1 - 3 of 3 Posts
tempature gauge is not reading at all. i replaced the tremostat because i thought it might be stuck open so it was reading very low, during replacing it i discovered that there was no wire going from the water temp sensor, so i need to know where that wire that comes from the sensor plugs into?? i have searched and searched on the net and there is now wire diagram in my book for a 1986.. it doesnt overheat just hate not knowing if im running hot. where does that dang wire plug into????? :help:
Soylent Green sales
rock crawler
The wire from the coolant temp sender to the gauge is yellow with a green stripe.
If you can't find it you can always run your own.
1 - 3 of 3 Posts
