Started my 2005 Avalon Touring this morning and had check engine, brake light and ABS light, all at the same time. Started driving and no speedometer and my odometer doesn't calculate and cruise doesn't work. Pulled my scanner and
P0500 Vehicle Speed Sensor VSS Malfunction popped up.
I can't tell from repair manual which sensor they are talking about NT or NC per the code. Looks fairly simple to replace under the air box and battery tray, but these jokers are expensive.
Does P0500 refer to a specific sensor, since I have 2 of them? Anyone have any idea what NT / NC stand for?
Right, magnetic sensor.
Could be wiring/connector/sensor or skid module/combo meter/ECM.
Since speed/odometer doesn't work chances are skid module/sensor or wiring faulty.
Hope OP gets back to us on the fix.
The behavior of the transmission may provide some indication if either or both of the sensors are bad, or the problem lies elsewhere.
If you would like to change a sensor just as an experiment, I suggest this inexpensive $17 one from Amazon instead of the pricey OEM part.
Ok, waiting on parts now, I pulled the current sensor, cleaned it and tried to reset the codes. Whatever is going on, that sensor doesn't look OEM it is some sort of light blue, off brand model sensor. On a test drive, sometimes I had speedometer, sometimes not, then I started to get P0503 along with P0500. I just have it parked until I can sort this all out, along with replacing the master cylinder and adjusting the rod. Maybe this is all related to my mushy brake pedal, not sure. Only had the car for less than 3 weeks, so the history and who did what over the years is completely unknown.
Well, while replacing my master cylinder, I ordered OEM sensor from the dealer and as soon as I put it in, things got worse. The car wouldn't shift correctly. I pulled the part and examined it the oem dealer sensor is definitely shorter than my current sensor. Purchased one from napa, exact same thing, so I'm baffled.
I pulled the negative terminal on my battery and it appears the old sensor is working, but how can the sensor be different?
Immediately if no cruise and no visible indicator of drive selection on dash the shifter cable is out of alignment. Same thing is happening to me now that it is getting colder. Slam the shifter from N to D and see if it corrects. This will be a daily activity until you adjust the cable.
Passenger Side -- has anyone put an electric power psgr side seat from an XLS, Touring or Ltd in an XL (it has no power seat)?
Side note - it seems that the pre-2008 seats are not same as 2009+. Dont make sense to me though
I have a 2010 Avalon with 85k miles regularly maintained (with love), what are some problems or components that typically start to deteriorate with age? What did Toyota cheap-out on for this body style? What have other owners experienced?
Hello all! I'm brand new to TN and look forward to poking around, meeting fellow Toyota owners and learning stuff. I have a 2008 Avalon Limited with 117,000 miles. Right around 102,000 miles there was a bumping noise in the rear. The ride quality degraded so I replaced the struts all around...
Twice in the last two years my vehicle has a misfire in cylinder 1
2006 Avalon Limited.
First repair used OEM ignition coil and Toyota recommended spark plug. Second time was a lessor expensive coil, but an OEM plug.
This time I will be also changing the injector(s)
It seems that moisture...
2012 under 100 k. I suspect front struts should be replaced soon. The dealer isn't wanting me to. Considering the mileage I am curious if the ride can be made better.
What replacements are better? OEM?
