1 - 3 of 3 Posts
Hi, I have a 1999 tacoma v-6,4x4,ext.cab,auto. If I put on a high performance exhaust, and a cold air intake, should I have the engine tuned? If so, who does that kind of stuff, and how much will it cost? Also, will a throttle body spacer make a lot of difference in performance? Thanks
· Offical TN Hillbilly
2002 Silverado
Uh.....no you don't need the engine tuned. Skip the intake and do the deck plate mod. The exaust makes a pretty noise, but that is about it. TB spacers are worthless. Really, there isn't anything that will significantly boost power short of putting on a supercharger. The only reason the deck plate mod is worth doing is because it can be done for about $20.
What you really need to make your truck kick ass is the Tornado fuel saver it atomizes the fuel and air mix in the throttle body into a tornado like swirl and makes your engine into a 454 Chevy V8 and can blow away any Honda Ridgeline out of the Supermarket parking lot (totally just kidding):clap: none of that crap works. Try using some Amsoil synthetics throughout it helps with a little better drivability.
1 - 3 of 3 Posts
