Got the p0401 code and the car stutters when stopped and the lights flicker.
I have checked:
Intake manifold cleaned and cleared egr ports
Check vacuum lines
Egr valve has been cleaned and check with vacuum pump for valve function and also while the car is running which stalls when vacuum is applied
VSV checked at 12v and air only flows when applied
Egr modulator has air flow through and clean filter on top, bottom holds a vacuum
Plug to VSV is metering at 0v at idle and up to 13v when open throttle
MAP sensor holds vacuum, one wire in plug is at 5v and another at 3.6v and drops 1v when 5in/hg vacuum is applied.
Any other suggestions? Could it be a bad ECU? Any help would be great thank you.
I have checked:
Check vacuum lines
