i looked around and still confused. Do i need any other accessories to make this light working such as an baillasts etc. ? If so... any recommendations on where to pick it up for a reasonable price.
Thanks again.
alright
lifestar, hopefully I can point you in the right direction. The headlights come with everything you need. There should be two wires hanging out of each unit, one red, one black. The red, you'll need to attach to a 12V power source. The black to a ground. A lot of people attach the red wire inline with the parking lights, the halos light up with the parking lights are on. I've heard of people wiring them to the DRL, but the DRL run at less than 12V (and go the full 12V when the high beam is activated, I think) so that may not work well. I also got a set of these headlights. I'm going to wire them like aftermarket fog lights. I'm planning to running a switch inside the cabin, so I can turn them on and off. I'm also in the process of changing out the projectors to HID, this is a little more involved and taking me some time and a lot of research. Like everyone else is saying, try the Search function on the forum... type in "halos" "halo wiring" "angel eyes" or even "fog wiring". Heck, google it. The wiring of the halos should be similar to any car. Btw, if you're even slightly unsure about handling car wiring/electronics, don't do it yourself, pay a professional to do it. Not worth messing up your car. Good luck. Have fun. Be careful.
