1 - 2 of 2 Posts
Desperately after an idea please my van wnt start ignition has power if its wired straight to starter motor but wnt turn over with the key. Ignition all test positive for power. So somewhere between the starter motor and ignition i have lost power . Even with power but it wnt fire . Ive spent the last 3 nights trying to google what it is . Its a 94 previa and manual
So it has power to the ignition switch, but it wont crank from the key switch, yet you can get it to crank if you jump the starter, but it wont start? I don't know if this explains the no fire issue, but if the key cant crank the engine on a manual transmission car, then that usually means the neutral/clutch safety switch is bad.
I suggest testing it for continuity if at all possible. (just my armchair diagnosis)
1 - 2 of 2 Posts
