1 - 3 of 3 Posts
Tires and lift help needed
Hi all, I've never posted anything before, but I'm looking for some advice. I would like to make my 87 pickup (2wd, long bed) look a little meaner. I'm giving it a new paintjob, but it sits a little low on the 195/75R14s I have. Are there larger tires I can put on the factory rims? I would like to keep my costs down, so keeping the factory rims is one way of doing it. Also, should I consider lifting it a few inches? What kit would you recommend?
Thanks for the help!
King Dingaling
77 scottsdale 4X4
as far as the tires go.....
check out used tire shops in your area, (look in a phone book...) they're usually pretty knowledgeable when it comes to throwing on bigger tires. plus you'll save a ton of money on rubber. you can get tires with 80%tread for dirt cheap! (I used to work at one)
just my 2 cents take it for what its worth...:D
1 - 3 of 3 Posts
