1996 T-100 auto 2WD with the 3rzfe 4 cylinder engine ran fine the night before. The next morning, the engine would fire and then sputter and die. Ultragauge got an immediate code of P0100 and P0505. I could smell that the engine was running lean but no codes were set fer a lean condition. It is unlikely that both sensors died but it could be possible. I had limited tools to work with in the middle of the night so I wasn't able to do any lengthy diagnostics. Removed the throttle body fer inspection as well as the IAC valve. Throttle body and air plenum was dirty but everything moved fine. Inspected the MAF sensor as well. MAF sensor didn't show anything visual issues.
According to this, it's most likely a vacuum leak after the throttle body butterfly plate. I did notice that the throttle body gasket was cracked and a few vacuum hoses were split. I will address those when I visit the strickened T-100 tomorrow morning.
https://www.yourmechanic.com/articl...dle-control-system-malfunction-by-jay-safford
"The most common problem is a vacuum line to one of the intake or throttle body ports."
