1 - 13 of 13 Posts
· Official TN Asshole
85 yota/ 99 audi s4
i think this is the "torque" arm/rod???
and w/ the nwor lift, they include this little bracket thing to lift it up..now if you don't cut the top of it off, it will hit the headers when you're articulated..and then today, when i was testing the new articulation, i noticed that its kinda bending when its really twisted up..this is a pic of it...
does any other company make a better one that drops it from the fram, instead of lifting it from the axle?
that would be a way better setup i think if you leave the sway bar on, cuz they look like they interfere with each other..
heres a pic...
4 toyotas
Take it OFF !!!!!!!!! throw it in the nearest dumpster !!!!!!!
4 toyotas
with a loaded truck, to slow/minimise 'body' roll in corners.
with an empty or as most of us load a truck=== worthless !!!!
i took it off my '92 the day i bought it------- never put one on the '85 !!
85 yota/ 99 audi s4
Discussion Starter · #7 ·
why would a 1992 toyota pickup that is ifs have that arm that attatches to the straight axle?
and even if it was a sas kit, they wouldnt inlcude that.
keep in mind that this isn't the same post as the sway bar post.
this is for the torque arm...you with me here?
When your truck is stock the torque arm is used to help control bump steer, once you add a lift kit you should remove it because it will limit your suspension travel. like everyone here is telling you, just remove it, you no longer need it.
4 toyotas
anti-wrap bar--- to control possible 'spring rap' and bump steer with push-pull with lift
throw it.
The torque arm has been removed from my 85 truck when the lift was installed, no problems at all. my cousin has an 85 4Runner with dana 60`s front and rear with no problems at all, you are kind of making this harder than it needs to be, just remove it. nobody here would give you bad advise that would mess up your truck.
4 toyotas
sea-- if you would like- since i can't seem to be able to post pics on this board if you would like, i'll post a couple on Pirate so you can see my modified '85 truck---
on 36's
cross over steering-(home made)
diff guards (8"weld-on well pipe caps)
lift-off doors
rock sliders
tube bumpers w/winch
chevy springs-rear, all-pro 4" fronts
square tube front driveshaft
no 'torque shaft'-
etc-etc--
1 - 13 of 13 Posts
