So I apologize about using the annoying all caps in the title, but it is late and this is a time sensitive issue
I was driving home from work today and I stopped to get food. When I got back in the car, I turned it on and it sputtered and died, I turned it on again and it fired right up. I look down, and the temp gauge is in the red. Seems strange as I never saw any steam.
It looks like the reservoir is pretty full, so I'm confused but I'm only a few blocks from home. I turn the heat on full blast as I was always told to do if its running hot, but the heat is cold. So I get home and start researching online.
Sounds like theres a bubble in the system, so I try burping it and didn't really see any noticeable bubbles, but I make sure its topped off with fluids and I go for a drive.
Uh oh. Starts getting warm. I pull over and open up the radiator, I try to squeeze the top radiator hose to help with the burp, doesn't seem too do much. This time however, with the radiator cap off, eventually it seemed like a full blown overheat as steam started pouring out of the radiator.
I drive it halfway home and it seems the heat kicks on for a few minutes now, I notice the temp gauge return to normal. I felt like a success! Very short lived however. After a few min of the heat coming and going, it went and never came back. Temp slowly creeped up, so I decided to pull over again. I went inside to get another jug of water, and when I came out I poured it in (the engine was hot, the water was warm, in retrospect, doesn't seem like the smartest idea).
It boiled over a few more times until it was cool enough to hold a little and put the cap back on.
Now heres where we stand:
I had to play with the big flathead screw on the throttle body quite a bit to keep it running. It seems as if whatever I had it set to this morning will no longer keep the truck running. I'd say in order to keep it idling now I have to unscrew the thing about 75-80%.
When I parked it on a REALLY steep hill, it wouldnt stay idling, I thought this would get all the burps out, but I had to adjust that screw again just to make it idle. After a few min of letting it idle, no burping or bubbles so I gave up.
During this whole ordeal I somehow popped my donut, so the truck is parked for the night until I can go get a tire tomorrow morning.
At that point, what are my best options for safely getting it a few miles home, and then from there how do I begin to diagnose the coolant issue
side question: how likely is it that I damaged the motor? Steam never came from anywhere other than the top of the radiator, it doesn't make any horrendous knocking, ticking, or pinging noises.
Sorry for the ramble.. I'm in a very bad place right now and this was the last thing that needed to happen. I appreciate any and all advice.
