1 - 12 of 12 Posts
Hi guys, I'm new to the site and need some help. I've got a 92 2wd 4cyl 5spd pickup that just recently started popping out of gear while driving. It has maybe 5k on a new clutch. It is lifted with spindles and torsion bars in the front and 2' shackles in the rear. I notice that when in gear and coming to a stop the shifter while pop out of gear and it seems almost like its because the motor and tranny are shifting during that time (deceleration). I thought about a new sleeve cylinder because it is kind of hard to get it into gear sometimes but once in gear it should stay there right? Any info would be great.
Discussion Starter · #10 ·
That sucks. I'm trying to figure out which seat I need, either white or blue? What exactly is a forward shift T case handle? I'm pretty sure the white one is the one I need which is most 1981+ top shift tranny's. Any tips to figure out which one mine takes?
Soylent Green sales
rock crawler
You don't have a t-case, your truck is 2WD.
If you have a 22R you should have a G series trans, and if it's a 22RE it should be a W series trans.
1 - 12 of 12 Posts
