Hi -
I'm mostly on TN related to my 1994 Corolla but recently I was asked by a family member if I wanted their old 1998 Avalon (~100K on it) when they get a new car next year (probably a new Avalon... they love those cars, they also own a 2008[?]).
Except for oil changes (every 6 months consistently at the local Jiffy Lube [eek!]) and tires everything has been serviced by the dealership with OE parts. They've followed the maintenance booklet to every last detail, so transmission fluid drain and fill every 30k etc, frequent coolant exchanges, timing belt every 7 years, etc. The following service has been completed recently:
- Water pump, timing belt & tensioner, crank/cam seals
- Head gasket (small oil leak) replacement
- Sway bar bushings and I believe end links?
- A/C compressor replacement
- Power steering rack replacement
The car drives well and has had none of the oil sludge issues some experience (probably due to their frequent and consistent OCIs). Car has been garaged since day one. I can't find any rust on it despite living in the rust/snow belt(!) - they avoid most driving in bad winter weather and do frequent car washes - seems to have worked wonders.
My question is - what should I look out for that typically fails at this mileage that hasn't already been addressed by the list above? I typically do all maintenance and repair myself so major concern would just be cost of parts, not labor (except for time investment!). I'm not sure when strut assemblies start to wear out on these cars? The clear coat has started peeling a bit here and there but nothing too nasty. I also think there's an exhaust leak somewhere as it sounds pretty loud. Flex pipe a typical weak area? What about engine mounts - those fail around 100K on the same vintage Corolla... perhaps the V6 is easier on the mounts due to less flexing/vibration than an inline 4 cyl? The upstream O2 sensor is likely original, so that might also be an item to replace at this point? Same with thermostat? I'm not sure if alternator and starter are original but I'd almost expect the starter to have been replaced by now... those 100k involve a lot of short tripping.
