Is there a way to wire around the igniter assembly on a 2tc engine and just run a coil?
Anything is possible if you try hard enough - but it's not necessarily a good idea. The 'igniter' is really what provides signal amplification from the distributor-mounted sensor - it's the part that actually 'fires' the coil. The sensor gives a 1/2 crank-speed-signal, the igniter switches the coil circuit to generate the spark.Is there a way to wire around the igniter assembly on a 2tc engine and just run a coil?
