now the Cam sensor is working, it's able to test the knock sensors, and one of those dirty whores is not working anymore.
Bank two Knock Sensor, what do I find out, that whore is under the intake manifold, F*ck! (WHY TOYOTA DID U NOT PUT IT ON THE BLOCK!!)
How to fix it: http://www.findonefindall.com/toyota-sienna/toyota_knock_sensor.htm
I need the diagnose info on these how to test them. Please post repair manual, I don't think swapping them to see if the problem changes to P0325 is a good idea because the time it takes to pull the manifold and all that stuff off.
