Hello,
I had been having battery issues so I took my 2021 Corolla to the dealership and had them do the recommended diagnostics on the battery, starter, alternator, and check for parasitic draws. The dealership said that it was a battery issue and that the battery was so low that they couldn’t test the alternator. They wanted $290 for the battery replacement when the battery was $180 so I decided to just buy it and replace it on my own. I bought a multimeter and wanted to check for parasitic draw.
1. Could someone confirm that I am testing and reading this correctly? I followed the instruction booklet and waited 30 minutes for the car to be in sleep mode, put the black lead on COM and the red lead on 10A, set the multimeter setting to 10A, and connected the red lead to the negative cable and the black lead to the negative post. With those settings I got readings mostly between 0.35-0.45 which I believe is between 350-450 milli amps and way above the 50 milli amp expected limit. When I started to pull fuses I pulled the J/B-B and VVT fuse and it dropped down to 0.19. When I plugged the fuse back in it rose to 0.27. But those levels are still way over what it’s supposed to be.
Second, I was looking at the fuse diagram and I don’t have all of the fuses/relays in the diagram. Is it possible that I’m missing fuses/relays or are those likely for options/configurations that I don’t have?
Thank you so much in advance!
