1 - 7 of 7 Posts
I'm trying to research wether their was a keyless entry system option back in the day for my camry and if possible I wanna see about locating and learning how to instal said parts. Anyone have any information on this?
· Super Moderator
1995 T100 2WD & 1993 MR2
Keyless systems were introduced in the US in 1983 by American Motors and followed bt GM and Ford by the end of the 80's. Toyota introduced a version in the late 90's and 2000 to the US market.
· CRESSIDA!!!
1984 Toyota Cressida
That fob is the dealer/port accessory fob. These were never built from the factory with keyless but that was an option from the factory after the car was built.
· 3s-gte in a Camry?!?
'89 Camry Alltrac
How about a newer RS3000 system? That's the late 90's port-installed Toyota alarm system. I think it should control door locks for you...
-Charlie
2000 Camry 2.2
You might want to try some kind of aftermarket system.... it will likely be a LOT easier to install / setup vs trying to find nearly 40 year old components, plus youd have the advantage of modern day tech / signal waves vs 1980s tech.
1 - 7 of 7 Posts
