I was just wondering if someone else is having the same problem as I am.
What I have is 98 corolla LE auto, when we first got the car it had 192,000miles
Initially the tranny was having some issues when in reverse but it was still moving, after replacing the oil and filter it got better. As of now the car 205,000 miles and the reverse only works when the engine is cold. I can start the car put it reverse let go of the brake and it will move like a dream, once its driven for a while and I put it back in reverse nothing happens, literally you will think it is in neutral. I have to rev it a couple of time and then I can feel the reverse slipping a little but making the car move barely. All other gears are fine, usually I drive on the highway around 70-75 mph and the car rpms are around 2500 may be 2600 if i have the A/C on!
Anyone else having this problem? The Toyota dealer told me that those 4 speeds auto are very likely to go out!
Thanks!
Thanks!
