Ok all, I need suggestions for what might be the soulution to this:
My car starts fine / idles fine when cold however the throttle response is very sluggish. So unless I have it up to around 3K RPM when I relese the clutch it will either die or nearly die if I don't re-engage the clutch. (I have a steep driveway) I don't particullarly want to replace my clutch in the near future. When the car has warmed up to normal operating tempature this isn't a problem. However it still seems that the overall thottle response could be a bit snappier.
I still have plenty of torque for climbing hills in 4th or 5th gear. And I recently did a tune up consisting of Dist. cap, rotor, wires, spark plugs and such.
So in your experiences what is the most probable cause for these problems?
Now one thing that I thought of might be I need to reset the ECU. Because until recently this car was driven daily at an altitude of around 6500ft above sea level and now is being driven at an altitude of around 1100ft above sea level. Does anyone else think this might help?
