1 - 9 of 9 Posts
95 Corolla
Im planning on painting my valve cover this weekend. I tried taking it off, but i couldn't. I only need to take off the spark plug wires and the 6 bolts right? Or does the spark plugs need to come out as well?
once you take off the bolts, it usually wont just slide off, its sealed onto the head. you need to give it some elbow grease...
kor-ro-ra?
97 Corolla 1.8L 5spd
I tried this before too and it wouldn't budge...
Sorry is this is a hijack but how did you guys get the wire harness out of the way?
FEW THINGS TO TRY:
after making sure all bolts are out,and wires out of the way,put oil cap back on and use that as a "handle" to try to move and brake the seal.If not,and i like to use this as a last result,pry with a wide flat screwdriver at one of the corners,taking care not to gouge surfaces!!!!!!!!!!!!!!!
Dave
Resident asshole
Corolla
100% you'll scratch the surface with a screw driver, rubber mallet and few whacks should loosen it up.
1 - 9 of 9 Posts
