1 - 3 of 3 Posts
i have a 06 tacoma with a 2.4 automatic. i have replaced the tps,fuel filter,cap,rotor,plugs,wires cleaned maf. while driving it would spit and sputter every now and then but now it will run for 2-3 min then once it is warmed up the stumbles bucks carries on cant even drive it. if you stop it will shut off but start back up and idle good for a min or so then act up more. it doesnt matter whether i m going 50mph or going 5mph it just acts like it is running out of fuel or misfiring but the check engine light doesnt come on and over the past year my gas milage has gotten progressively worse. i can hear the fuel pump running. was wondering if anyone has any ideas before going to dealership.
thankyou
01 & 04 S-Runners
There's little chance of diagnosing the problem unless you can retrieve the problem codes. You can do this yourself with an appropriate scanner. Otherwise, you'll be needing to take it to the dealership (or other shop) to have it checked out.
2000 Tacoma TRD
While the check engine light might not be on, there could be some stored codes on the computer to retrieve and give you an idea of where to start. Try running to AutoZone and getting the free diagnosis to see if there is anything stored on the truck's computer.
1 - 3 of 3 Posts
