Hello Toyotanation!
My door locks, factory alarm, door trigers, trunk relase, keychime with the door open as well as the ring that lights up around the key, dome and maplights and the lights in the front 2 doors, the autoheadlights, and the delay for the power windows after u shut the car
off, have all stoped working. I was working on my car and had the 2 rear doors and trunk open for most of the day and at some point while I was not paying attention all the lights where shut off now I do have a 3"LED strip for my dome light and a 32" blue led strip for my trunk light. I work in a custom shop in Winterville, Ohio (First Class Customs) so I know wiring. I do remote starts/alarms daily along with custom stereo and upholstery. I also do paint and body work so i know what im doing be for I say, I was installing my stereo system. Now the system has been in there for 2 years all I did was remove it, tape the positive wire and remote turn on wire off and then relocate my amp to the rear deck and DeadSkin my trunk. Now like I said befor at some point every thing went out on its own because all the stuff was working when every thing was out of the car. Then after a while I noticed all the above things not working.
SO........
I checked every fuse inside the car even the ones under the driver knee panel in the fuse box. Also checked under the hood all the fuses and some relays that i didnt know what they did all where fine. Then I know that the door lock realys click in the passanger kick panel checked 3 realys I found under there all work fine. the lock and unlock wires sit at ground and should alwyas have voltage negative actavaites the door locks on these wires only thing I can think of that I have not checked is the look switch itself. But I dont see how that could be just because of all the other stuff. I would love a wiring diagram for the hole dash fuse box and security system if any one has one. Or any idea where to start.
THANKS FOR LOOKING
PLEASE HELP:help:
Update: Today I checked the relays on the back of the inside fuse pannel and tried swaping around some fuses agin still cant find nothing and nothing seams to be pinched or corated anywhere.
SO........
THANKS FOR LOOKING
PLEASE HELP:help:
